Today (2019) what drive emulator would you recommend for 800XL?
35 replies to this topic
#1 as4VP OFFLINE
as4VP
    Combat Commando
  • 8 posts
Posted Tue Mar 19, 2019 9:46 AM
I have an Atari 800xl (have the original 1050 drive and 410 Program Recorder <- repaired it and it works again)  Anyhow, I'd like a drive emulator.
Since there are a few different drive emulators for Atari 8bit.  Today, 2019, what would you folks recommend?
I was leaning towards an S-Drive MAX because of the screen.  But I'd value your opinion.
Additionally, I live in the USA where we have 60Hz voltage.  Is that a problem since most of these drives are coming from Europe where they have 50Hz voltages?
Thanks.
#2 slx OFFLINE
slx
  • 1,853 posts
Posted Tue Mar 19, 2019 10:58 AM
Whether you prefer SIO2SD or SDriveMax also depends on whether you prefer buttons (SIO2SD) or a touchscreen (SDriveMax). Be aware that the touchscreen is not the type found on your typical smartphone, more of a "push screen"like on a Palm and easier to use with a stylus than with your fingers.
SDriveMax is  easier to build yourself as it requires minimal soldering, especially if you use Chinese clone parts and use it as the only device on the SIO bus, obviating the need for the extra chip and resistors.
SIO2SD is a bit cheaper to buy, especially if you take the "bare" version and make a case yourself. The larger screen on SDriveMax certainly makes operation a bit more intuitive than the "forward/back/shift" concept of SIO2SD.
Mains voltage is not a concern as both are powered from the SIO bus and even if you decide to run SDriveMax from a USB PSU those are generic and available everywhere.
#3 kheller2 OFFLINE
kheller2
  • 1,375 posts
Posted Tue Mar 19, 2019 11:35 AM
I thought I read somewhere that the Max requires a USB power supply and can not run properly using SIO power.  Can someone confirm?
#4 JR> OFFLINE
JR>
    Moonsweeper
  • 401 posts
Posted Tue Mar 19, 2019 11:47 AM
Have never had a problem running mine on SIO power.
#5 bfollowell OFFLINE
bfollowell
    Chopper Commander
  • 230 posts
Posted Tue Mar 19, 2019 11:53 AM
Well, there are two main stand-alone devices and they have already been mentioned; the SIO2SD and the S-Drive Max. I personally prefer the SIO2SD, but they are both excellent devices and you really can't go wrong with either. If you have a PC close, there's also the SIO2PC-USB that you can use to connect your 800XL to your PC and access disk image files stored there, basically turning your PC into a giant drive emulator. Any of the three would fulfill your basic needs of Atari disk drive emulation. You just need to look at all the other available features of each, as well as the pros and cons of each, and decide which is right for you.
Personally, I started with an AtariMax SIO2PC-USB, then picked up an Ultimate Cart SD multi cart. My next purchase will likely be one of Lotharek's excellent SIO2SD devices.
#6 Mclaneinc OFFLINE
Mclaneinc
    Retro Madman
  • 6,675 posts
Posted Tue Mar 19, 2019 12:17 PM
Quite happy here with the USB PC idea, not had problems with it but obviously it needs a supported PC type platform for the loader..
For stand alone I'd probably think about the MAX but in terms of keeping it a little cheaper and not bothered about super fancy screens the the SD would be fine...In terms of drive emulation I believe they are all very good..
#7 Larry OFFLINE
Larry
  • 4,109 posts
Posted Tue Mar 19, 2019 12:59 PM
The advantage of APE or RespeQt as a drive emulator is the power of a Windows PC.  (I'm not sure about Mac use with RespeQt, but APE is Windows only.)  Scrolling and clicking a mouse instead of pressing buttons to scroll on an itty-bitty LCD or a bunch of key presses is a great benefit to me.  Of course, not for everyone, but certainly offers easy navigation of images plus other features such as printer emulation, easy transfer to/from a PC.  Need not be a huge screen; an old, small laptop with a 486 running Windows 95 should work fine with APE.  I've personally run APE on a Pentium 50 MHz with Win 97 on a 5" laptop. (It is more useful on something like a 10" laptop since you have more room on the screen.)
Here's the Atarimax homepage (scroll down for APE info)
https://www.atarimax.com/
And here are a couple of pics of my setups.  Of the SIO2SD devices, I think that Lotharek has the nicest. Note the open folder of ATR images -- mouse click easy access to hundreds of images.
-Larry
#8 6BQ5 OFFLINE
6BQ5
    Moonsweeper
  • 287 posts
Posted Tue Mar 19, 2019 2:00 PM
How did you get the video output of your 800 XL to appear on your Windows machine?
#9 bfollowell OFFLINE
bfollowell
    Chopper Commander
  • 230 posts
Posted Tue Mar 19, 2019 3:30 PM
It looks like he's probably feeding it in through an ATI Wonder TV card, or something along those lines.
#10 Larry OFFLINE
Larry
  • 4,109 posts
Posted Tue Mar 19, 2019 4:50 PM
Yes, ATI All-in-Wonder graphics & capture card. This is the best system I've found for using the Atari and PC. But newer versions were aimed primarily as TV display and used a video buffer that destroyed the usefulness with computer/gaming systems.
#11 Rybags OFFLINE
Rybags
    Gridrunner
  • 16,141 posts
Posted Tue Mar 19, 2019 5:55 PM
The most "power" and versatility comes from the PC based ones such as APE and Respeqt but the downside is you have a whopping great PC or laptop tethered to your Atari.
My standalone choice is SIO2SD but I'd not mind a SIO2BT type solution if it could be used with a small phone.
One of the highest criteria for me re the standalone devices is that you have to be easily able to change disk image without needing to involve the Atari in the process, otherwise multi disk games could be unusable.
All these devices though take a back seat thanks to the likes of IDE +2 and SIDE* - but they still have the advantage of usually being easier to get files and images across from a PC.
#12 bfollowell OFFLINE
bfollowell
    Chopper Commander
  • 230 posts
Posted Tue Mar 19, 2019 6:06 PM
I keep seeing mention of the Side2 cartridge. Help me to understand what it offers that make it so great.
I see mention of hard drive access, but I have no interest in running a hard drive with my 8-bit. That being the case, is there any other reason that it might interest me.
I just want to better understand what it is and what it does.
Thanks.
#13 Rybags OFFLINE
Rybags
    Gridrunner
  • 16,141 posts
Posted Tue Mar 19, 2019 6:12 PM
Advantage of the IDE class devices is speed - typically SIO devices will do a little over 1K/second standard speed and 4 or 5 times that in turbo speeds.
IDE types generally do 30K or better.
#14 DrVenkman OFFLINE
DrVenkman
  • 4,077 posts
  • Back off, man! I'm a scientist.
Posted Tue Mar 19, 2019 6:32 PM
Thanks.
If you have a SID2 cart *and* an Ultimate 1MB board in your Atari, Flashjazzcat's BIOS lets you access ATR disk image files stored on a FAT partition of the CF card in the SIDE2 cartridge. You can mount multiple disk images in each of several disk drive slots (D1:, D2: ...) and then cycle them by pressing the external button on the SIDE2 cart. So, for instance, you can mount a two-disk game in two slots, and when the game tells you to insert the second disk, for instance, you can tap the button to swap the two disk images and the game now has access to that second disk image, now rotated to the D1: slot. Since this functionality also lets you write to ATRs stored on the FAT partition, you can do the same trick with single-disk games that use a second disk to save your progress. Put the game disk in D1:, your save disk in D2:, then swap in your save disk with a tap of the button, and then a second tap will rotate the disks again, putting the original back into the D1: slot ... You can rotate as many disks as you have mounted, though admittedly it can be tricky if you have more than two or three. :)
It's all very easy to use and elegant, and makes the U1MB/SIDE2 combo a must-have for me as a modern hobbyist using my classic Atari hardware. My "daily driver" Atari for 2 years was an 800XL with U1MB + SIDE2 cart, then I installed another U1MB in a 1200XL I restored to working condition; that machine was my daily driver for another 18 months or so until I built my 1088XEL.
#15 bfollowell OFFLINE
bfollowell
    Chopper Commander
  • 230 posts
Posted Tue Mar 19, 2019 6:40 PM
OK, thanks for explaining that to me. Now I think I understand a little better.
While I am slowly gaining interest in the Ultimate 1Mb Upgrade, I really don't think I'd be interested in the Side2 Cartridge. While neat, I already have other devices that perform the same functions.
I'd love to have a 1088XEL as well, but I can't afford to spend $500 to $600 (or more) on one when I already have an 800XL that, with the upgrades, I have and have planned, will do all I need it to. They are definitely cool though.
Thanks again for the explanation.
#16 SS OFFLINE
SS
  • 6,321 posts
Posted Tue Mar 19, 2019 7:17 PM
I use my SIO2SD more than any of the other SD card devices that I own.
However, if I were purchasing one today, I would be inclined to buy Lotharek's new (and somewhat crudely named) SIO2SD variant. It has a larger display than the original SIO2SD model and I really like the look of its clear casing.
https://lotharek.pl/...tail.php?id=243
#17 slx OFFLINE
slx
  • 1,853 posts
Posted Tue Mar 19, 2019 7:56 PM
While this „PCB sandwiched between two pieces of plexiglass“ is quite popular now and easy to build, it leaves you with a dust catcher that is hard to clean.
The new display is larger but as in larger letters, not more characters on screen.
My son uses a SIO2SD which sometimes stays on for months, so durable it is.
I did forget SIO2BT in my prior post, that‘s quite elegant, too, as it allows to use any old Android phone or tablet to host the files.
Gesendet von iPhone mit Tapatalk
#18 bfollowell OFFLINE
bfollowell
    Chopper Commander
  • 230 posts
Posted Tue Mar 19, 2019 8:21 PM
Actually, no, it says the new display is 2x20, as opposed to the 2x16 of the current model, so it is 4 characters wider than the original.
I think I'm going to go throw some money at Lotharek!
Edited by bfollowell, Tue Mar 19, 2019 8:25 PM.
#19 _The Doctor__ OFFLINE
_The Doctor__
    Flux Capacitor Master Craftsman
  • 6,930 posts
Posted Tue Mar 19, 2019 8:37 PM
you can use longer displays on sio2sd as well. I have two of them but they are due for reprogramming....
#20 manterola OFFLINE
manterola
    Moonsweeper
  • 353 posts
Posted Tue Mar 19, 2019 8:50 PM
I thing the Sio device that end up using the most is a laptop with RespeQt and sio2pc. The reason is that most of the time I am trying something interesting I found here in the forum, a new app a new variation of a game, the new Plato, svg rendered, etc. So I need to start my PC anyways to update the files in the SD Card. So now I just connect the cable to the laptop and everything is easier and faster.
Don't get me wrong, sio2sd is a great amazing device, but in my case, having a laptop beside the Atari setup, makes the use of a PC much more convenient, and RespeQt is an amazing piece of software, you can swap disk, view the disk content, extract and add individual files, create new disk, load cassette images, and much more, with the convenience of a mouse and big screen.
Edited by manterola, Tue Mar 19, 2019 8:51 PM.
#21 256 colors ONLINE
256 colors
    Moonsweeper
  • 296 posts
Posted Tue Mar 19, 2019 10:52 PM
Lotharek SIO2SD
#22 TGB1718 OFFLINE
TGB1718
    Star Raider
  • 98 posts
Posted Wed Mar 20, 2019 5:37 AM
If you want to use RespeQt, don't forget it runs on a Raspberry Pi, I have a multi input monitor, composite video via a scart
is connected to the 130XE, VGA input connected to the Pi, all I have to do is switch inputs when I want to change a disk.
Saves having 2 screens and a tiny Pi.
I also have an SDrive-Max and think its great, can't comment on the SIO2SD
#23 Larry OFFLINE
Larry
  • 4,109 posts
Posted Wed Mar 20, 2019 6:23 AM
Have a picture of your setup?  The Pi sounds like an interesting option.
-Larry
#24 Stefan Both OFFLINE
Stefan Both
    Moonsweeper
  • 451 posts
Posted Wed Mar 20, 2019 12:09 PM
The Arduino doesn't need much current.
The touch-display however likes about
100...400mA (peak).
If your Atari PSU is still in good condition
and there is no other hungry device in
the chain - no worries at all.
However, there is another aspect.
If you draw the current from Sio,
and you power cycle your XL, you
switch off the SDrive-Max too.
That is (in my opinion) the main reason
to spend the device its own PSU.
I would prefer Lothareks Sio2Sd too.
It proofs it's relia/durability since years.
On the other hand, Sdrive-Max has Tape emulation
too. (or do I mix something up?)
Whatever your choice may be, it can't be wrong.
Stefan
#25 _The Doctor__ OFFLINE
_The Doctor__
  • 6,930 posts
Posted Wed Mar 20, 2019 12:54 PM
sdrivemax preferences for myself...
Just do yourself the favor and plug it in or use the battery option ;)    don't bother with sio power.
Yes it does tape emulation.
the device has really shaped up.
