+slx Posted March 17, 2019 Share Posted March 17, 2019 I'm trying to use a real KoalaPad as an input device for Altirra through an original AtariAge/pixelspast Stelladaptor. I can get the buttons to work (mapping to gamepad buttons 1 and 2) but can't find the right input mappings for the tablet part which according to the documentation should read as PADDLE(0) and PADDLE(1). I have tried all the Joystick 1-4 V and H mappings as well as the POV joystick but always get 228 as an output and no response on any touches to the KoalaPad. It should basically connect the same way as standard Atari paddles. I have tried the settings from this thread but to no avail (output 228 for both paddles). (KoalaPad is verified to work on real hardware.) Quote Link to comment Share on other sites More sharing options...
Irgendwer Posted March 17, 2019 Share Posted March 17, 2019 (edited) (Misinterpret the question. Sorry.) Edited March 17, 2019 by Irgendwer Quote Link to comment Share on other sites More sharing options...
phaeron Posted March 17, 2019 Share Posted March 17, 2019 First step is to open Input > Input Setup and check that the paddle inputs are coming through. This dialog shows the inputs that are coming from the Windows gamepad API, so it is before any of the input mappings. They are most likely coming through as left analog stick, but that may not be the case and regardless you will want to turn the dead zone down to zero. Assuming it is coming through as left analog stick, Joy Axis 1H/1V would be the correct sources to use in the emulator. The POV hat isn't it since it's just a digital directional input like the CX40 joystick. It is named because it used to be mapped to a small clicky directional disc at the top of the joystick which could be used to turn the camera (POV = Point of View). These days, gamepads frequently map their D-pads to it. As for why the emulator doesn't provide the mappings by default, historically all of the default mappings used to be automatically copied into the registry and appear in the active list. That would get cluttered very quickly with the combinations of host and emulated controllers. Current versions have a separate Preset list that can have mappings separate from the default list, so I've started adding some there. But even in this case, mapping analog inputs to the pad in absolute mode would be uncommon -- typically the input device would either be a mouse in screen mapped mode or a gamepad stick in relative mode, which would use a different mapping. 1 Quote Link to comment Share on other sites More sharing options...
+slx Posted March 18, 2019 Author Share Posted March 18, 2019 First step is to open Input > Input Setup and check that the paddle inputs are coming through. This dialog shows the inputs that are coming from the Windows gamepad API, so it is before any of the input mappings. They are most likely coming through as left analog stick, but that may not be the case and regardless you will want to turn the dead zone down to zero. Assuming it is coming through as left analog stick, Joy Axis 1H/1V would be the correct sources to use in the emulator. Thanks phaeron! I see nothing at all on the input setup, not even the triggers (which work as buttons 1 and 2), stick indicates left/up, other than that no joy It's been quite some time but I recall paddles working with that Stelladaptor. Will try on another machine (this one is the prepackaged Altirra under Wine on a Mac but I have access to a Window installation as well.) Update: same results on a windows machine. Tried paddles and they show although I get 228 through about half of the turn. Quote Link to comment Share on other sites More sharing options...
phaeron Posted March 19, 2019 Share Posted March 19, 2019 Update: same results on a windows machine. Tried paddles and they show although I get 228 through about half of the turn. I'm not sure what you mean -- are you saying that connecting paddles to the Stelladaptor works, while the KoalaPad doesn't? If you still can't get anything in input setup for it, then you'll have to go up one level to Windows itself. In Windows 10, go to Control Panel, Game Controllers. This will produce a list with all game controllers, and selecting Properties will open a sub-window where you can see all input: Controller input has to be visible in this path for Altirra to see it. If you can't get the inputs to come through here, then you'll have to double-check the Stelladaptor's installation procedures and documentation. Another thing to check is whether the Stelladaptor shows up in the Game Controller drop down on the input map editor in Altirra. This field defaults to "Any" and will list other controllers in case you want to restrict the input map to a specific controller. If no specific adapters are shown here then the emulator isn't seeing the controller. As for paddles only working over half the range, that would be accurate for the Atari 8-bit. The resistances and timing work out such that POKEY's full 0-228 range only covers about half of the CX30 paddle range. 2 Quote Link to comment Share on other sites More sharing options...
+slx Posted March 19, 2019 Author Share Posted March 19, 2019 Thanks Phaeron! I will check that out. Quote Link to comment Share on other sites More sharing options...
