TIPI / RPI / File Project Repository
6 replies to this topic
#1 BeeryMiller OFFLINE
BeeryMiller
    Dragonstomper
  • 952 posts
Posted Fri Apr 19, 2019 1:25 PM
I'm not exactly sure how one may describe it, but throwing something out there to see if may tickle someone's interest.
I am wondering about the possibility multiple users working on a project together, with a RPI as the file repository for a project.
Github is fine for some people working on a project, however, I am a bit more old school dealing with assembly source files and do not have a desire to learn all the nuances in addition to the C language for the gcc compiler.
What I wonder is what would be involved so that a user could retrieve a file for editing / submission purposes from someone's RPI for projects involving multiple programmers?  I'm thinking with the filename such as TIPI.URL1.Filename,username,password would allow secured reading/writing access.  Maybe a separate app someone could run that would give a user write permission by the hosting TIPI/RPI unit???
At the moment, I am not sure if our current editors out there would choke on a comma in the filename (perhaps a semicolon?) to know if we may need to modify an editor or two.
Anyways, just throwing some thoughts out there for an idea.
Thoughts?  It's not something I am capable of doing, but I see it as something that may be beneficial for some programmers............
Beery
#2 jedimatt42 OFFLINE
jedimatt42
  • 2,023 posts
Posted Fri Apr 19, 2019 2:05 PM
well, there are webservers that allow url based authentication...  the URL syntax is:
http[s]://<username>:<password>@<hostname>:<port>/filepath
You could open PI.https://beery:passwo...proja/PROJA.A99
That'd read the file... if TIPI were extended to allow writing to PI.http[s] files (tipi/services/CurlFile.py - collect the records in memory then do a POST to the url with the python curl api) then you could write to them...
You could amend the TIPI  web-ui webserver to require access control and authentication... Or set up an instance of apache that would just require configuration.
This is a horrible way to collaborate though... like dropbox sharing...   you could also dropbox share... I believe it is possible to run a dropbox daemon on raspbian, and conrol where the shared folder is located... so it could just  be under tipi_disk/DROPBOX
Or you could mount an FTP folder under tipi_disk, and add an FTP server to your own raspberry pi...  username and password are supplied when you mount... or cached in a config file...
Or you could just learn something easier than git, like subversion... checkout the source your want to collaborate under tipi_disk... use a side workflow to benefit from actual version control.  anything with an ssh server on it can be a git or subversion server.
-M@
#3 mizapf OFFLINE
mizapf
  • 3,666 posts
Posted Fri Apr 19, 2019 4:33 PM
Presenting a password in the URL is considered deprecated: https://tools.ietf.org/html/rfc3986(section 3.2.1).
#4 jedimatt42 OFFLINE
jedimatt42
  • 2,023 posts
Posted Fri Apr 19, 2019 5:58 PM
It is also just a bad idea... :)
-M@
#5 Shift838 OFFLINE
Shift838
  • 2,586 posts
  • SHIFT838
Posted Fri Apr 19, 2019 8:10 PM
I would also wonder if there are multiple developers of a project then there really should be some type of check-in / check-out method to ensure that more than 1 developer could not check it out at a time.  This would also allow some type of version control maybe.
#6 jedimatt42 OFFLINE
jedimatt42
  • 2,023 posts
Posted Sat Apr 20, 2019 9:54 AM
That's why you should just use git, or subversion...
-M@
#7 Asmusr OFFLINE
Asmusr
  • 3,144 posts
Posted Sat Apr 20, 2019 11:56 AM
-M@
Yes. And there are lots of front-ends if you don't want to learn a command line interface.
