Joystick question
7 replies to this topic
#1 waderain OFFLINE
waderain
    Space Invader
  • 27 posts
Posted Mon May 6, 2019 1:20 PM
anybody have some good simple smooth code for controls that only go left, right, up and down. No diagonal control
I've been experimenting but nothing I've done works very well.
#2 Random Terrain ONLINE
Random Terrain
    Visual batari Basic User
  • 29,020 posts
  • Controlled Randomness
    Replay Value
    Nonlinear
Posted Mon May 6, 2019 9:07 PM
If I was doing it, I'd have a bit for left/right and a bit for up/down. If the up/down bit is on, don't look at left/right movement. If the left/right bit is on, don't look at up/down movement.
#3 Nukey Shay OFFLINE
Nukey Shay
    Sheik Yerbouti
  • 21,966 posts
Posted Sat May 18, 2019 2:33 AM
Something like this?
 if joy0up || joy0down then playery=playery+joy0up-joy0down:goto skiphoriz
 playerx=playerx+joy0right-joy0left
skiphoriz
If you want left/right to have priority, use those first.
Edited by Nukey Shay, Sat May 18, 2019 2:34 AM.
#4 Random Terrain ONLINE
Random Terrain
  • 29,020 posts
    Replay Value
    Nonlinear
Posted Sat May 18, 2019 5:36 AM
 if joy0up || joy0down then player0y=player0y+joy0up-joy0down:goto skiphoriz
 player0x=player0x+joy0right-joy0left
skiphoriz
Those joystick thingies can only be used in if-thens. You get an Unresolved Symbol error if you try to use them in other ways.
#5 Random Terrain ONLINE
Random Terrain
  • 29,020 posts
    Replay Value
    Nonlinear
Posted Sat May 18, 2019 7:06 AM
This works, but there's probably a better way to do it:
   ;  Variable aliases go here (DIMs).
   dim _Bit4_JoyU = y
   dim _Bit5_JoyD = y
   dim _Bit6_JoyL = y
   dim _Bit7_JoyR = y
   ;  Defines the edges of the playfield for an 8 x 8 sprite.
   ;  If your sprite is a different size, you'll need to adjust
   ;  the numbers.
   const _P_Edge_Top = 9
   const _P_Edge_Bottom = 88
   const _P_Edge_Left = 1
   const _P_Edge_Right = 153
   ;  Defines shape of player0 sprite.
   player0:
   %00111100
   %01111110
   %11000011
   %10111101
   %11111111
   %11011011
   %01111110
   %00111100
end
   ;  Sets starting position of player0.
   player0x = 77 : player0y = 53
__Main_Loop
   ;  Sets color of player0 sprite.
   COLUP0 = $9C
   ;  Skips up/down movement if player is moving left or right.
   if _Bit6_JoyL{6} || _Bit7_JoyR{7}  then goto __Skip_Joy0Down
   ;  Up movement check.
   if !joy0up then _Bit4_JoyU{4} = 0 : goto __Skip_Joy0Up
   if player0y > _P_Edge_Top then player0y = player0y - 1 : _Bit4_JoyU{4} = 1
__Skip_Joy0Up
   ;  Down movement check.
   if !joy0down then _Bit5_JoyD{5} = 0 : goto __Skip_Joy0Down
   if player0y < _P_Edge_Bottom then player0y = player0y + 1 : _Bit5_JoyD{5} = 1
__Skip_Joy0Down
   ;  Skips left/right movement if player is moving up or down.
   if _Bit4_JoyU{4} || _Bit5_JoyD{5} then goto __Skip_Joy0Right
   ;  Left movement check.
   if !joy0left then _Bit6_JoyL{6} = 0 : goto __Skip_Joy0Left
   if player0x > _P_Edge_Left then player0x = player0x - 1 : _Bit6_JoyL{6} = 1
__Skip_Joy0Left
   ;  Right movement check.
   if !joy0right then _Bit7_JoyR{7} = 0 : goto __Skip_Joy0Right
   if player0x < _P_Edge_Right then player0x = player0x + 1 : _Bit7_JoyR{7} = 1
__Skip_Joy0Right
   ;  Displays the screen.
   drawscreen
   goto __Main_Loop
Attached File  no_diagonal_movement.bas   2.76KB   3 downloads
Attached File  no_diagonal_movement.bin   4KB   5 downloads
#6 tabar OFFLINE
tabar
    Combat Commando
  • 7 posts
Posted Sat May 18, 2019 3:39 PM
how would this routine look in standard 2600 machine/assembly language.
#7 Nukey Shay OFFLINE
Nukey Shay
    Sheik Yerbouti
  • 21,966 posts
Posted Sat May 18, 2019 5:13 PM
A number of ways.  Dunno what bB's equates for player0x/player0y are, but a routine that favors left and right when diagonals are used goes like this:
   ldx player0x
   ldy player0y
   lda SWCHA
   asl
   bcs NotRight
   inx
   cpx #154
   beq DontSave
   bne Update
NotRight:
   asl
   bcs NotLeft
   dex
   txa
   beq DontSave
   bne Update
NotLeft:
   asl
   bcs NotDown
   iny
   cpy #89
   beq DontSave
   bne Update
NotDown:
   bmi DontSave
   dey
   cpy #8
   beq DontSave
Update
   stx player0x
   sty player0y
DontSave:
If you don't want -any- diagonals or button combos to be recognized at all, just use a table that throws away invalid directions:
   lda SWCHA
   lsr
   lsr
   lsr
   lsr
   tax
   lda Directions,x
   beq DontMove
   cpx #12
   bcc UpdateX
   clc
   adc player0y
   cmp #89
   beq DontMove
   cmp #8
   beq DontMove
   sta player0y
   bne End
UpdateX
   adc player0x
   beq DontMove
   cmp #154
   beq DontMove
   sta player0x
DontMove:
End:
;somewhere in rom tables:
Directions:
   .byte 0,0,0,0,0,0,0,1
   .byte 0,0,0,-1,0,1,-1,0
#8 tabar OFFLINE
tabar
    Combat Commando
  • 7 posts
Posted Yesterday, 8:01 PM
thank you.
