TI-99/4A doesn't power on, how to measure voltage
12 replies to this topic
#1 AmintaAtari OFFLINE
AmintaAtari
    Space Invader
  • 13 posts
Posted Wed Apr 24, 2019 6:28 PM
Hi all from Italy!
My TI-99/4A suddenly doesn't power up!
So I've disassembled the machine to isolate the internal power supply.
Now I have, as from the photos, the power supply and the external original transformer.
How can I test the voltage with my multimeter?
Where have I to insert the red probe and the ground probe to measure the voltage for the transformer and for the power supply?
You'll find all the photos attached...
Many thanks in advance!
Davide
Attached File  IMG_8669.JPG   1.07MB   1 downloads
Attached File  IMG_8658.JPG   1.14MB   1 downloads
Attached File  IMG_8659.JPG   588.74KB   1 downloads
Attached File  IMG_8663.JPG   647.05KB   1 downloads
Attached File  IMG_8666.JPG   887.83KB   1 downloads
Attached File  IMG_8668.JPG   674.67KB   1 downloads
  • RXB likes this
#2 HOME AUTOMATION OFFLINE
HOME AUTOMATION
    Moonsweeper
  • 435 posts
Posted Wed Apr 24, 2019 7:47 PM
For the A.C. transformer, black/red order does not apply...
Attached File  LOW.JPG   2.27MB   1 downloads
Attached File  HIGH.JPG   2.33MB   1 downloads
Attached File  CASE.JPG   2.46MB   1 downloads
But, this does not appear to match your P.S. board...
because this transformer's secondaries are isolated...
Edited by HOME AUTOMATION, Wed Apr 24, 2019 8:08 PM.
#3 HOME AUTOMATION OFFLINE
HOME AUTOMATION
    Moonsweeper
  • 435 posts
Posted Wed Apr 24, 2019 8:26 PM
This one is internally coupled...
Attached File  low.JPG   2.47MB   1 downloads
Attached File  high.JPG   2.47MB   1 downloads
Attached File  notapplicable.JPG   2.46MB   1 downloads
Attached File  case.JPG   2.52MB   1 downloads
#4 AmintaAtari OFFLINE
AmintaAtari
    Space Invader
  • 13 posts
Posted Thu Apr 25, 2019 4:33 AM
Ok, here its mine:
Attached File  6E6C6F59-67C8-4372-99D8-759D70E0160A.jpeg   2.01MB   1 downloads
#5 AmintaAtari OFFLINE
AmintaAtari
    Space Invader
  • 13 posts
Posted Thu Apr 25, 2019 4:34 AM
but it reads only 4
!Attached File  5685F504-A669-4123-A180-78E588E72349.jpeg   658.09KB   1 downloads
#6 Stuart OFFLINE
Stuart
    Dragonstomper
  • 881 posts
Posted Thu Apr 25, 2019 5:21 AM
but it reads only 4
Looks like you're measuring between pins 1 and 3 - and pin 3 isn't connected to anything (there's no metal pin where you've got the black probe). You're just picking up 4V of crosstalk.
#7 Stuart OFFLINE
Stuart
    Dragonstomper
  • 881 posts
Posted Thu Apr 25, 2019 5:37 AM
If you measure the voltages at the red/black/white wires on the PSU PCB, you should get:
-- across white and black - about 9V AC
-- across white and red - about 19V AC
You can measure the DC output voltages on the white 4-pin connector. The voltage on each pin is written in yellow on the PCB. Measure between the GND pin (black probe) and each of the other pins in turn (red probe). Make sure the probes don't slip and short between two pins! Make sure you set your multimeter to DC Volts for these. The voltages may be around 0.2V higher than stated as there is no load on the PSU.
#8 AmintaAtari OFFLINE
AmintaAtari
    Space Invader
  • 13 posts
Posted Thu Apr 25, 2019 6:34 AM
Ok, Ive changed the fuses and now the light on power supply works, here are the measures.Attached File  57E56C33-6D61-4DBD-88DD-C864FFF3EDE7.jpeg   530.46KB   0 downloadsAttached File  FE83739D-F8EE-4D7B-B3E9-5DBFF102093D.jpeg   565.56KB   0 downloadsAttached File  DCB863BE-CCB4-4B92-8BBD-B7711F213F0A.jpeg   607.14KB   0 downloadsAttached File  5140DC41-EE7F-438E-A4BE-E5A8D637BD4B.jpeg   619.03KB   0 downloads
#9 AmintaAtari OFFLINE
AmintaAtari
    Space Invader
  • 13 posts
Posted Thu Apr 25, 2019 6:36 AM
Ok, I get exactly these measures!
#10 AmintaAtari OFFLINE
AmintaAtari
    Space Invader
  • 13 posts
Posted Thu Apr 25, 2019 6:45 AM
Here are the measures on the transformer... why that 27v?
Attached File  612986C5-6F0F-40E2-86FF-2BBA27A58C86.jpeg   728.87KB   0 downloadsAttached File  A00663A6-522B-419C-976A-2CAB753DDE74.jpeg   677.08KB   0 downloads
#11 Lee Stewart ONLINE
Lee Stewart
  • 3,991 posts
Posted Thu Apr 25, 2019 6:58 AM
The total voltage across the secondary of the transformer is the sum of the divided voltages—especially with just one center tap.
...lee
#12 AmintaAtari OFFLINE
AmintaAtari
    Space Invader
  • 13 posts
Posted Thu Apr 25, 2019 7:00 AM
The total voltage across the secondary of the transformer is the sum of the divided voltages.
...lee
Many thanks for the explanation and for your help!!
#13 Lee Stewart ONLINE
Lee Stewart
  • 3,991 posts
Posted Thu Apr 25, 2019 7:26 AM
...lee
I should say that your measurements imply a center-tapped secondary:
18.7v + 8.5v = 27.2v
...lee
