Sofia and Lode Runner issues?
5 replies to this topic
#1 scotty OFFLINE
scotty
    Moonsweeper
  • 490 posts
  • I have, but have **YOU** played Atari today?
Posted Fri Apr 12, 2019 8:07 PM
So I have an S-Drive Max, Sofia and Ultimate1MB in one of my 800XLs.  Decided to play some Lode Runner today.  Title screen plays fune, but after the game starts, the screen starts going on and off.  Does not do it on the title screen, just the ameplay.  Other games play fine.  Also noticed some games that use artifacting are in black and white, while others seem to be OK.  Pinball Construction Set is one that comes to mind that is black and white.  Is this normal?
#2 Gavin1968 OFFLINE
Gavin1968
    Star Raider
  • 62 posts
Posted Fri Apr 12, 2019 8:24 PM
Bad image maybe?
#3 Nezgar OFFLINE
Nezgar
  • 1,978 posts
Posted Fri Apr 12, 2019 9:38 PM
Artifacting in the 320x192 modes is only present in the NTSC composite output. S-Video & RGB from Sophia I presume will be similar, and show it in monochrome only. (Unless I am mistaken, and sophia has some mode to emulate artifacting?)
Anyhow, I'm pretty sure lode runner relies on artifacting for colour, since it was a direct port from the Apple II. Same with games like Drol, Choplifter, AE, David's Midnight Magic, (the original, not the one with the graphics 15 hack)
Some examples:
Lode Runner with no artifacting. This is what you will see with an S-Video connection, and I suspect Sophia as well.
Lode runner with artifacting. Blends the thin vertical lines to color on a composite or RF output.
PAL has very subtle artifacting, but is still primarily monochrome stripes...
Not sure about the 'screen going on and off' - does sophia let you see the original video output simultaneously to compare?
#4 vattari OFFLINE
vattari
    Chopper Commander
  • 125 posts
Posted Sat Apr 13, 2019 9:42 AM
Which Sofia do you have - RGB or DVI?
Sent from my iPad using Tapatalk
#5 scotty OFFLINE
scotty
    Moonsweeper
  • 490 posts
Posted Sat Apr 13, 2019 10:05 AM
DVI
#6 scotty OFFLINE
scotty
    Moonsweeper
  • 490 posts
Posted Sat Apr 13, 2019 12:10 PM
Bad image maybe?
Image is known good.  Works on Altirra, and on real hardware without the Sofia board.  Tried 0S-B, 1200XL and XL/XE OSes
