Atari 2600 4 switch video distortion
10 replies to this topic
#1 diablonet OFFLINE
diablonet
    Space Invader
  • 12 posts
Posted Wed Apr 17, 2019 8:24 AM
Hello all, I own an Atari 2600 4 switch which has video distortion.
When I turn on the console and after 3-4 minutes, the video will be distorted, look the video I made of it, If I power cycle the Atari, it looks fine again and it will begin to distort again in a while.
I have replaced so far:
Capacitors, voltage regulator, RF module, power supply, video cable, crystal, 3 main chips (TIA, 6507 and 6532), but the problem remains.
Any suggestion?
Thank you in advance.
#2 Cambouis de l'Atari OFFLINE
Cambouis de l'Atari
    Moonsweeper
  • 299 posts
  • Also known as "Urbinoo"
Posted Wed Apr 17, 2019 8:26 AM
The tv ? ;)
#3 diablonet OFFLINE
diablonet
    Space Invader
  • 12 posts
Posted Wed Apr 17, 2019 8:33 AM
The tv ? ;)
No, its not the TV, I tried another as well, thank you
#4 ubersaurus ONLINE
ubersaurus
  • 5,351 posts
Posted Wed Apr 17, 2019 8:44 AM
I had a similar issue with a four switch that went away after I completely recapped the thing and had the voltage regulator replaced. Same system also had the main chips and RF modulator swapped, but the issue only went away after the recapping and regulator swap. Maybe there's a bad solder joint somewhere around a cap?
#5 diablonet OFFLINE
diablonet
    Space Invader
  • 12 posts
Posted Wed Apr 17, 2019 9:36 AM
Thank you for your suggestion, I just resolder everything as you suggested and the problem remains, there must be something else
#6 -^CrožBow^- ONLINE
-^CrožBow^-
  • 7,116 posts
  • Collector of Fine Atari and Sega Antiquities!
Posted Wed Apr 17, 2019 10:18 AM
- How do you have it connected to the TV exactly?
- You stated it does the same thing on two different TVs? Where they both modern displays?
#7 diablonet OFFLINE
diablonet
    Space Invader
  • 12 posts
Posted Wed Apr 17, 2019 10:31 AM
If I try RF or Composite mod, it gets same result, i tried old CRT and led screen, both same results.
#8 -^CrožBow^- ONLINE
-^CrožBow^-
  • 7,116 posts
Posted Wed Apr 17, 2019 10:35 AM
Does you 2600 4 switch happen to use the 4050 buffer chip on it? That would be the next thing that comes to my mind since you've replaced pretty much everything else at this point and given the fact the signal issue happens on both composite and RF leads me to think the issue is happening before the composite signal is even getting to the RF modulator in the first place. I'm assuming your composite mod is amping the signal from the composite video in at the RF modulator?
#9 diablonet OFFLINE
diablonet
    Space Invader
  • 12 posts
Posted Wed Apr 17, 2019 1:34 PM
By board uses not the 4050 buffer chip, I attach some pics, the issue appeared before all the changes I did (capacitors, regulator, bla bla bla), after the changes the problem remains. thank you for your help.
#10 Rom Collector OFFLINE
Rom Collector
    Star Raider
  • 97 posts
Posted Wed Apr 17, 2019 6:53 PM
I'm no expert, but sounds like the voltage regulator may be overheating. Did you use good thermal compound between the regulator and heat sink?
Also I might try a different ac adapter.
#11 diablonet OFFLINE
diablonet
    Space Invader
  • 12 posts
Posted Fri Apr 19, 2019 8:05 AM
Problem solved guts, thank you so much to everyone, it come I forgot to replace the C241 capacitor, not it works perfect!
