Joystick failure
9 replies to this topic
#1 JamesH OFFLINE
JamesH
    Combat Commando
  • 7 posts
Posted Sat Mar 9, 2019 5:18 PM
Have a joystick adapter and two modern Atari joysticks from a Flashback. Powered up my TI today and the up direction does not work, tried both sticks on both ports. Any tips on testing the adapter and the console? Any common cap or resistor failure that I can check for? Thanks.
#2 HOME AUTOMATION OFFLINE
HOME AUTOMATION
    Moonsweeper
  • 390 posts
Posted Sat Mar 9, 2019 5:24 PM
you probably already know about the ALPHA LOCK key thing? :)
#3 jrhodes OFFLINE
jrhodes
    Moonsweeper
  • 286 posts
Posted Sat Mar 9, 2019 5:28 PM
Dirty joystick port? And yes, make sure the alpha-lock is off (raised) when using a joystick.
#4 twoodland OFFLINE
twoodland
    Chopper Commander
  • 214 posts
Posted Sat Mar 9, 2019 5:30 PM
Have you eliminated a problem with the joystick itself?  Do you have the Atari Flashback console to test the joystick?
Sometimes the problem can be with the contacts inside the joystick:
Atari Flashback 2 Joystick
Atari CX40 Joystick
#5 JamesH OFFLINE
JamesH
    Combat Commando
  • 7 posts
Posted Sat Mar 9, 2019 5:47 PM
No, I didn't. And, yes, the caps lock was on. HAHA.
Edited by JamesH, Sat Mar 9, 2019 5:52 PM.
#6 Ksarul OFFLINE
Ksarul
  • 5,212 posts
Posted Sat Mar 9, 2019 6:16 PM
We all make that mistake at least once. . .
#7 FarmerPotato OFFLINE
FarmerPotato
    Moonsweeper
  • 310 posts
Posted Sat Mar 9, 2019 6:19 PM
Would you like to modify your console? It's beginner level soldering.  Read about fixing the alpha lock problem once and for all by adding a diode (follow link on that thread to MainByte article).
#8 JamesH OFFLINE
JamesH
    Combat Commando
  • 7 posts
Posted Sat Mar 9, 2019 6:22 PM
Interesting. Maybe once I get my electronics bench outfitted and pickup an untested console for modification. Otherwise I want to keep my console as original as possible.
#9 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,806 posts
Posted Sat Mar 9, 2019 6:44 PM
It's a nice easy mod and doesn't even require removal of the keyboard, which now days can be problematic because those ribbon cables have been known to self-destruct from becoming so brittle over the decades.  It's a nice thing we have Arcadeshopper in our ranks, as he's started carrying replacement cables for unfortunate users.
#10 apersson850 OFFLINE
apersson850
    Dragonstomper
  • 591 posts
Posted Mon Mar 11, 2019 7:39 AM
The alpha lock diode thing was the first modification I did to my console. Over time, more would come...
