inty-midi: convert MIDI files to IntyBASIC code
intybasic music midi
4 replies to this topic
#1 ppelleti OFFLINE
ppelleti
    Space Invader
  • 37 posts
Posted Sun Mar 24, 2019 6:59 PM
I have written a program which converts MIDI files into MUSIC lines which can be used in an IntyBASIC program.  Depending on the number of voices in the MIDI file, it can generate code either for the Intellivision alone, or for the Intellivision with ECS.  MIDI Program Change messages can be used to select among the four instruments that IntyBASIC supports.  I have also attempted to support drums (on MIDI Channel 10).
The source code and README are available on GitHub:
https://github.com/ppelleti/inty-midi
Binaries for Mac OS X, Linux, and Windows are available on the "Releases" tab on GitHub, but I've also attached the binaries to this message.
#2 ppelleti OFFLINE
ppelleti
    Space Invader
  • 37 posts
Posted Thu Mar 28, 2019 1:42 PM
Aha, it turns out this has been done before:
https://atariage.com...r-non-musicians
Somehow it did not show up in my initial search for "IntyBASIC MIDI".
#3 carlsson OFFLINE
carlsson
    Metagalactic Mule
  • 8,818 posts
Posted Thu Mar 28, 2019 3:53 PM
Perhaps you two produce different results from the same input, so it is good to have two solutions.
#4 ppelleti OFFLINE
ppelleti
    Space Invader
  • 37 posts
Posted Thu Mar 28, 2019 7:52 PM
At least, I think the two programs have different approaches.  MusoCheat is a modular toolkit which gives the user quite a bit more flexibility, but also requires the user to do more.  inty-midi, on the other hand, tries to be as automatic as possible, and (currently) has very few command line options to tweak.
#5 Lathe26 OFFLINE
Lathe26
  • 3,912 posts
Posted Thu Mar 28, 2019 11:32 PM
There are advantages to both approaches.  Users who are new to MIDI and just trying to get things working will benefit from your tool.
Also tagged with one or more of these keywords: intybasic, music, midi
