SDrive-Max Installation HELP!
42 replies to this topic
#26 E474 OFFLINE
E474
    Chopper Commander
  • 234 posts
Posted Sat Apr 27, 2019 3:07 PM
Hi,
You use avrdude to program the Arduino firmware (e.g. the memory built in to the Arduino). You need a micro-sd card to store ATR disk images (and possibly XEX files, but I am not 100% sure of this). You will need to use a PC to load up files onto the micro-SD card, you might also need an adaptor to put the micro-SD card in, as most PCs have SD card readers, not micro-SD card readers.
#27 toddtmw OFFLINE
toddtmw
    Dragonstomper
  • 632 posts
Here is a picture of one I did for myself.
#28 DrVenkman ONLINE
DrVenkman
  • 4,085 posts
  • Back off, man! I'm a scientist.
Posted Sat Apr 27, 2019 3:08 PM
A question I can't seem to get anyone to answer.    So how do I get files on the CD in the first place?    Do I load them on with a card reader?   Can I load them with the USB interface to the Arduino?   Or do  I also need an SIO2PC?
You mean the SD card or microSD card? Yes, you need to write them to your card from whatever other computer or device you have and your card reader.
#29 spinnaker15136 OFFLINE
spinnaker15136
    Chopper Commander
  • 144 posts
Posted Sat Apr 27, 2019 7:08 PM
Now completed build, thought I would show you what I did as I couldn't use the SIO Cable from an old 410 Cassette, I couldn't
get the pins out to move the motor control to Command line as Command signal not used in Cassette.
Some years ago I built a SIO2PC and didn't have a spare SIO Cable so I cut one of my 1050 SIO cables in half, then soldered
a 25pin male/female to each half, I used a 25 way on the input to the SIO2PC box.
This meant I could use the SIO2PC but also join the cable back together when I wanted to use the 1050.
I decided to use this cable and put a 25 way (I have loads of components, so no purchase needed) on the SDrive
cable, I also didn't really want to mount the board with the 7407 in the Arduino, so I put the circuit board in a small
box between the plug and the SDrive.
All working fine now, only tested with 130XE, but will try on the 800 later.
I've added a diagram of the circuit I used, I wasn't happy with the ones I've seen before where the Atari +5V is connected to
the Arduino +5V (a recipe for disaster).
All I have to do now is find a suitable case
What did you use for the cable from the Arduino?   Sort of looks like one of those modular phone cables.
#30 spinnaker15136 OFFLINE
spinnaker15136
    Chopper Commander
  • 144 posts
Posted Sat Apr 27, 2019 7:11 PM
This post from me near the end of that same thread has the version 1.1beta files already compiled.
The zip has folders for each of 4 or 5 supported touchscreens. Basically you’ll copy the .hex files for your model display out of the sub folder into the main folder, then you can run the batch file in the post I linked to first.
You say "this post"   but I don't see a link.   Am I missing something?
#31 DrVenkman ONLINE
DrVenkman
  • 4,085 posts
Posted Sat Apr 27, 2019 7:18 PM
Huh. My link disappeared. Here you go:
http://atariage.com/...port/?p=4226460
#32 TGB1718 OFFLINE
TGB1718
    Chopper Commander
  • 102 posts
Posted Sun Apr 28, 2019 4:10 AM
the cable I used to the Arduino is just ribbon cable
#33 bbking67 OFFLINE
bbking67
    Dragonstomper
  • 506 posts
Posted Sat May 11, 2019 8:08 AM
Ive purchased an r3 and screen that are supposed to be compatible... are there detailed instructions on hooking up the SIO cable?  I saw a reference to having a diode and I cant seem to find a proper tutorial with schematic.
#34 DrVenkman ONLINE
DrVenkman
  • 4,085 posts
Posted Sat May 11, 2019 8:24 AM
You may need to use Google Translate or something, but there are instructions on the ABBUC page below:
http://www.abbuc.de/...php?f=15&t=9451
There are only a handful of wires you need to connect: +5V (which can come from the Arduino’s power input or the SIO bus BUT NEVER BOTH AT THE SAME TIME!), GND, Command, Data In, and Data Out.
The instructions about the diode are frankly outdated - initially people believed a diode on the Arduino Tx pin would sufficiently isolate the device and prevent it from “taking over” the SIO bus, so you can use the SDrive-MAX with other SIO devices at the same time. Unfortunately, further investigation reveals that the diode doesn’t really do the job properly. Post 13 above from the OP shows how he wired up a 74-series buffer chip and a few resistors to provide proper SIO isolation. But if you don’t use the SDrive-MAX alongside real floppy drives this is unnecessary.
#35 TGB1718 OFFLINE
TGB1718
    Chopper Commander
  • 102 posts
Posted Sun May 12, 2019 9:29 AM
Look at page one of this thread, about 3/4 way down first page, I put a circuit diagram of whats needed and it works fine with a 'real' drive.
#36 _The Doctor__ OFFLINE
_The Doctor__
    Flux Capacitor Master Craftsman
  • 6,959 posts
Posted Mon May 13, 2019 1:15 AM
http://atariage.com/...help/?p=4234325
#37 Forrest OFFLINE
Forrest
    Chopper Commander
  • 205 posts
Posted Mon May 13, 2019 6:17 AM
My plan is to leave SIO pin 10 (5V) unconnected, and power the SDrive Max from the 5V provided by the USB connector. So I will be powering the chip from the 5V from USB also. Any issues?
Edited by Forrest, Mon May 13, 2019 6:18 AM.
#38 DrVenkman ONLINE
DrVenkman
  • 4,085 posts
Posted Mon May 13, 2019 6:44 AM
Nope, no problem at all.
#39 _The Doctor__ OFFLINE
_The Doctor__
  • 6,959 posts
Posted Mon May 13, 2019 8:20 AM
I just use the power jack, sometime with power pack, sometime with a battery... depends where I am....
#40 PE1PQX OFFLINE
PE1PQX
    Space Invader
  • 16 posts
Posted Mon May 13, 2019 8:54 AM
Looks very interesting...
Any chance the SDrive-MAX is somewhere available as a kit?? (No experience with Arduino here)
#41 telmnstr OFFLINE
telmnstr
    Space Invader
  • 34 posts
Posted Mon May 13, 2019 10:55 AM
There are units listed on eBay out of UK complete with 3d printed case/SIO connector. No experience with seller.
Edited by telmnstr, Mon May 13, 2019 10:55 AM.
#42 DrVenkman ONLINE
DrVenkman
  • 4,085 posts
Posted Mon May 13, 2019 11:41 AM
Check out MacRorie’s website as well: http://thebrewingacademy.com
In addition, a fellow named Gavin sells completed units on Facebook in the Atari 8-bit Computers group there.
#43 slx ONLINE
slx
  • 1,881 posts
Posted Mon May 13, 2019 12:34 PM
You need zero Arduino experience to do this. You plug the screen module (shield) into the Arduino board (almost impossible to plug it in the wrong way round) and f you make the version that monopolizes the SIO bus, you need to solder five wires to points on the Arduino (a bit easier if you get one with extra contacts next to the connectors, but if it has connectors only, you can solder to the underside. Either before or after assembly you connect it to a PC using USB and run two programs to flash the firmware. It's a case of "just follow the instructions".
IMHO the only two reasons not to do it yourself are not being able to solder or not wanting to care about a housing.
