pc gameport adapters
16 replies to this topic
#1 bohoki OFFLINE
bohoki
  • 1,579 posts
Posted Mon Mar 18, 2019 1:38 PM
i know this is not the right forum to be selling but i know you guys let me slide
i want to let you all know i am working on a batch its going to take me some time just hang in there.
i got all the parts rounded up i dont have anymore of the little pushbuttons i use for a start but i have 10 clicky buttons from mice i'll use.
at least 5 are spoken for and i'm making 10 i'll contact all you that emailed me when they are done.
they will be $13 shipped anywhere in the usa
#2 bikeguychicago OFFLINE
bikeguychicago
  • 1,349 posts
Posted Mon Mar 18, 2019 2:25 PM
I'd be interested in one once they are ready. In fact, I picked up a PC game-port game-pad at Goodwill recently with this in mind :)
Edited by bikeguychicago, Mon Mar 18, 2019 2:26 PM.
#3 ave1 OFFLINE
ave1
    Dragonstomper
  • 525 posts
Posted Mon Mar 18, 2019 9:24 PM
Nice to see more of these being made! Great :)
#4 0078265317 OFFLINE
0078265317
  • 6,707 posts
Posted Thu Mar 28, 2019 3:04 PM
https://www.ebay.com...redirect=mobile
Would this work if I just got a 9 pin to 15 pin adapter?
#5 bohoki OFFLINE
bohoki
  • 1,579 posts
Posted Thu Mar 28, 2019 6:27 PM
the ibm/apple one may work with the adapter but they are very old and their potentiometers are probably very worn and dirty
ive had much trouble with the plug ends i got 2 females that solder just doesnt stick to the contacts so i only made 9 so there is not any available for people who were not waiting
i will not be making any more untill i find better quality plug ends
#6 0078265317 OFFLINE
0078265317
  • 6,707 posts
Posted Thu Mar 28, 2019 8:00 PM
You already sold me one.
#7 Protestari OFFLINE
Protestari
    Dragonstomper
  • 937 posts
Posted Mon Apr 8, 2019 2:20 PM
Hi, are these the adapters that dont include a Keypad? I would take two.
#8 Kaboomer OFFLINE
Kaboomer
    Chopper Commander
  • 139 posts
Posted Mon Apr 8, 2019 9:22 PM
Definitely interested in 2 of these! :)
#9 ultrasteve OFFLINE
ultrasteve
    Chopper Commander
  • 162 posts
Posted Fri Apr 12, 2019 2:12 AM
Sending you a PM!
#10 Alaskaman OFFLINE
Alaskaman
    Combat Commando
  • 1 posts
Posted Sat Apr 13, 2019 11:39 PM
Very interested in 2 of these! :)
#11 bohoki OFFLINE
bohoki
  • 1,579 posts
Posted Tue Apr 23, 2019 3:28 PM
if anyone wants to make their own with an extension cable and 2 breakout boards
the reason i use a jumper between pins 4 and 5 is i found some kraft joysticks used pin 5
also if you want to use buttons 3 and 4 of a pc joystick those are pins 10 and 14 of the joystick so you could run a wire from them to 5200 pins 14,13
Edited by bohoki, Tue Apr 23, 2019 3:43 PM.
#12 ave1 OFFLINE
ave1
    Dragonstomper
  • 525 posts
Posted Fri Apr 26, 2019 1:34 PM
bohoki- I used these breakout boards on a couple episodes of my Ytube classic gaming presentations. Hmmm, maybe I'll do an episode on wiring one of these up for the 5200 :)
#13 Protestari OFFLINE
Protestari
    Dragonstomper
  • 937 posts
Posted Mon May 6, 2019 10:34 AM
Hi Bohoki, Did you get my PM, thanks.
#14 bohoki OFFLINE
bohoki
  • 1,579 posts
Posted Mon May 6, 2019 12:12 PM
i just do not have confidence in the blue plugs from china there may be good ones and bad ones but its impossible to know until they arrive
the problems i run into is sometimes the solder cups are not well tinned and solder just wont stick
another problem is the holes on the female side are a bit too small for the 5200 pins and can break them off when you pull the plug out
another problem is the little contacts inside can be oxidized (super random) and not make a good connection
the male pins seem to not have locking bulges and can push right out the back
the last good ones i made were those silver housing ones i found someone with some old stock plugs
its super annoying to go through all the work then find a bunch that have problems sure i run into a couple where i put the wrong wire somewhere but when it fails and i did nothing wrong its just not worth it i try to keep the costs low but having to deal with just one return repair and resend puts me in the red
also 5200 is not my favorite system i'm a commodore 64 guy
#15 sramirez2008 ONLINE
sramirez2008
  • 2,944 posts
  • Stella Foreva
Posted Mon May 6, 2019 4:38 PM
...also 5200 is not my favorite system i'm a commodore 64 guy
:-o blasphemous  :-o
jk...my first home computer was C64.
#16 Swami OFFLINE
Swami
  • 2,869 posts
Posted Thu May 9, 2019 12:00 PM
If you don't like the idea of trashing the cord ends of an extension cord or you think the wires are too thin, there is this as well (18 guage vs 24)
https://www.amazon.c...coding=UTF8&me=
I'm not sure where bohoki gets the cord he uses or how many different colors there wires are. Some electronics cords on ebay/amazon with nine wires come with pairs of wires the same color, which kind of defeats the purpose.
#17 bohoki OFFLINE
bohoki
  • 1,579 posts
Posted Thu May 9, 2019 3:05 PM
with the breakout boards you should not have to cut into an extension cord but it must be one of the extension cords that have the plastic ends not metal clad cause the metal shielding put the contacts out of reach for the 5200
you can see in my above pics i just use old solid wire eithernet cord i got when a school near me demolished a temporary solid wire is easy to strip and solder but is more fragile and subject to flex breaking
i wish i stuck to a standard but all my batches have different colors to the contacts i used to try to keep the orange be the +5 and the green be the button ground but i gave up and just do my batches however i make the first one  by having 8 wires it allowed me to run the 2 unused to the start button which i always left the brown and white brown
