a couple of 68K ASM questions
30 replies to this topic
#1 Wally1 OFFLINE
Wally1
    Moonsweeper
  • 393 posts
  • RAP SUCKS!
Posted Sat Apr 13, 2019 4:49 PM
I wrote this little program to print random Hebrew letters
to the screen:
;RANDOM Hebrew PRINTER
;BY 'ACE'
;April 11 2019
loop:
move.w #17,(sp)    ;get random
trap #14	   ;call GEM
cmp #$c1,d0        ;compare to one before Alef
ble loop           ;less or equal? branch back to loop
cmp #$dd,d0        ;compare to one greater than Tau
bge loop           ;greater or equal? branch back to loop
move d0,-(sp)      ;put random on stack
move.w #2,-(sp)    ;print it
trap #1            ;
jmp loop
bp:
rts
end
Now, it works but very slow.
How to optimize for machine language speeds?
Another question is that I DID NOT clean up the stack
after its use and it runs fine.  I tried this with other little
programs (not ADDQ.L or whatever to the stack)
and they seem to work okay.
Is it absolutely necessary to add and clean up the stack
after its every usage?
Somebodys gotta know.
Todah rabah.
Edited by Wally1, Sat Apr 13, 2019 4:51 PM.
#2 fedepede04 OFFLINE
fedepede04
    Chopper Commander
  • 149 posts
Posted Sat Apr 13, 2019 6:43 PM
yes you need to clean up the stack :D
imagine that you stack is a glass, and every time you put something on the stack, was like you put some water to the glass.
and ever time you clean up the stack was if you drain some water from the glass.
when you can imagine when would happen if you don't  clean up the stack.
it will in the long run crash you program, it could also crash the ST.
#3 Wally1 OFFLINE
Wally1
    Moonsweeper
  • 393 posts
  • RAP SUCKS!
Posted Sat Apr 13, 2019 7:24 PM
thank you fedepede
can somebody please further help..?
:?  :)  :spidey:
fedepede you are from Denmark
do you know the band Volbeat?
Edited by Wally1, Sat Apr 13, 2019 7:27 PM.
#4 ggn OFFLINE
ggn
  • 1,479 posts
Posted Sun Apr 14, 2019 1:56 AM
to the screen:
There are lots of things you can do (and many different ways to do these things).
Reading your code I noticed that you call random and check if the value returned is within range. This is super slow as you're calling an expensive routine over and over and is probably the worst offender for speed in your program. So, how to speed this up?
From your code I see that the number has to be between $c1 and $dd inclusive. Unless I'm mistaken that's 29 numbers. So, instead of waiting until the random number generator gives you the right number, why not modulo the result instead? Quick math refresher, the modulo is the result of a division. So if we divide by 29, the modulo is guaranteed to be between 0 and 29. So, something like this will do:
loop:
trap #14 ;call GEM
and.l #$ffff,d0 ;clear the upper 16 bits so that division will not overflow
divu #29,d0 ;divide by 29. The low word of d0 now contains the result of the division and the high word contains the modulo
swap d0 ;bring the modulo to d0.w. This will be between 0 and 29
add.b #$c1,d0 ;now our number is between $c1 and $dd
trap #1 ;
jmp loop
That should be fine. Of course that's far from the most optimal code but I'm sure it's much faster than your version :)
Todah rabah.
Regarding the stack: Physically it occupies a part of your RAM, so it's not at some magic place where it doesn't matter. To elaborate this using a cruel graph:
ooo..........................................Xxxxxxxx..
RAM START                                             RAM END
This is a very rough model of the ST RAM layout. The 'o's at the start is memory reserved for the system. The '.'s is free memory that applications can use. The 'X' is the address of the stack, and finally 'x' is screen RAM.
So, computers usually place the stack at the highest allowed address, since they go backwards. I.e. when you push parameters on the stack you use -(sp). This works exactly like an address register (and in fact SP is register A7 in 680x0).
So what happens if you don't tidy up the stack? It starts writing RAM backwards. So something like this will happen:
ooo................................XXXXXXXXXXXxxxxxxx..
RAM START                                             RAM END
The stack will start writing over RAM. Usually your program starts in low RAM, right after the 'o's, so it will be safe for a while. Perhaps even forever if you don't use the stack too often.
But if you keep hammering data to the stack it will eventually go and overwrite everything, including your code. This will definitely lead to a crash!
Hopefully this explains things.
Edited by ggn, Sun Apr 14, 2019 1:59 AM.
#5 Wally1 OFFLINE
Wally1
    Moonsweeper
  • 393 posts
  • RAP SUCKS!
Posted Sun Apr 14, 2019 7:17 AM
wow thanks a million
i gotta study your answer
i suspected that to chop half of the random byte was necessary
but didnt know how to do it.
and i have to learn what 'modulo' is
smart!
you are from Greece.  do you like Gyros?
Edited by Wally1, Sun Apr 14, 2019 7:42 AM.
#6 ggn OFFLINE
ggn
  • 1,479 posts
Posted Sun Apr 14, 2019 8:19 AM
smart!
Here's a nice resource with hands-on examples: https://www.omnicalc...com/math/modulo
Sure, it's pretty good!
#7 ParanoidLittleMan OFFLINE
ParanoidLittleMan
  • 1,676 posts
Posted Thu Apr 18, 2019 1:13 AM
There is very fast way to generate pseudo random numbers . Just one of many links dealing with it: http://www.cs.miami....om_numbers.html
 I used that way in many cases. For instance so called random dissolve - something like pixelwise fading needs fast pseudo random gen.
And if you want extra high speed may use direct draw to screen instead trap calls.
#8 Wally1 OFFLINE
Wally1
    Moonsweeper
  • 393 posts
  • RAP SUCKS!
Posted Thu Apr 18, 2019 2:08 PM
Can you provide examples Peter?
#9 ParanoidLittleMan OFFLINE
ParanoidLittleMan
  • 1,676 posts
Posted Fri Apr 19, 2019 1:54 AM
Here is ASM code for 32 bit pseudo random generator, with shifts:
*random generator
  btst #2,d6
  bne.s y1
  btst #16,d6
  beq.s peven
  bra.s podd
y1 btst #16,d6
  beq.s podd
peven bset #31,d6
  bra.s rotate
podd bclr #31,d6
rotate  rol.l #1,d6
In case of 32 bit length, feedback are bits 2 and 16, and parity of them is condition for setting or resetting last bit, 31 before shift, better said rotate - it will go in bit 0 .
There are specific feedback bits for every length in bits, sometimes it's more than 2 bits. Of course, here talking about feedback what will generate full range of values. So in case of 32 bit length it is all 2 POW 32 different values.
You may find pages about it, where are concrete feedback bits for different bit lengths. I made in past some proggie which tested are used feedback bits correct for getting 2 POW n different values. Will look to dig it out.
#10 Wally1 OFFLINE
Wally1
    Moonsweeper
  • 393 posts
  • RAP SUCKS!
Posted Fri Apr 19, 2019 8:46 AM
OK thanks. What about direct draw to screen?
#11 ParanoidLittleMan OFFLINE
ParanoidLittleMan
  • 1,676 posts
Posted Sat Apr 20, 2019 12:53 AM
Here is simple code I used in some cases:
txtpr
	move.l	$44E.w,a1   * dest - screen start
	lea	4(a1),a1   * move to dark blue color  - low res
	move.l	a1,a4
txtloop	move.b	(a0)+,d5   * char code ASCII
	beq	txtend
	cmp.b	#13,d5
	bne.s	prich
	addq.b	#1,txty
	clr.b	txtx
	bra.s	txtloop
prich	moveq	#0,d0
	moveq	#0,d1
	move.b	txtx,d0
	move.b	txty,d1
	mulu	#$500,d1
	add.l	d1,a1
	move.l	d0,d2
	bclr	#0,d2
	lsl.w	#2,d2   * x8 - because it is step 2
	btst	#0,d0
	beq.s	notOd
	addq.w	#1,d2
notOd	add.l	d2,a1   * dest, bitplane n
	lea	font(pc),a2
	adda.w	d5,a2
	moveq	#7,d3
charl	move.b	(a2),(a1)
	lea	$100(a2),a2
	lea	$A0(a1),a1
	dbf	d3,charl
	addq.b	#1,txtx
	move.l	a4,a1
	bra	txtloop
txtend	rts
txtx  dc.b  0
txty  dc.b  0
font   incbin  "FONT"
Attached File  FONT.ZIP   1.3KB   3 downloads
#12 Wally1 OFFLINE
Wally1
    Moonsweeper
  • 393 posts
  • RAP SUCKS!
Posted Sat Apr 20, 2019 8:27 AM
Thank you Peter!
but, erm.. what does this program do?
I will type it in anyhow.
Edited by Wally1, Sat Apr 20, 2019 8:33 AM.
#13 ParanoidLittleMan OFFLINE
ParanoidLittleMan
  • 1,676 posts
Posted Sat Apr 20, 2019 12:10 PM
This is not complete program, just simple routine for text print on screen. It is for low res.
Enter parameter is txt string address in a0 . Terminated by 0, so may be single char. too.
txtx and txty serve to set position for text on screen. txtx=0, and txty=0 means top right corner
txty=5 will print 5 lines lower.
#14 Wally1 OFFLINE
Wally1
    Moonsweeper
  • 393 posts
  • RAP SUCKS!
Posted Wed May 1, 2019 3:21 PM
okay
i need to know why when I
MOVE #$21,(SP)
that is, move something to the top of the stack
(on my 1040 ST the stack top is $F8000)
and then examine memory at that very address ($F8000)
NOTHING is ever there!
I have some idea but would like to hear an expert opinion.
however if I: "MOVE #$21,-(SP)"
then the stack pointer decreases and I examine memory
at $F8FFE, the "$21" will be there!
also, I wrote the object code for this (improved) Hebrew random print
program.  It becomes a .PRG file but when I run it it only prints one line
of Hebrew at the very top of the screen!
The original source code when run from my assembler works as it should,
filling the screen with random Hebrew letters.
AtariAge for some reason won't allow me to attach my .PRG file so
here is the source code for my little work of art that needs your help:
;BY 'ACE' with help from ggn of Greece
;April 14, 2019
loop:
move.w #$11,-(sp)   ;get random
trap #$e	    ;call GEM
addq.l #$2,sp       ;fix stack
and.l #$ffff,d0     ;clear upper 16 bits division not overflow
divu #$1b,d0        ;divide by 27
swap d0             ;modulo to D0
add.b #$c2,d0       ;add 194 to random
move d0,-(sp)       ;random on stack
trap #1             ;call GEM
addq.w #$4,sp       ;stack correction
jmp loop
bp:
rts
end
thanks !
:jango:
#15 Wally1 OFFLINE
Wally1
    Moonsweeper
  • 393 posts
  • RAP SUCKS!
Posted Wed May 1, 2019 4:24 PM
sorry that memory location at the top of the previous post
should read:
"$F7FFE"
and not "$F8FFE"
Decidedly so.
Edited by Wally1, Wed May 1, 2019 4:25 PM.
#16 fedepede04 OFFLINE
fedepede04
    Chopper Commander
  • 149 posts
Posted Wed May 1, 2019 11:59 PM
okay
MOVE #$21,(SP)
;April 14, 2019
loop:
trap #$e	    ;call GEM
trap #1             ;call GEM
jmp loop
bp:
rts
end
thanks !
:jango:
Hi Wally
a couple of things, lets start with -(Sp) and (SP)+ or -(Ax) (Ax)+.
ok it actual telling you what its doing.
In case of -(SP),-(Ax) what it means is, it first start with subtracting the length of the data to the Ax/SP pointer and after that is finish, its moves the data ,
so in case if you use a long word. and let say A0 points Address 1000 and you write Move.l  #$12345678,-(A0)
it will start with subtracting 4 from A0 so it now pointing to 996, and if you look in address 996 it would say $12345678
same with move.w but its only 2 bytes and of cause move.b its only a byte,
but i am not sure that it work when using a byte on the stack Pointer (SP)
same with (SP)+,(Ax)+ it just mean that the SP or AX will be add to instead of being subtracted from, one more thing to beware of here, is that the add fist will be add after the memory operations.
same example as before
let say A0 points address 996 and the contains in 996 is #$12345678
and if you write Move.l  #$0,(A0)+
it will start by moving #0, to address 996 and after that have been done, it now add 4 to the address register.
before the move #0 the address contain the value of #$12345678 after the move.l. A0 now pointing to address 1000 and if you look in memory address 996 it should say zero
but you can remember it like this is the mathematical symbols before the Parenthesis
it will do the sub first (and in this case) the move after.
and if the mathematical symbols are after Parenthesis.
it will do the (in this case) move first and the add after
but the party don't stop here. you can do the same with
clr.b.w.l  -(ax/sp)+
tst.b.w.l  -(ax/sp)+
cmp.b.w.l  -(ax/sp)+
or.b.w.l  -(ax/sp)+
and.b.w.l  -(ax/sp)+
and more
why use the -()/()+, I think you get the add and the sub for free. (but I am not 100% sure maybe an other can tell you).
one more thing don't use jmp or jsr there can be cases where you only can use the like jmp (A0)
use bra and brs
i hope you get my nonsense, i have been very sick the last week, and still not 100%.
#17 Wally1 OFFLINE
Wally1
    Moonsweeper
  • 393 posts
  • RAP SUCKS!
Posted Thu May 2, 2019 6:52 AM
thank you fedepede
I was talking about
when the stack pointer is accessed without, the plus or minus (+ or -)
"MOVE #$21, (SP)"  [notice NO plus or minus]
and say stack pointer says $F8000
and i check memory $F8000
there is nothing there!
when you access the stack without a plus or minus
it means the top of the stack.
but I don't know why the memory address holds nothing.
I hope you feel better fedepede
Edited by Wally1, Thu May 2, 2019 6:54 AM.
#18 fedepede04 OFFLINE
fedepede04
    Chopper Commander
  • 149 posts
Posted Thu May 2, 2019 7:09 AM
You are right to a certain degree, but since you always or nearly always do a -(sp) you need to point byte outside the memory, I don't know what Atari you have but I will bet that you memory have ended at address $F80000
#19 Wally1 OFFLINE
Wally1
    Moonsweeper
  • 393 posts
  • RAP SUCKS!
Posted Thu May 2, 2019 8:52 AM
I have 1040 ST.
i guess its because $F8000 is the very top of memory or something.
not the best explanation or whatever...
can you help with my program
it only prints the very first line at the top of the screen
and nothing else.
when run from assembler it fills the whole screen.
#20 fedepede04 OFFLINE
fedepede04
    Chopper Commander
  • 149 posts
Posted Thu May 2, 2019 9:18 AM
You still use Seka? I could make a source code that can do what you need and uploaded it... and you can take what you need from it, and if you have any questions to it just ask.
But it have to wait for tomorrow I am going out for the rest of the day 😀
Btw how much do you know to the Atari hardware like video chip ect.
#21 Wally1 OFFLINE
Wally1
    Moonsweeper
  • 393 posts
  • RAP SUCKS!
Posted Thu May 2, 2019 9:54 AM
yeah i still use Seka
its okay but one thing is it exits to TOS with almost every program break.
I dont really know Atari hardware like video chip stuff.
I try to learn simple things like hardware independent beginner code, stuff like that
i am just a beginner myself.
and i just ordered DevPac one on a floppy from ebay.
thank you very much fedepede
Edited by Wally1, Thu May 2, 2019 9:54 AM.
#22 fedepede04 OFFLINE
fedepede04
    Chopper Commander
  • 149 posts
Posted Thu May 2, 2019 1:55 PM
in Seka you can't terminate a program like you do with other software.
it how you normal terminate a program
                  CLR.W     -(A7)  ;PTERM0
                  TRAP      #1
                  Rts
But in Seka you have to rem these two lines, and only to let them be compiled them the last time (Or when the program is finish for release),
;                  CLR.W     -(A7) ;PTERM0
;                  TRAP      #1
                  Rts
now you should be able to run and exit a program in seka with out it exiting to TOS.
but give me an idea what you goal would be with this program, so i know what i should make?
Edited by fedepede04, Thu May 2, 2019 2:02 PM.
#23 Wally1 OFFLINE
Wally1
    Moonsweeper
  • 393 posts
  • RAP SUCKS!
Posted Thu May 2, 2019 2:18 PM
well
I just trying to print random Hebrew (which is in TOS ROM)
to the screen.
you dont have to write it for me
cause it works from Seka but not as a .PRG file
As a .PRG file, it just prints one line at the top of the screen
here it is:
;April 14, 2019
loop:
trap #$e	    ;call GEM
trap #1             ;call GEM
jmp loop
bp:
rts
end
i appreciate your help Fedepede
and i will try that trick in Seka
i guess you could run the program to see what i am talking about
thank you
#24 fedepede04 OFFLINE
fedepede04
    Chopper Commander
  • 149 posts
Posted Thu May 2, 2019 2:56 PM
Hi Wally I now think that i know what you problem is, I will try putting something together for tomorrow.
but try check this website
http://www.atari-wik...x.php/Main_Page
there are also a lot of info on the ST hardware sothware ect.
#25 fedepede04 OFFLINE
fedepede04
    Chopper Commander
  • 149 posts
Posted Thu May 2, 2019 10:31 PM
btw could you please try an change the extension of the prg file to .tos
