Team Pixelboy News Bulletin - April 14th 2019
46 replies to this topic
#26 Pixelboy ONLINE
Pixelboy
  • 8,242 posts
Posted Mon Apr 29, 2019 7:14 AM
Interesting update: I tried Knightmare on my AtariMax SD cartridge (after making sure I'm using the same software revision that's on the buggy carts, which is indeed the very latest "fixed" version) and I couldn't get the game to crash at the second boss.
So Ikrananka is testing his real Knightmare cart on real hardware and he's not seeing the bug, while I do see it during my own tests with the real cart. But I can't make the game crash when I'm running the same software via my AtariMax SD cartridge.
I would theorize that there's some kind of subtle technical difference between the MegaCart implementation in the SD cartridge and the MegaCart I'm using for real cartridges, and this subtle difference is causing problems on certain (not all) revisions of the ColecoVision motherboard. This conclusion is arguably a bit convoluted, but it's the best conclusion I can reach given the tests that were done. So I guess all I can do is give people a refund if they want it, for those who are having problems with their Knightmare cartridge. :|
#27 Ikrananka OFFLINE
Ikrananka
  • 3,105 posts
Posted Mon Apr 29, 2019 7:25 AM
I'm totally grasping at straws here but does the system you're testing your cart on have the centre screw installed on the motherboard and do you have good continuity between pin 13 of your CVs cartridge connector and ground.  Lack of continuity here badly affects Penguin Adventure and Risky Rick so perhaps this also can also affect MegaCart games as well in different ways.  Just a thought.
Edited by Ikrananka, Mon Apr 29, 2019 7:26 AM.
#28 Pixelboy ONLINE
Pixelboy
  • 8,242 posts
Posted Mon Apr 29, 2019 7:58 AM
I'm too much of a klutz to open up my CV console without breaking something, so I'd rather not try.
#29 Ikrananka OFFLINE
Ikrananka
  • 3,105 posts
Posted Mon Apr 29, 2019 8:13 AM
If you have a multimeter you can access both the cart connector and a ground pin on the expansion port without opening up the console.
#30 Pixelboy ONLINE
Pixelboy
  • 8,242 posts
Posted Mon Apr 29, 2019 8:45 AM
No multimeter in sight. :P
#31 Ikrananka OFFLINE
Ikrananka
  • 3,105 posts
Posted Mon Apr 29, 2019 8:48 AM
Time to buy one then  :P  :-D  :P
#32 Ikrananka OFFLINE
Ikrananka
  • 3,105 posts
Posted Mon Apr 29, 2019 8:49 AM
Seriously though, do you have another CV console you can try that cart on?
I'll play the game some more later this week and will report back.
Edited by Ikrananka, Mon Apr 29, 2019 8:50 AM.
#33 Kiwi OFFLINE
Kiwi
  • 1,693 posts
Posted Mon Apr 29, 2019 2:36 PM
Ok, I finally raise my Colecovision from it stasis to test the cart version with it white square on it.  Even though I had the shield, it didn't crash when I got hit in the back.  It went to game over and went to the title screen because I died to the bat storm that I have forgotten about.  Letting the slimes live prevented that storm from happening.
I would recommend letting 5-11under or who you're comfortable to check out your Colecovision for the reason Ikrananka stated.  It could affect your beta testing effort on the game in progress and can cause confusion to the programmer trying to locate the bugs.
Edited by Kiwi, Mon Apr 29, 2019 2:58 PM.
#34 Pixelboy ONLINE
Pixelboy
  • 8,242 posts
Posted Tue Apr 30, 2019 4:31 AM
I do have another CV I can try Knightmare with, but this cannot change the outcome of this investigation. Am I going to ask all my customers to open up their consoles to make sure they are "up to specs" for playing this game? I think not. It makes more sense to simply say "sorry, I guess your Knightmare cart doesn't work with your particular console hardware revision", and offer those who are having problems their money back. The ROM is already available for free anyway (it was released last Christmas).
On the other hand, I do wonder how the CollectorVision Phoenix behaves with this game. If real Knightmare carts (not running via Atarimax SD cart) work without issue for some of the people here, then perhaps it will work on the Phoenix just as well.
#35 Bmack36 OFFLINE
Bmack36
    Dragonstomper
  • 685 posts
Posted Tue Apr 30, 2019 4:41 AM
If someone wants to send a known bad cart to me, I can test it on the phoenix.
#36 Pixelboy ONLINE
Pixelboy
  • 8,242 posts
Posted Tue Apr 30, 2019 5:19 AM
I have one, obviously. :) Does coleco_master have a Phoenix in his possession? Otherwise I can just ship it to you directly. Be warned though, making it to the second boss takes some practice, because Knightmare is a tough game, especially when the game throws a flurry of bats your way from all directions.
#37 Ikrananka OFFLINE
Ikrananka
  • 3,105 posts
Posted Tue Apr 30, 2019 7:08 AM
I was simply trying to help you determine if the issue perhaps lies with the console and not the cart.  I made no comment regarding what you should do based on that outcome.
#38 Pixelboy ONLINE
Pixelboy
  • 8,242 posts
Posted Tue Apr 30, 2019 7:34 AM
Understood. I can't spend too much time on this because I'm busy preparing the next releases. :)
#39 Kiwi OFFLINE
Kiwi
  • 1,693 posts
Posted Wed May 1, 2019 3:14 AM
I've wondered if it also crash at the next sprite version of the boss with that PCB?  I have reached stage 7 without any crash before on the fixed version.  I will try to make time to recheck it out, and finally reach stage 8 and complete the loop.
Cool. I'm ready for it.
Was playing it today and couldn't even get to the second boss  :mad:  Will try again tomorrow .
Try to power up your speed and get the shield with the Blue P and the Light Blue P.  Shoot it to make it cycle through the colors.  Once you're satisfied with the speed power up, aim to get the white P.  This makes you invulnerable, but you're able to shoot in this state. The red P makes you able to crash into enemies and make them explode into bits and pieces Vanguard-style(you're not able to shoot in this state), be sure you're not on the level you need to shoot to reveal a bridge to cross the water :skull: .
For weapon, I recommend getting the sword.  That'll melt almost everything. You can power up your weapon twice, so you'll have to shoot the weapon orb and get the same weapon icon twice.  I preferred the boomerang so if you miss, you can move to get it to hit your target on the return.  Powered up boomerang let you have 3 boomerangs at a time.
Remember where the hidden 1ups are.  Don't stop shooting so you can reveal those hidden tiles.  Also, you gain 1up as you reach a certain amount of points.
The enemies group comes in 4 and 6.  Sometimes, you can leave 1 linger to try to skip or delay the next wave of enemies.  Good luck!
Edited by Kiwi, Wed May 1, 2019 3:14 AM.
#40 Pixelboy ONLINE
Pixelboy
  • 8,242 posts
Posted Wed May 1, 2019 4:00 AM
I marvel at your gaming talents, but you do need to let each boss kill you with his projectiles in order to check if the crash happens. ;)
#41 opcode OFFLINE
opcode
  • 4,585 posts
  • Bringing new life to your ColecoVision!
Posted Wed May 1, 2019 12:01 PM
I would be surprised if there is a bug in the game, as Knightmare is something I tested extensively. And the same code was later ported for Prometheus, with added hardware scroll and all. No issues. So I agree it must be some hardware issue.
#42 Pixelboy ONLINE
Pixelboy
  • 8,242 posts
Posted Wed May 1, 2019 12:12 PM
Agreed. And it must be a pretty subtle technicality, as it doesn't happen on all consoles.
P.S.: Is your "upgraded" version of Knightmare compatible with the Omni/SGM2, by the way? :)
Edited by Pixelboy, Wed May 1, 2019 12:13 PM.
#43 Kiwi OFFLINE
Kiwi
  • 1,693 posts
Posted Wed May 1, 2019 12:55 PM
One last question. Did you test the game just with the PCB?  I do recall you stating having to shave some of the plastic before.
I admit I am worried since I am a programmer and I don't want my games to bug out due to hardware issue.  My the game I just finished is a mega-cart so that's something I can't test on my system on an actual half-mega cart PCB.  And also, how to get around the hardware issue via software.
#44 Pixelboy ONLINE
Pixelboy
  • 8,242 posts
Posted Wed May 1, 2019 1:06 PM
I tested with fully-assembled carts.
I believe this is a bug of the one-in-a-million kind. You need to have some specific code doing specific things at a specific time to make the software crash and reset. This is the first time I've ever seen something like this, so I'd say the same problem popping up in another completely different MegaCart game is rather unlikely.
Edited by Pixelboy, Wed May 1, 2019 1:06 PM.
#45 TPR OFFLINE
TPR
  • 2,223 posts
Posted Thu May 2, 2019 2:18 PM
I can ship you my cart or I could try it on my Phoenix assuming I have the latest version. (of the PHX, that is)
#46 Bmack36 OFFLINE
Bmack36
    Dragonstomper
  • 685 posts
Posted Thu May 2, 2019 2:25 PM
I sent you the latest bit file, so yours should be fine to test. Although even an older version should still be fine for testing.
Edited by Bmack36, Thu May 2, 2019 2:26 PM.
#47 Pixelboy ONLINE
Pixelboy
  • 8,242 posts
Posted Sun May 19, 2019 9:33 PM
Quick (yet important) update: A problem has been encountered with cartridges of The Cure (it's the old works-on-AtariMax-cart-but-not-on-real-carts problem) and it's currently being investigated. As a result, I've contacted all the people who pre-ordered the new games except for The Cure, and the majority of those orders shipped earlier today. Once the issue with The Cure is resolved, I will assemble the carts and honor the rest of the recorded pre-orders.
All this to say that Uridium, QBIQS, Booming Boy, Multiverse and The Cure have been moved from the "Ongoing Projects" to the "Completed Projects" section of teampixelboy.com. Perhaps I shouldn't have moved The Cure just yet, since copies are not quite ready to ship, but oh well, it's no big deal. :)
P.S.: By the way, TPR, were you able to give your Knightmare cartridge a kick in the tires on the Phoenix? :)
Edited by Pixelboy, Sun May 19, 2019 9:34 PM.
