Calculating time
26 replies to this topic
#1 JPC531 OFFLINE
JPC531
    Combat Commando
  • 3 posts
Posted Mon Mar 18, 2019 11:07 AM
I just started playing around with Extended Basic to see what the TI-99/4A can do.
I made a simple program where I want to see how many words can be entered in one minute, but I do not see any Basic commands for time.
On the TI-99 do you just have to estimate based on how long each instruction takes to run?  Not sure how I would do that since the number of words would be different every time it is run.
How do you handle a time count down?
#2 Vorticon OFFLINE
Vorticon
  • 3,726 posts
Posted Mon Mar 18, 2019 11:25 AM
This will be near-impossible to do without assembly language support to access the 9901 timer.
To clarify, will you be timing at rest or in motion? There might be some complicating factors at play here  ;)
#3 HOME AUTOMATION OFFLINE
HOME AUTOMATION
    Moonsweeper
  • 428 posts
Posted Mon Mar 18, 2019 11:40 AM
TI-99-4A-CLOCK-Capability-v1.10.pdf
I remember a program called 4aclock... I think it was in TI BASIC... can't locate.
Edited by HOME AUTOMATION, Mon Mar 18, 2019 11:59 AM.
#4 Asmusr OFFLINE
Asmusr
  • 3,110 posts
Posted Mon Mar 18, 2019 12:52 PM
Isn't there a VDP interrupt counter that you can peek (>83d6)?
#5 Vorticon OFFLINE
Vorticon
  • 3,726 posts
Posted Mon Mar 18, 2019 1:26 PM
Yes, the screen time-out counter. How long would it take for it to go from 0 to >FFFF? That would be the maximum time interval that could be counted. Problem is there is no POKE function in XB, so one would not be able to reset the timer before starting the word count.
#6 sometimes99er OFFLINE
sometimes99er
  • 4,225 posts
Posted Mon Mar 18, 2019 1:38 PM
You can set a sprite in motion and then read its position to get time.
#7 Vorticon OFFLINE
Vorticon
  • 3,726 posts
Posted Mon Mar 18, 2019 3:54 PM
Great idea! Didn't think of that.
#8 Lee Stewart ONLINE
Lee Stewart
  • 3,966 posts
Posted Mon Mar 18, 2019 4:07 PM
The screen timeout counter steps by 2 at each interrupt, so 32768/3600 = 9.1 minutes.
In XB, you use CALL LOAD() to poke byte values into RAM.
...lee
#9 JPC531 OFFLINE
JPC531
    Combat Commando
  • 3 posts
Posted Mon Mar 18, 2019 5:53 PM
...lee
Timing would be in motion. I do want to try assembly, but I wanted to see what is possible in Basic first.  I think I can handle a peek and poke though.
At least I know that I didn't miss anything easy :)
#10 JPC531 OFFLINE
JPC531
    Combat Commando
  • 3 posts
Posted Mon Mar 18, 2019 5:55 PM
Using sprite motion is a great idea.  I could not think of anything that was consistent over time.  I'll try that.  Thanks
#11 RXB OFFLINE
RXB
  • 3,583 posts
Posted Mon Mar 18, 2019 7:27 PM
GKXB,  Super XB have a CALL LOAD or CALL PEEK,
Problem is both require CALL INIT to access.
RXB does not require a CALL INIT to use CALL LOAD or CALL PEEK this really speeds up access and ez to use.
#12 Vorticon OFFLINE
Vorticon
  • 3,726 posts
Posted Mon Mar 18, 2019 10:28 PM
Can you LOAD into CPU RAM? I thought you could only use CALL LOAD for the expansion RAM to directly load a value.
EDIT: Never mind. You can
#13 Vorticon OFFLINE
Vorticon
  • 3,726 posts
Posted Mon Mar 18, 2019 10:51 PM
...lee
Actually using the timeout counter won't work because it keeps getting reset while a program is running and only starts counting when the computer is idle. A quick test in Classic99 and its debugger confirmed that.
#14 Vorticon OFFLINE
Vorticon
  • 3,726 posts
Posted Mon Mar 18, 2019 10:53 PM
I was being obnoxious here. I was referring to time dilatation with motion  :grin:
#15 Lee Stewart ONLINE
Lee Stewart
  • 3,966 posts
Posted Tue Mar 19, 2019 6:38 AM
I actually was not suggesting using the timeout counter—just answering the question.  The timeout counter is incremented by 2 at every VDP interrupt.  It is reset only when a keystroke is detected by KSCAN, the console’s keyboard routine.
...lee
#16 Vorticon OFFLINE
Vorticon
  • 3,726 posts
Posted Tue Mar 19, 2019 6:59 AM
In my test, the timer kept getting reset while a short program was running even without any key presses...
#17 Asmusr OFFLINE
Asmusr
  • 3,110 posts
Posted Tue Mar 19, 2019 10:04 AM
Yes that's also what I found.
I then tried for fun to see if I could add my own ISR hook and counter using pokes only. It seems to be working but for some reason it's counting too slowly.
XAS99 CROSS-ASSEMBLER   VERSION 1.7.2
**** **** ****     > isr.a99
0001               	aorg >83b8
0002 83B8 05A0  34 	inc @cnt
     83BA 83BE
0003 83BC 045B  20 	rt
0004 83BE 0000     cnt data 0
0005
10 CALL INIT
15 REM CREATE THE ROUTINE
20 CALL LOAD(-31816,5,160,131,190,4,91)
25 REM HOOK INTO ISR
30 CALL LOAD(-31804,131,184)
35 REM READ COUNTER
40 CALL PEEK(-31810,MSB,LSB)
50 TIME=(MSB*256+LSB)/60
60 PRINT INT(TIME)
70 GOTO 40
#18 Lee Stewart ONLINE
Lee Stewart
  • 3,966 posts
Posted Tue Mar 19, 2019 11:49 AM
My bad.  :P   I just checked the console code and, indeed, the VDP screen timeout timer, >83D6, is reset for each and every Basic statement executed.  Sorry about that.
However, what I said about KSCAN still obtains for any ALC (and TI Forth, fbForth and, I believe, TurboForth and Camel99 Forth) program that does not explicitly change >83D6, i.e., >83D6 will not be reset until a new keystroke is detected by KSCAN.
...lee
#19 Tursi OFFLINE
Tursi
  • 5,638 posts
  • HarmlessLion
Posted Tue Mar 19, 2019 5:11 PM
0001               	aorg >83b8
     83BA 83BE
0005
10 CALL INIT
35 REM READ COUNTER
60 PRINT INT(TIME)
70 GOTO 40
Print scrolls the screen, and scrolling the screen takes more than one frame in BASIC/XB. During the screen scroll, interrupts are blocked. You can see it happen with a moving sprite, too.
#20 Vorticon OFFLINE
Vorticon
  • 3,726 posts
Posted Tue Mar 19, 2019 6:03 PM
Learn something everyday :)
#21 RXB OFFLINE
RXB
  • 3,583 posts
Posted Tue Mar 19, 2019 6:05 PM
Try RXB:
10 CALL INIT
35 REM READ COUNTER
50 CALL HPUT(INT((MSB*256+LSB)/60)
60 GOTO 40
#22 1980gamer OFFLINE
1980gamer
    Dragonstomper
  • 986 posts
Posted Tue Mar 19, 2019 8:01 PM
Are you talking about the screen FREEZE for a split second?
Or the output issues?
25
25
25
25
21
25
25
25
26
26
Edited by 1980gamer, Wed Mar 20, 2019 3:29 AM.
#23 LASooner OFFLINE
LASooner
    Moonsweeper
  • 401 posts
Posted Tue Mar 19, 2019 8:44 PM
0001               	aorg >83b8
     83BA 83BE
0005
10 CALL INIT
35 REM READ COUNTER
60 PRINT INT(TIME)
70 GOTO 40
This works in Classic99, but JS99er.net doesn't like it
#24 Tursi OFFLINE
Tursi
  • 5,638 posts
  • HarmlessLion
Posted Wed Mar 20, 2019 3:04 AM
I do too, that's why it's so much fun to come here ;)
#25 Tursi OFFLINE
Tursi
  • 5,638 posts
  • HarmlessLion
Posted Wed Mar 20, 2019 3:16 AM
I didn't run the code, so I guess the freeze. ;) If you're running interrupts in XB and you scroll the screen, it will miss a few frames. ;)
I find it easiest to see with a sprite - you can visibly see the motion stutter:
10 CALL SPRITE(#1,65,3,100,100,0,50)
20 INPUT A$
30 PRINT : : : : : : : : : :
40 GOTO 20
