A MACHDOS Question.
6 replies to this topic
#1 DavidMil OFFLINE
DavidMil
    Dragonstomper
  • 835 posts
Posted Sat Mar 16, 2019 7:37 PM
I came across a disk with MACHDOS 3.7 and a few other files.  Is MACHDOS a European DOS?
The files I don't recognize are:
CPY800PL.EXE
ATASPRT (no extension)
MYDOSPLS ( no extension)
The machine will boot up to the MACHDOS DOS screen but nothing works (as in, the is no keyboard response from ANY key on the computer).  I
have to do a cold reboot to get the machine to respond again.  The MACHDOS.DOC file is corrupt and the only way I can look at it is using
DiskWizard.  None of the three unknown files will load in Basic or binary format.  I haven't looked at any of these three files in DiskWizard... yet.
Suggestions anyone?
Thanks,
DavidMil
#2 Kyle22 OFFLINE
Kyle22
  • 4,033 posts
  • Call my BBS! telnet://broadway1.lorexddns.net
Posted Sat Mar 16, 2019 8:11 PM
Manual: https://seriouscompu....7 - Manual.pdf
Fox-1 has it here: http://atari.fox-1.n.../mach-dos-3-7a/
File: Attached File  MachDos-3.7a-130XE.atr   90.02KB   16 downloads
Hope this helps.
#3 DavidMil OFFLINE
DavidMil
    Dragonstomper
  • 835 posts
Posted Sat Mar 16, 2019 9:51 PM
After downloading the manual (thank you Kyle22)  and finding a good download of MACHDOS ver. 3.7, I have discovered
that all the files on my disk are the same as the downloaded version with the exception of the three additional files I had listed
above.  So, anyone have any idea what they might be?  I'm going to run DiskWizard on them to make sure the files are good, or
try and repair them if not.
DavidMil
#4 Kyle22 OFFLINE
Kyle22
  • 4,033 posts
Posted Sat Mar 16, 2019 10:06 PM
Not including your earlier offending files, is the MachDOS disk from the link I sent to you working?
#5 _The Doctor__ OFFLINE
_The Doctor__
    Flux Capacitor Master Craftsman
  • 6,767 posts
Posted Sun Mar 17, 2019 10:57 AM
Why not make an ATR/ATX and post it up for a look-see
#6 DavidMil OFFLINE
DavidMil
    Dragonstomper
  • 835 posts
Posted Sun Mar 17, 2019 11:56 AM
No, I got the MACHDOS download from the internet.  The one I downloaded didn't have the 130XE after it.
I have downloaded your 130XE version also, and they do look alike.  Again, Thank you.
The problem is that the files all appear to be corrupt.  I'm working on them though.  If I can get anything I will most definitely post 'em.
David
#7 1050 OFFLINE
1050
  • 1,104 posts
Posted Tue Mar 19, 2019 12:40 AM
The beauty of the ATR image idea first is not to have
corrected files. You might not know which end of the
gun to look at to put it in a manner that I hope is
not too offensive to you. And certainly no offense is
intended here, just the point that you might trample
the roses so bad it's not a rose garden anymore.
In any event an ATR image will capture exactly what is
there now without your possible and not even needed
missteps in "correcting" the files as is.
The truth is "as is" always, we ask for the truth.
A DCM file made of the disk would be of equal value as
the asked for unaltered ATR. DCM is for all intents
and purposes a sector copier that has it's data
compressed and turned into a common Atari file
format. It cares nothing about fixed or not fixed
files either, just raw sector for sector imaging.
