Flashing Side2cart with 64kb?
21 replies to this topic
#1 Mariano DM OFFLINE
Mariano DM
    Combat Commando
  • 6 posts
Posted Wed Apr 17, 2019 5:41 AM
Hello, Ive been trying to update side2 to FJCs firmware, I managed to load the Flash útil executable using the menu loader..
If I switch the cart to sdx mode, it can detect the cart, but now I get an error enable extended memory and continue.
Does this require a 130xe or expansion? . Im trying to do it in my 800XL.
Thanks.
Edited by Mariano DM, Wed Apr 17, 2019 5:42 AM.
#2 flashjazzcat ONLINE
flashjazzcat
  • 14,497 posts
Posted Wed Apr 17, 2019 5:51 AM
I provided four ATRs in the 'ATR' folder of the firmware update. Run the 'FLASH_S2.COM' file on the 'side_loader.atr' image and the loader will be updated. You should first boot SDX from the cartridge itself before launching the flasher. It works on 64K machines.
#3 Stormtrooper of Death OFFLINE
    Moonsweeper
  • 449 posts
Posted Wed Apr 17, 2019 6:41 AM
In the SIDE_Loader_v.2_Final_230718 zip file,
there are 4 ATR files in the ATR section.
Side_full
Side_loader
side2_full
side2_loader
what is the diference between those 4 ?
And what is the correct order to update the Side2 (Lotharek) cart ? SDX rom first, then SIDE loader ?
#4 flashjazzcat ONLINE
flashjazzcat
  • 14,497 posts
Posted Wed Apr 17, 2019 6:53 AM
side_full = the full SIDE ROM (512KB, including SDX and the loader)
side_loader = the SIDE loader
side2_full = the full SIDE2 ROM (512KB, including SDX and the loader)
side2_loader = the SIDE2 loader
The loaders for SIDE and SIDE2 are actually identical, but the SDX ROMs are not. Nevertheless I included separate loader ATRs for maximum clarity, supposedly. I'll include a README in the next update, nevertheless, since it's plainly needed and the purpose of the .COM flashers is obviously unclear.
You can update things in any order you please, since SDX and the loader are two completely separate entities.
Note: actually, the separate loader ATRs are required since the SDX banking register is used during the flashing process, and that differs between SIDE and SIDE2. :)
Edited by flashjazzcat, Wed Apr 17, 2019 6:55 AM.
#5 dimfil OFFLINE
dimfil
    Star Raider
  • 58 posts
Posted Wed Apr 17, 2019 6:54 AM
I remember I used the Side2_full.
I first updated SDX then the Loader, as described in a relative YouTube video.
#6 Stormtrooper of Death OFFLINE
    Moonsweeper
  • 449 posts
Posted Wed Apr 17, 2019 6:56 AM
FJC, if I want to replace the SIDE2 loader with something i program myselve but still want to have SDX on the SIDE2, do you have a seperate SDX Rom that I can use to only flash the newest SDX to the SIDE2 ?
and is there also an option to use the full 512KB for SDX only ?
#7 flashjazzcat ONLINE
flashjazzcat
  • 14,497 posts
Posted Wed Apr 17, 2019 7:28 AM
The SDX ROMs for SIDE2 are all available directly from the SDX upgrade site, so I saw little point in offering them for download from my site. I could link to them in the future, I suppose.
As for replacing the loader: you're free to flash whatever you like to the external cart ROM, and you can do so with either UFLASH or the DLT flasher. Later this week I'll be releasing SIDE ROMs which include the loader and all four OSS language carts (kindly converted by ebiguy).
It should be possible to use a 512K SDX ROM, although it's difficult to imagine a scenario where this would be necessary since it's difficult to fill up the CAR: volume on the 320K builds available for U1MB. The 8K file size limitation does not help. But since the SDX banking register is - necessarily - able to access all sixty-four 8K banks of the ROM, there's no reason it could not be done.
#8 Mariano DM OFFLINE
Mariano DM
    Combat Commando
  • 6 posts
Posted Wed Apr 17, 2019 12:24 PM
Thanks a lot for your help !
If I only use the side2 loader, I get a memory conflict error.
I updated using the side2_full atr and now I get FJC's loader.
Next: Trying to figure out how to create an APT partition in the CF without 128Kb.
I wish gparted had the "atari 8 bit" option :)
Cheers !
Edited by Mariano DM, Wed Apr 17, 2019 12:25 PM.
#9 _The Doctor__ OFFLINE
_The Doctor__
    Flux Capacitor Master Craftsman
  • 6,738 posts
Posted Wed Apr 17, 2019 1:05 PM
X /C FLASH_S2.COM
is the next thing to try with stuff that conflicts...
also try to bypass a autoexec.bat or startup.bat/ config.sys etc
if that fails load from disk and make sure not to load too much stuff, also try loading sparta in other memory areas
Edited by _The Doctor__, Wed Apr 17, 2019 1:17 PM.
#10 flashjazzcat ONLINE
flashjazzcat
  • 14,497 posts
Posted Wed Apr 17, 2019 1:12 PM
The SIDE.SYS driver is pushing MEMLO up too high for the flasher. Try booting from an SIO-attched disk containing a CONFIG.SYS which doesn't install the SIDE driver, and you should be good.
#11 flashjazzcat ONLINE
flashjazzcat
  • 14,497 posts
Posted Wed Apr 17, 2019 1:14 PM
What am I saying? I thought of this already, of course.
Boot as normal, but while holding down the shift key. SIDE.SYS won't load and you can run the flasher from your SIO-attached ATR. :)
#12 dimfil OFFLINE
dimfil
    Star Raider
  • 58 posts
Posted Wed Apr 17, 2019 1:47 PM
As far as the partitions is concerned, you can't run the FDISK with only 64kb. I had the same problem and (before installing my U1Mb) I solved the situation like this:
- took an image of my cf with win32DiskImager
- used Altirra to mount this image as cf of Side2 device
- prepared the partitions
- had the image written back to the cf with same program
Edited by dimfil, Wed Apr 17, 2019 1:48 PM.
#13 Stormtrooper of Death OFFLINE
    Moonsweeper
  • 449 posts
Posted Wed Apr 17, 2019 2:30 PM
Using FDISK with a 64KB Atari might work when you do the following:
1 - boot SDX from the SIDE2 cart
2 - format a floppy (example D1:)
3 - then type this
D1:    (push RETURN)
ED CONFIG.SYS (press RETURN)
then type this
USE OSRAM
DEVICE SPARTA OSRAM
DEVICE SIO
DEVICE SIDE
(then save the config file, by pushing ESC key once and then RETURN key)
4 reboot your Atari + SIDE2 cart
5 FDISK works with 64K
(If the SIDE2 compactflash memorycard already is partitioned before, check that SDX is not using one of the partitions on the CF memorycard as a BOOT partition, otherwise SDX will not boot from the floppy.)
(I tried this using the Altirra emulator in 64K Atari 800XL and SIDE2 settings, have to try it next week, when my real SIDE2 cart from Lotharek arives....)
Edited by Stormtrooper of Death, Wed Apr 17, 2019 2:32 PM.
#14 Mariano DM OFFLINE
Mariano DM
    Combat Commando
  • 6 posts
Posted Wed Apr 17, 2019 2:53 PM
You freaking rock !
Thanks for all the guidance, I'll try both methods and publish my results.
Currenty fdisk runs, but it does not detect the device (I suppose it is because it is running form the same cart)
#15 Stormtrooper of Death OFFLINE
    Moonsweeper
  • 449 posts
Posted Wed Apr 17, 2019 3:02 PM
Mariano, could you try to run FDISK using my trick
#16 dimfil OFFLINE
dimfil
    Star Raider
  • 58 posts
You freaking rock !
No, it is not detecting the card because of memory conflict issues with Side driver, as Jon explained in another thread when I asked the same question.
#17 flashjazzcat ONLINE
flashjazzcat
  • 14,497 posts
Posted Wed Apr 17, 2019 4:17 PM
The FDISK stub loader should check MEMLO and exit gracefully, but it makes little difference at the end of the day, since the SIDE driver pushes MEMLO too high on a 64K machine for most applications to even run. If you manage to get the disk partitioned, it's still not going to be much practical use, IMO.
The solution is more RAM or U1MB (the latter making the SIDE.SYS driver totally unnecessary and ironically rendering the hard disk fully usable in 64K of RAM).
Of course the SIDE loader is perfectly at home on a 64K machine, but SDX quickly starts feeling cramped without extended RAM regardless of whether one wants to use SIDE.SYS or not. I remember hurrying to upgrade to 128K in 1989 within weeks of purchasing my SDX cart. :)
#18 irich2 OFFLINE
irich2
    Space Invader
  • 33 posts
Posted Wed Apr 17, 2019 8:03 PM
Nir Dary of The Modern Atari 8Bit Computer made a video a couple of years ago on how to upgrade the SIDE2 cartridge:
#19 Mariano DM OFFLINE
Mariano DM
    Combat Commando
  • 6 posts
Posted Wed Apr 17, 2019 8:45 PM
Holey Pozole !
Take a look at this, using the custom config, it actually worked.
Now I know I'm pushing the little box to the limits, but now I can play around in the meanhile I get the upgrade
Wow ...
Thank you  Thank you  Thankyou
#20 Stormtrooper of Death OFFLINE
    Moonsweeper
  • 449 posts
Posted Thu Apr 18, 2019 12:54 AM
Mariano, did you use my custom Config file ?
If it works on a real SIDE2, then that is great news for 64K Atari users.
#21 flashjazzcat ONLINE
flashjazzcat
  • 14,497 posts
Posted Thu Apr 18, 2019 2:20 AM
What is the resulting MEMLO with this configuration (type 'MEM')?
#22 Mariano DM OFFLINE
Mariano DM
    Combat Commando
  • 6 posts
Posted Thu Apr 18, 2019 11:09 AM
Hello FJC
Here's mem results. I think the custom config made barely enough for fdisk to work.
As expected, things like Turbobasic still get memory conflict, but synasm loads fine.
For reflashing the SDX, doing this does not work. I booted with the shift key and was able to update to 4.49c
Cheers
M
