The AtariAge Forum is undergoing a major upgrade today.  The forum is currently in read-only mode except for the Announcements Forum.  Please read this important post!
Atari ST 16-color limitations and tricks
3 replies to this topic
#1 MoonTurtle OFFLINE
MoonTurtle
    Space Invader
  • 25 posts
Posted Wed Apr 3, 2019 10:51 PM
I was wondering  about any limitations that the standard color graphics mode of the Atari ST (other than only having 16 colors to work with.) and how developers tried to work around these limitations,
Now sometimes it's hard to discuss this kind of topic without using some examples, but this can be a bit tricky to so for Atari ST because, when it comes to color graphics on the ST, there are two main ones, there's the standard 16 colors out of 512, and then there's the STE, which I'm told (I could be wrong) is 32 out on 4092 colors, the ladder being most common in late Atari ST games, mostly in the 90s.
Which is why it's tricky to bring up an example here, I was going to use Wolfchild on the ST as an example of some way to work around the 16 color limitations. but I have a feeling that's an STE game, not an ST game, because looking at the graphics, the game uses way more than 16 colors,
But I did have an idea, maybe the background graphics and foreground graphics use their own respective palettes, but I don't know if that's truly the case or not.
This topic is for the graphics side of Atari ST development. so people who are developing for the ST/STE/STF can learn tricks/loopholes/exploits and just general knowledge of graphics on the Atari ST.
This is mainly for the standard 16-color graphics mode of the ST, but the enhanced graphics of the STE and STF(Falcon) can be discussed here as well.
#2 fedepede04 OFFLINE
fedepede04
    Chopper Commander
  • 167 posts
Posted Thu Apr 4, 2019 5:27 AM
the STE also only had 16 but out of a palette of 4096 colors
but you could do some trick, to get more on the screen.
edit add some info.
The St and STE had a 32000k Screen array.
and it had 4 bit planes in low res
2 bit planes in medium res
and 1 bit plane in high res
giving it 320x200 and 16 colors in low res from a palette 512 (ST) and 4096(STE)
in medium res it had 640x200 4 colors
and i high res 640x400 Black and white
the formula in low res is
(320 / 16 pixel) * 4 (bit plane) * (2 for word for the 16 pixel)
it have a interleave for the graphic,
so first one word (16pixel) for bit plane
so  a word for bit plane 2
so  a word for bit plane 3
so  a word for bit plane 4
then word for bit plane 1
ect.
Edited by fedepede04, Thu Apr 4, 2019 5:59 AM.
#3 ParanoidLittleMan OFFLINE
ParanoidLittleMan
  • 1,712 posts
Posted Fri Apr 5, 2019 5:45 AM
Yes, STE has still only 16 colors at once on screen, only that palette is 'finer' - that is visible in case of some gradation effect, like sky - on STE if will be with less rough transitions.
However, programmers found way to display much more colors at once - first was Spectrum 512. The thing is on changing palette 'on fly' . Later came more advanced solutions, for STE, so we can have almost photo quality, even in movie playback:
http://atari.8bitchip.info/movpst.php
#4 zzip OFFLINE
zzip
  • 2,782 posts
Posted Fri Apr 5, 2019 10:59 AM
CPU Interrupts are often used to swap out the color palette part way through drawing a screen.  The easiest way to do this is at the start of a line, so that each line in effect gets its own unique palette.   Programs like Spectrum 512 changed it mid-line so it would have 48 unique colors per-line.      I believe mid-line color palette changes are more CPU intensive than interrupts at the start of a line.
In case you aren't familiar with the term, an "interrupt" in computing terms is just like someone at work interrupting you to work on another task.  they can be scheduled or trigger by external events (mouse moves cause interrupts that get the computer to update the pointer).   For increasing colors you would tell the computer "excuse me, but if you could change the palette to this before drawing line 96, that would be super!"   (and saying please is accurate because some interrupts are allowed to be ignored under load).   These interrupts also happen independent of the main program after you set them up, so that's nice from a coding aspect.
