Mcwill install help
8 replies to this topic
#1 As3rox OFFLINE
As3rox
    Combat Commando
  • 5 posts
Posted Mon Mar 11, 2019 10:33 AM
Hi I hope someone maybe able to help, I purchased a lynx2 at a carboot and really don't think the chap really knew what he had, anyway it had a mcwill LCD in it works sort of but displays lines from top to bottom and colour is off,
I'm thinking it was done without doing the caps I have completely unsoldered the screen and had to shorten the wires as I could install two screens with the amount that was used, it's still the same. Iv checked the power and it's a steady 4.8 volts i have tried a variety of games and all display these lines, also pressing the backlight button just makes the screen go blank and not change the screen mode, I have disabled vga and connected a wire from menu to gnd.
If anyone has seen this before any information on how to fix it if I can would be greatly appreciated
J
#2 necrocia OFFLINE
necrocia
    Moonsweeper
  • 432 posts
Posted Mon Mar 11, 2019 3:00 PM
It looks like it's not getting all of the colour channels, have you done a recap now or just shortened the wires and removed VGA?
#3 As3rox OFFLINE
As3rox
    Combat Commando
  • 5 posts
Posted Mon Mar 11, 2019 3:52 PM
Iv ordered recap kit hopefully I'll get it tomorrow, Iv have just shortened wires and removed vga. I have also ordered some ribbon cable as all these wires flopping around is doing my head in.
Would bad caps stop some of the colour channels?? I have had a good look at it loos like it has been recapped but because of the state of all these wires I don't think I can trust if a: the right caps have been used and b: the solder joints are good.
#4 necrocia OFFLINE
necrocia
    Moonsweeper
  • 432 posts
Posted Mon Mar 11, 2019 4:57 PM
Not entirely sure but recap is worth doing. I've come across cold solder joints even in my own Lynx so that could be worth checking out.
#5 As3rox OFFLINE
As3rox
    Combat Commando
  • 5 posts
Posted Sun Mar 17, 2019 12:14 AM
Well finally got round to recapping and reinstalling mcwill with better wire, still no change have a lynx 1 but not keen on testing the mcwill screen in
there. so I think im going to have to call it dead
#6 necrocia OFFLINE
necrocia
    Moonsweeper
  • 432 posts
Posted Sun Mar 17, 2019 4:50 AM
Have you tried to send a message to McWill on these forums? He will know what the issue is most likely.
#7 As3rox OFFLINE
As3rox
    Combat Commando
  • 5 posts
Posted Sun Mar 17, 2019 12:56 PM
lol I didn't want to bother him but will give it a shot thank you for you help and input
#8 arkleyjoe OFFLINE
arkleyjoe
    Space Invader
  • 21 posts
Posted Fri Mar 22, 2019 8:31 AM
I had a similar problem with my screen and it turned out I had attached D0 and D1 to the wrong pins on the Lynx. They were both 1 pin off where they should have been. I would check the wires and pins are all correct.
#9 As3rox OFFLINE
As3rox
    Combat Commando
  • 5 posts
Posted Fri Mar 22, 2019 8:35 AM
Thank you I will check later when I get home.
Regards
J
