Problem running SAMS TI-Nopoly on console
SAMS Classic 99 TI-Nopoly
10 replies to this topic
#1 twoodland OFFLINE
twoodland
    Moonsweeper
  • 277 posts
Posted Thu May 2, 2019 6:29 AM
Good day everyone.  I need your help!  What am I doing wrong?
Goal: To play TI-Nopoly on real iron.
Issue: Loading EA5 "ABOOT" on Classic 99 loads menu option E "TI-Nopoly".  Loading the same file from the TI Console does not load option E.
Hypothesis:  The AEMS boot script is not finding the SAMS memory.
CFG: TI-99/4A console w/Speech Synth, PEB (FlexCable Interface, TI32K, TIRS232, TIPI-PEB, SAMS 1024K, TIDisk Controller)
Files in Directory:
Attached File  Files.JPG   65.39KB   2 downloads
Classic 99 Screen Shot 1:
Attached File  C99S1.JPG   37.68KB   2 downloads
Classic 99 Screen Shot 2:
Attached File  C99S2.JPG   29.7KB   2 downloads
Real Iron Screen Shot 1:
Attached File  RIS1.jpg   140.72KB   2 downloads
Real Iron Screen Shot 2:
Attached File  RIS2.jpg   116.48KB   2 downloads
#2 Asmusr OFFLINE
Asmusr
  • 3,144 posts
Posted Thu May 2, 2019 9:36 AM
Have you tried if other SAMS software is working? Dungeons of Asgard, for instance.
  • Attached File  DOA.dsk   180KB   5 downloads
#3 twoodland OFFLINE
twoodland
    Moonsweeper
  • 277 posts
Posted Thu May 2, 2019 9:49 AM
Asmusr,
Yes. I typically run RXB's "In The Dark" game:
Attached File  InTheDarkIntro.PNG   11.09KB   2 downloads
And just tried "Dungeons Of Asgard".  Thank you so much!!!
Attached File  DOA.JPG   72.93KB   3 downloads
#4 adamantyr ONLINE
adamantyr
  • 1,523 posts
Posted Thu May 2, 2019 10:16 AM
Does DOA use ABOOT, or it's own custom loader?
#5 Asmusr OFFLINE
Asmusr
  • 3,144 posts
Posted Thu May 2, 2019 11:02 AM
It's a custom loader.
#6 RXB OFFLINE
RXB
  • 3,600 posts
Posted Thu May 2, 2019 2:19 PM
ABOOT is a good menu program but I do not know if anyone fixed the issue of the address it starts in a XB cart or RXB or SXB as it ignores the Random Number Generator and non standard start of cart.
FW had the same issue why every XB game ran from FW always used the same exact random numbers., you never got random results ever.
Also it did not initialize all of XB variables or clear all of them, thus a very small number of XB programs crahsed, specially in RXB as it used odd address that
was not supposed to be the starting point of XB GPL code.
GROM ADDRESS >633B is the start address supposed to be used in any XB cart. If I remember (I could be wrong) ABOOT and FW and MENU were using >63D3
Edited by RXB, Thu May 2, 2019 2:20 PM.
#7 Tursi OFFLINE
Tursi
  • 5,664 posts
  • HarmlessLion
Posted Thu May 2, 2019 11:44 PM
I have to note I don't know very much about the ABOOT and the AEMSSYS boot script - but did you try looking at the latter to see if there is any hard-coded paths that don't apply to your machine?
#8 atrax27407 OFFLINE
atrax27407
  • 1,272 posts
Posted Fri May 3, 2019 4:23 AM
It is probably an error in AEMSSYS not pointing to the correct pathname. Give us a look at your AEMSSYS file.
#9 twoodland OFFLINE
twoodland
    Moonsweeper
  • 277 posts
Posted Fri May 3, 2019 4:24 AM
Success!  Thanks to all of you for your help!  It ended up being a simple issue that I had overlooked.  If you look at my files screenshot. The AEMSSYS script file has the Attibute of "Classic".  I converted this file to TIFILES and it loaded on the console.  I feel embarrassed, but am very thankful for your input.
#10 twoodland OFFLINE
twoodland
    Moonsweeper
  • 277 posts
Posted Fri May 3, 2019 4:28 AM
atrax27407 FYI here is the contents of the AEMSSYS file.  Last night I noticed that it had the attribute of "Classic" so I converted it to TIFILES format using Ti99Dir and it the console was able to read the file
* AEMS Boot Script
RAM 1024
SW99
MENU DSK1.TIN_A,'TI-Nopoly'
#11 Tursi OFFLINE
Tursi
  • 5,664 posts
  • HarmlessLion
Posted Sat May 4, 2019 6:48 AM
Grr, I asked Fred not to do that... it's not a Classic99 file, it's a corrupted file header.
Oh well, glad you found the issue!! :)
Also tagged with one or more of these keywords: SAMS, Classic 99, TI-Nopoly
