Atariwriter Plus and Spartados Side2
Atariwriter Spartados side2
7 replies to this topic
#1 joeatari OFFLINE
joeatari
    Space Invader
  • 10 posts
Posted Mon Mar 18, 2019 12:18 AM
I have a new Side2 cart and would like to run Atariwriter Plus from a partition on the cart.  I am unfamiliar with Spartados.  I have tried starting with the X command, but it hangs.  I assume there is a memory problem, and that there is some configuration that needs to be done to get this to run.  The computer is a stock 130XE.  I have three partitions on the cart/compact flash, and the first is set as bootable.
#2 flashjazzcat OFFLINE
flashjazzcat
  • 14,494 posts
Posted Mon Mar 18, 2019 12:58 AM
The 128k version of Atariwriter Plus uses all the extended RAM on a 130XE, IIRC, so you'll need to run SDX in 'USE OSRAM' mode, which will make it impossible to use the SIDE driver. If there's a version of the word processor which doesn't touch extended memory, use that or get an U1MB. I ran Atariwriter Plus (with copy protection patched out) with SDX on a 130XE for years in the 90s, and presumably I used the 64K version or ran SDX in OSRAM.
#3 joeatari OFFLINE
joeatari
    Space Invader
  • 10 posts
Posted Mon Mar 18, 2019 1:22 AM
I have a U1MB on the way together with a VBXE and stereo pokey upgrade.  I have written journals for years in Atariwriter Plus, but I may switch to Last Word if I like it.  My journals are very large and use much of the 130XE memory.
For many years I have used MyDos, Atariwriter Plus, and Bobterm almost exclusively on a stock 130XE.  I have a lot to learn.
Thanks for the quick response!
Joe
#4 flashjazzcat OFFLINE
flashjazzcat
  • 14,494 posts
Posted Mon Mar 18, 2019 1:30 AM
You emailed me as well, I think? If I remember more info, I will add it here. :)
#5 _The Doctor__ OFFLINE
_The Doctor__
    Flux Capacitor Master Craftsman
  • 6,726 posts
Posted Mon Mar 18, 2019 5:49 AM
is there a way to get SDX to use banks above the normal XE banks... I thought there was such a config, or it would be useful if it were.... I have vague recollection of a function to reserve banks to be used in conjunction with ramdisks etc...  there was something about getting the most of the banks also in the same vein.
If it's not standalone and only functions as part of such... How cool would it be to break that out into a standalone configuration possibility!!
Edited by _The Doctor__, Mon Mar 18, 2019 5:50 AM.
#6 flashjazzcat OFFLINE
flashjazzcat
  • 14,494 posts
Posted Mon Mar 18, 2019 7:01 AM
In short: you need a machine with more than 128K of RAM.
#7 _The Doctor__ OFFLINE
_The Doctor__
  • 6,726 posts
Posted Mon Mar 18, 2019 11:51 AM
an old guide to using AtarWriter Plus with Sparta DOS and Sparta DOS X
If you have a 130XE or 800XL computer, using AtariWriter Plus is straightforward.
Simply insert the AtariWriter Plus diskette into Dl:
then type
D1:X /C AP.OBJ
If you have more than 128K of ram in your computer, the procedure is a bit more complex.
You will need to prepare a boot floppy for AtariWriter Plus with a modified config system.
FORMAT a disk in SpartaDOS format and create a text file named CONFIG.SYS file on it.
The these lines must be in the CONFIG.SYS file...
USE OSRAM
DEVICE SPARTA OSRAM
DEVICE SIO
DEVICE ATARIDOS.SYS
another config...
USE OSRAM
DEVICE SPARTA OSRAM
DEVICE SIO
DEVICE ATARIDOS.SYS
try one then the other..
You may use the rest of this disk for anything you choose. To run AtariWriter Plus,
boot the computer with this boot floppy in Dl:.
Remove this diskette and insert the AtariWriter Plus diskette.
Then type D1:X /C AP.OBJ
You may use a ramdisk at D3: - D9: with Atariwriter Plus, but you won't be able to get
a directory of the ramdisk from the program. You can use this for temporary storage.
Somewhere there was a hack to allow an extended menu to make the other disks accessible
with some other stuff. It may be in my piles of disk somewhere.
You can put this on your boot disk or your boot manager.
With latter Sparta DOS versions there may become a way to control nbanks to achieve this and other goals with more flexibility.
Edited by _The Doctor__, Mon Mar 18, 2019 12:17 PM.
#8 _The Doctor__ OFFLINE
_The Doctor__
  • 6,726 posts
Posted Mon Mar 18, 2019 12:16 PM
not much difference in the newer pdf...
E.7
Using AtariWriter Plus with SDX
With a stock 130XE or 800XL computer, using AtariWriter Plus is straightforward. Simply insert the AtariWriter Plus disk into D1: and type 'D1:X AP.OBJ'.
If you have more than 128 KiB of RAM in your computer, the procedure is a bit more complex. You will need to prepare a boot floppy disk for AtariWriter Plus in SD format and create a
CONFIG.SYS file on it. These lines must be in the. CONFIG.SYS:
USE OSRAM
DEVICE SPARTA OSRAM
DEVICE SIO
DEVICE ATARIDOS.SYS
The rest of this disk for anything you choose. To run AtariWriter Plus, boot the
computer with this boot floppy disk in D1:. Remove the disk and insert the AtariWriter
Plus disk and then type 'D1:X AP.OBJ'.
You may use a ramdisk at D3: - D9: with AtariWriter Plus, but you won't be able to get a
directory of the ramdisk from the program. You can still use this for temporary storage.
Note:
The above hints for AtariWriter Plus have been kept for historical reasons in this
guide and still apply. For up to date word processing please check 'The Last Word'
available from http://atari8.co.uk/as it especially supports SDX features.
You can put this on your boot disk, your cart using the SDX imager, or a boot manager.
Also tagged with one or more of these keywords: Atariwriter, Spartados, side2
