Cartridge for E/A and 8K battery RAM
8 replies to this topic
#1 TheBF OFFLINE
TheBF
    Dragonstomper
  • 987 posts
Posted Wed Mar 27, 2019 8:19 PM
I may not have searched hard enough but I am wondering about making a Cartridge with Editor Assembler GROM and an 8K battery ram with calendar and clock.
The 8K RAM could be easily written to and used to host CAMEL Forth.
Since the kernel is only 8K the battery RAM could be used to hold Forth in the cartridge but could be updated if need be very easily.
(I will have to cross-compile a slightly different version for this application but that's what we do this for isn't it?)
The real time clock and calendar is just a nice addition to the system.
Would a mini-memory cartridge board allow this kind of thing?
Anybody know if such a board exists?
The chip I have used in the past is old (MK48T18)  but I see newer versions available like this:
https://4donline.ihs...GSTS16672-1.pdf
#2 helocast OFFLINE
helocast
    Chopper Commander
  • 193 posts
Posted Wed Mar 27, 2019 9:04 PM
Rings a bell I've seen something like that, but like you, a cursory search after reading your post didn't produce anything.
Other than the obvious 24/28 pin size difference if using an existing Mini-mem pcb/cart (arcadeshopper has adapter boards), I'd say it would be a fairly easy realization.
I'll keep searching and reply back if I find anything:
#3 jedimatt42 OFFLINE
jedimatt42
  • 1,964 posts
Posted Wed Mar 27, 2019 9:23 PM
This is generally called a "supercart"
-M@
#4 jedimatt42 OFFLINE
jedimatt42
  • 1,964 posts
Posted Wed Mar 27, 2019 9:25 PM
https://www.arcadesh...bare/p/44354006
#5 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,924 posts
Posted Wed Mar 27, 2019 10:01 PM
The << Super Cart >> was a big thing back in the day.
#6 TheBF OFFLINE
TheBF
    Dragonstomper
  • 987 posts
Posted Thu Mar 28, 2019 5:33 AM
Thanks for the responses. I will look into the supercart idea.
#7 RickyDean OFFLINE
RickyDean
  • 1,117 posts
Posted Thu Mar 28, 2019 6:17 AM
Yes, I have one that was started 20 years ago, not finished yet, been in storage since then, that had a BCD switch to go between banks. could cram some stuff in there and was battery backed like a gram device. Since then, there have been a lot of improvements, by people like Ksarul.
Here is a link with some info, to get started.   http://www.mainbyte..../supercart.html
Edited by RickyDean, Thu Mar 28, 2019 6:26 AM.
#8 senior_falcon OFFLINE
senior_falcon
  • 1,487 posts
Posted Mon Apr 1, 2019 10:30 AM
I did this with 2 additional groms that can be selected with a switch. You can choose:
Editor/Assembler
MiniMemory
Disk Manager
But most of the time I just left it on the EA grom.
#9 TheBF OFFLINE
TheBF
    Dragonstomper
  • 987 posts
Posted Thu Apr 4, 2019 7:18 PM
I think I will buy a board and case from Arcadeshopper after I kill a few million more bugs. :-)
