How to get started with RespeQt?
11 replies to this topic
#1 6BQ5 ONLINE
6BQ5
    Chopper Commander
  • 229 posts
Posted Wed Mar 13, 2019 9:42 PM
I wanted to download RespeQt so I Google'ed it to find the program's homepage. The first result is Github and i don't see any "install.exe" file.
So ... what am I suppose to do with all these files? They look like source code files.
#2 RodLightning ONLINE
RodLightning
    Dragonstomper
  • 757 posts
Posted Wed Mar 13, 2019 11:18 PM
Check here for general info:  http://atariage.com/...io2pc-software/
I think the latest beta is 4.3:  Go to this thread for Windows and Mac binaries posted by JoSch:
http://atariage.com/...beta/?p=4219350
#3 6BQ5 ONLINE
6BQ5
    Chopper Commander
  • 229 posts
Posted Thu Mar 14, 2019 8:09 AM
So, the Atari Age forum is the official (unofficial?) distribution point for executable binary files?
#4 DrVenkman OFFLINE
DrVenkman
  • 3,984 posts
  • Back off, man! I'm a scientist.
Posted Thu Mar 14, 2019 8:31 AM
Here’s the deal. RespeQt was forked from the earlier AspeQt by user JoeyZ. He made a bunch of improvements and released versions r1 through r4. Then life happened, JoeyZ got sidetracked and the project stalled.
Others forked the github repository and made their own changed and improvements. JoSch added better printer emulation and ebiguy added Happy and Archiver support plus ATX file support.
The current “unofficial” r4.3 builds combine both of those sets of additional code. Binaries are in this forum.
#5 6BQ5 ONLINE
6BQ5
    Chopper Commander
  • 229 posts
Posted Thu Mar 14, 2019 8:46 AM
Wow, that’s a story fit for a TV drama series. :)
Thanks for the historical insight. I’ll give it a whirl later tonight after work. Then I still have to order some hardware to build a cable.
#6 RodLightning ONLINE
RodLightning
    Dragonstomper
  • 757 posts
Posted Thu Mar 14, 2019 10:29 AM
I just noticed the forum post I linked to RespeQt 4.3 is just the executable binary.  The complete set of windows files (docs, dll, etc) necessary to run can be downloaded with the previous release 4.2.1, courtesy of ebiguy, here:  http://atariage.com/...beta/?p=4150092
RespeQt.exe 4.3 binary can be copied over previous version.   RespeQT is click and run under Windows with no package installer required.
#7 JoSch OFFLINE
JoSch
    Moonsweeper
  • 496 posts
Posted Fri Mar 15, 2019 2:09 AM
Please see http://atariage.com/...-6#entry4238377 for newer binaries.
#8 Stormtrooper of Death OFFLINE
    Moonsweeper
  • 452 posts
Posted Wed Apr 17, 2019 8:46 AM
Hello, i downloaded version 1,2,3 and 4 òf RespeQT and want to use them on my Panasonic Toughbook CF-M34 (with touchscreen).
My CF-M34 had Windows XP pro with sp1 installed. 192MB ram memory, Pentium III 400Mhz and has a RS232 port. I want to use the old Sio2PC serial kabel connection.
Anyhow, RespeQT doesnt start at all. It gaves an error beforre starting.
Trying to solve the problem, i upgraded my Win XP install from SP1 to SP2. tried RESpeQT again. still doesnt work
Then upgrade from SP2 to SP3. Same thing. RespeQT refuses to start at all.
I then tried all 4 versions of RespeQT on the CF-M34 and then at another Panasonic Toughbook model. the CF-28 (1Ghz Pentium III and 512MB memory)
still no go.
Am I doing something wrong ?
Update: I tried R4 on my old Compaq D230 Desktop with serial port and it works ! Strangly, the Toughbooks run the same Windows XP version as my Compaq desktop.
Edited by Stormtrooper of Death, Wed Apr 17, 2019 9:27 AM.
#9 Kyle22 OFFLINE
Kyle22
  • 4,033 posts
  • Call my BBS! telnet://broadway1.lorexddns.net
Posted Wed Apr 17, 2019 5:41 PM
Have you tried installing more memory?
#10 Stormtrooper of Death OFFLINE
    Moonsweeper
  • 452 posts
Posted Thu Apr 18, 2019 12:38 AM
The max memory of the CF-M34 is 192 MB and the max of the CF-28 is 512MB. So, more memory is not an option. Min specs for using RespeQT is a Pentium 233Mhz MMX, so my CF-M34 and CF-28 are faster.
#11 DrVenkman OFFLINE
DrVenkman
  • 3,984 posts
Posted Thu Apr 18, 2019 5:56 AM
Don’t read too much into “minimum specs” for an open source project which itself was forked from an earlier open source project. Those specs are estimated at best.
As for specs, RespeQt r4 will run okay on a Raspberry Pi ZeroW, though the GUI is slow. An RPi2 or better is a much improved experience. The current forks implementing Happy and Archiver features are not reliable on the Pi Zero.
#12 Stormtrooper of Death OFFLINE
    Moonsweeper
  • 452 posts
Posted Thu Apr 18, 2019 7:25 AM
I tried the old AspeQT 1.0.0.0 preview 7 and it worked good. 38400 High Speed mode works 20% of the time. 19200 works most of the time. 57600 doesnt work good. (i guess I have to fix my 130XE sioport to higherspeed)
Settings are now in AspeqT
COM1
Handshake method : RI (non also works)
Writing to a blank ATR spartados floppy of 720K and 360K also worked good.
Boot Atari executable (XEX) file also works good.
So, for now, i will work with the old AspeQT.
Edited by Stormtrooper of Death, Thu Apr 18, 2019 7:32 AM.
Reply to this topic
