Programming Instruction Issue
1 reply to this topic
#1 BeeryMiller ONLINE
BeeryMiller
    Dragonstomper
  • 953 posts
Posted Fri May 3, 2019 12:09 PM
OK, need to figure out how to pass a status bit back to a piece of calling code from another BLWP instruction using an XOP on the Geneve.
Basically, code is as follows:
START LWPI  >F000
ST1      BLWP @KSCAN
             JNE    NEWCODE
             JMP    ST1
NEWCODE
              Etc.............
KSCAN, >F020,KSCAN0
KSCAN0
               CLR  @KSTAT
               CLR  R0
                XOP  @KEY,0
                JEQ   KS2
                MOVB @H04,@KSTAT
                MOV   @KSTAT,R15
KS2         RTWP
KEY       DATA 5
H04        BYTE >04
               EVEN
My code does not seem to recognize the status bit (bit 3) is set.  Is there something I am overlooking?
Beery
#2 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,467 posts
Posted Fri May 3, 2019 3:23 PM
If memory serves correctly, I think you want to reset/set the EQ bit, not the status bit.  Something like this.
HB20  BYTE >20
SZCB @HB20,R15  - clear the bit when you enter the routine
SOCB @HB20,R15 - set the bit before exiting, based on condition
  • RXB likes this
