Programmer's Reference Manual
35 replies to this topic
#26 phaeron OFFLINE
phaeron
  • 2,734 posts
Posted Tue Mar 12, 2019 11:01 PM
Yes, the ASL stores the high bit (inverse video) into the carry, then pushed in the stack with the PHP, so the state is unknown at the SBC.
Right, but A bit 0 is then guaranteed to be 0 at that point and is discarded later with the ROR, so the SEC can be dropped and the SBC adjusted to SBC #$3F, or equivalently ADC #$C0 used. Did an exhaustive test of all 256 values and it seems to work fine.
does not change perocesor flags nor registers
delay6 .byte $80
delay5 .byte $80
delay4 .byte $80
delay3 .byte $04
delay2 .byte $1a
Thanks, but I'm avoiding including anything with illegal opcodes for now. Most of the time they are not necessary and I don't intend to encourage recreational use of them.
#27 dmsc OFFLINE
dmsc
    Dragonstomper
  • 508 posts
Posted Wed Mar 13, 2019 5:18 AM
Hi!
You are right, I missed the fact that adding one more is not important, as the last bit is then discarded!
So, now the code is une byte shorter and two cycles faster :)
#28 pirx OFFLINE
pirx
    Moonsweeper
  • 451 posts
Posted Thu Mar 14, 2019 2:09 AM
 ...and I don't intend to encourage recreational use of them.
Laughed my a**e off :))))
#29 flashjazzcat OFFLINE
flashjazzcat
  • 14,493 posts
Posted Thu Mar 14, 2019 5:39 AM
Hi,
   One routine that I end up using in almost all my code is byte -> 2 digit hex code, I copied it from: http://atariage.com/...o-ascii-string/ - obviously it can handle word values by being called twice.
Cool! In the SIDE loader, I was able to replace this:
	.proc HexOut
	tax
	lda HexTable,x
	jmp PutChar
	.endp
(which required a 16 byte look up table) with this...
	.proc HexOut
	sed
	cmp #9+1
	adc #$30
	cld
	jmp PutChar
	.endp
...which is only 2 bytes longer but requires no table at all. :)
#30 Irgendwer OFFLINE
Irgendwer
  • 1,459 posts
Posted Fri Mar 15, 2019 4:41 PM
You can do it in one cycle less, but three bytes more, using a ZP location:
                ; Bytes   Cycles
 sta zp         ; 2       3
 and #$60       ; 2       2
 asl            ; 1       2
 bmi ok         ; 2       2 3
 eor #$40       ; 2       2 0
ok:
 adc #$40       ; 2       2
 lsr            ; 1       2
 eor zp         ; 2       3
The variant from cc65 is also interesting:
        asl     a               ; shift out the inverse bit
        adc     #$c0            ; grab the inverse bit; convert ATASCII to screen code
        bpl     codeok          ; screen code ok?
        eor     #$40            ; needs correction
codeok: lsr     a               ; undo the shift
        bcc     done
        eor     #$80                ; restore the inverse bit
done:   ...
or my alternative to the above (one byte shorter but slower):
codeok: tax
	lsr     a
	txa
        ror     a
Compared to the php/plp version this is one byte longer but one cycle faster (of course with the drawback that X is used), so a lot of versions to choose from...
Edited by Irgendwer, Fri Mar 15, 2019 4:46 PM.
#31 dmsc OFFLINE
dmsc
    Dragonstomper
  • 508 posts
Posted Fri Mar 15, 2019 9:36 PM
Hi!
        bcc     done
done:   ...
That is the fastest yet, at 12 to 14 cycles, but I suggest the following that returns with the carry always cleared:
        asl     a
        adc     #$c0
        bpl     codeok
        eor     #$40
codeok: lsr     a
        bcc     done
        adc     #$7F
done:
codeok: tax
	lsr     a
	txa
        ror     a
If you are using the X register, you can do faster:
        tax            ; 1  2
        asl            ; 1  2
        sbc #$3F       ; 2  2
        bpl ok         ; 2  2 3
        eor #$40       ; 2  2 0
ok:     cpx #128       ; 2  2
        ror            ; 1  2
#32 flashjazzcat OFFLINE
flashjazzcat
  • 14,493 posts
Posted Sat Mar 16, 2019 2:45 AM
These solutions are almost as efficient as my preferred solution where it's possible: reordering the font data so that ASCII = internal. Unfortunately this method is useless if you a) want to use the resident font or b) want to share the display with anything else (TD Line, etc).
#33 Stephen OFFLINE
Stephen
  • 7,584 posts
  • A8 Gear Head
Posted Sat Mar 16, 2019 9:24 AM
Does anybody know why the font was arranged this way?  Probably to save a few transistors in ANTIC and have the extra colours in the low res text modes?
#34 dmsc OFFLINE
dmsc
    Dragonstomper
  • 508 posts
Posted Sat Mar 16, 2019 10:14 AM
Hi!
My guess, to make the useful characters - numbers and upper case letters, ASCII from $20 to $5F - available in antic modes 6 and 7 (the 64 character modes).
But of course, if they had put lowercase into $40 to $5f and control chars into $60 to $7f, the code to transform ATASCII to screen would be shorter and faster :P
#35 _The Doctor__ OFFLINE
_The Doctor__
    Flux Capacitor Master Craftsman
  • 6,703 posts
Posted Sat Mar 16, 2019 1:11 PM
dmsc..  you could make the changes and share with Facaui could add it to one of his specials!
#36 E474 OFFLINE
E474
    Chopper Commander
  • 210 posts
Posted Sat Apr 6, 2019 3:01 AM
Hi,
I wrote asking about adding a chapter on different programming environments a while back, but I think that would probably just end up duplicating the info in http://atariwiki.orgso it's probably better not to do so.
I wonder if it's worth listing other resources available, e.g. atarimania, atariwiki, atari8, pigwa, atariage, etc., or pointing to a list of these, just as a useful list of resources for people getting back in to the 8-bit scene?
