CF7+ and TIDir questions
8 replies to this topic
#1 InfernalKeith OFFLINE
InfernalKeith
    Dragonstomper
  • 737 posts
Posted Mon Apr 29, 2019 6:58 AM
I just got my CF7+ out after a few years' disuse, and fired it up.  It works!  All the files that were on it are still there.  But I'm a little confused by how it interacts with TIDir and I'm hoping one of you can verify that I'm doing this right, and/or explain its proper use to me like I'm six years old and not too bright.
So when I access the CF7 with TIDir, should I "mount" the drives, which then dumps those files into DSK1, DSK2, DSK3, etc?  And then would I initialize the CF7 volumes and create a new DSK image to move things back over to the CF card?
I tried loading a BASIC program from cassette, saving it to DSK1 on the CF, and mounting the drives in TIDir.  The file was there, in its own separate disk image, and I had to "view file" and copy/paste the listing to get a working version into memory.
I feel like I'm missing something obvious, but whatever familiarity I had with using this thing is long gone.
If there's a previous thread or a tutorial elsewhere, I'd love to see it.  I'm feelin' kinda dumb this morning.
#2 FDOS OFFLINE
FDOS
    Moonsweeper
  • 283 posts
Posted Mon Apr 29, 2019 8:41 AM
What?  I'm normally very confused each morning, but I don't experience any improvement through out the day due to my age and health.  However, you've really confused me, as I don't know how you're "mounting" DSK1., DSK2., & DSK3. using TIDir (TI99Dir by Fred Kaal?) or some other program I've not heard of before?  Anyway, you said nothing about removing the actual CF card from your CF7+ side car in order to mount it in a CF card adapter attached or internal to a PC.  So, can you, please clear up my foggy brain, just a little?
Bill
#3 arcadeshopper OFFLINE
arcadeshopper
  • 4,398 posts
Posted Mon Apr 29, 2019 11:20 AM
You are not dumb. the CF7/Nano file system is just not intuitive at all.
In tidir you mount the CFcard itself and then you can interact with it. make sure you back it up first with the copy cf image function.  just in case.. you can also mount that image and work with it directly then copy it back to the card in one swoop if you like..
mounting DSK1,2,3 is just tidir setting those disks as mounted when you plug it back into your TI, I found this to be basically irrellevent and didn't even seem to work on mine I still had to call mount(1,3) whatever on the TI once the card was back in
so in TIdir you just select which disk you want to copy too and then you can copy disks to it.. (to the card) in the image you can actually click into the disk on the cf image and copy individual files to it.  easier
Greg
#4 InfernalKeith OFFLINE
InfernalKeith
    Dragonstomper
  • 737 posts
Posted Mon Apr 29, 2019 11:30 AM
Sorry for the confusion, Bill, I think I was a little groggy myself when I wrote that this morning.  I think I've figured it out with some more trial and error.  It's not a very intuitive system and I haven't done much with TIDir, so I think my relative unfamiliarity with handling .dsk images was confusing matters for me.  It's hard to go away and come back, I seem to lose everything more difficult than "OLD CS1" every time I do!
#5 Lee Stewart ONLINE
Lee Stewart
  • 3,990 posts
Posted Mon Apr 29, 2019 12:21 PM
Presuming you are reading the CF7’s CF card mounted in a card reader plugged into your PC with TI99Dir, mounting the volumes does not “dump those files into DSK1, DSK2, DSK3, etc.”  Rather, it pops up a dialog box showing which volumes are associated with, i.e., mounted as, DSK1, DSK2, DSK3 and allowing you to change which volumes you would prefer to appear as DSK1, DSK2 and DSK3 when that CF is plugged into your CF7, which, in turn, is plugged into your TI-99/4A.  You can only mount 3 volumes at a time because there are only 3 virtual disk drives (DSK1,DSK2,DSK3).
You may but do not need to initialize a CF7 volume on the CF card before copying an image file from your PC to a volume slot on the CF card.  The only way on your PC to copy files to a CF-card volume is to create a CF7 DSK image on your PC, copy TI files into it and copy the image to a volume slot on the CF card.  If you have an existing volume to which you wish to add files from your PC, you should first copy the relevant volume from the CF card to your PC, add TI files to the copied image and copy said image back to the volume slot from whence it came.
I am really not sure what you are doing here.  If you loaded the Basic program from cassette on the TI-99/4A and saved the program to CF7 DSK1, again on the TI-99/4A, that same file should be loadable from DSK1 on the TI-99/4A.  No separate mounting in TI99Dir is necessary.
Also, I am not aware that you can view any files from a CF7’s CF card volume in TI99Dir.  I have the latest version of TI99Dir (v6.4a) and all you get to see is a listing of the volumes with their names and some other relevant information, but you cannot drill down to a file list for any one volume.  You can initialize, mount and copy volumes, but, if you want to see the contents of a volume, you must first copy it to your PC and open up that copied image to see its file listing or an individual file’s contents.
...lee
#6 mizapf OFFLINE
mizapf
  • 3,665 posts
Posted Mon Apr 29, 2019 12:44 PM
May I - just for the sake of completeness and as a humble alternative - mention that TIImageTool can handle CF7 images?
#7 Ksarul OFFLINE
Ksarul
  • 5,318 posts
Posted Wed May 1, 2019 6:44 PM
I use TIImageTool all the time. . .it is seriously intuitive.  :)
#8 Lee Stewart ONLINE
Lee Stewart
  • 3,990 posts
Posted Wed May 1, 2019 9:17 PM
I like just about everything about TI Image Tool.  It is, indeed, very useful and intuitive—except for CF7+/nanoPEB images.  The way TI Image Tool handles CF image transfers is excruciatingly slow because one must transfer the entire CF image, even for a single volume—good for backups, perhaps, but a non-starter for single volume manipulation.  TI99Dir, on the other hand, reads the CF’s volume list and transfers one volume at a time in either direction.  The TI Image Tool manual explains the reason it transfers only entire CF images, but I have been using TI99Dir for single-volume transfers for a long time now with no ill effect to date.
...lee
#9 mizapf OFFLINE
mizapf
  • 3,665 posts
Posted Thu May 2, 2019 5:04 AM
This is a good point. I actually have some ideas for speeding up the compact flash handling: It is possible to write just the blocks that have changed, which would make it considerably faster. However, I did not carry on with it because a) I don't have a CF7 device and b) I had some doubts that there is a significant interest in the CF7 support in TIMT. If there is, I could have some good reason to resume the work.
