Atari800MacX R: to Internet?
Atari800Macx Internet
2 replies to this topic
#1 Ripdubski OFFLINE
Ripdubski
  • 1,307 posts
Posted Sat Mar 16, 2019 6:24 PM
I can't seem to connect to a BBS using Atari800MacX 5.0.1 on MacOS 10.14.3, though I think I have everything configured right.
Atari800MacX Settings:
R: patch enabled
R: path port 8888   (incoming, so doesn't matter I think)
Load 850 handler via outrun.sys (not sure if this step required)
Run terminal software
Issue ATDI site.address port  (ATDI per the Atari800MacX instructions - ATDT doesn't work either)
but I'm getting nothing back
What am I doing wrong?
Thanx
#2 Nezgar OFFLINE
Nezgar
  • 1,815 posts
Posted Sat Mar 16, 2019 9:07 PM
Loading the 850 handler might override the one patched in by the emulator. Have you tried skipping that?
Also, even before attempting to 'dial' out - at a minimum, you should get an "OK" response when typing AT then return in ASCII mode.
In ATASCII mode it would be AT followed by control-J or control-M...
#3 Ripdubski OFFLINE
Ripdubski
  • 1,307 posts
Posted Sun Mar 17, 2019 9:55 AM
Tried removing the 850 handler from boot.  Still not making progress.  I do not get an OK response from AT.
Also tagged with one or more of these keywords: Atari800Macx, Internet
