pixelmischief Posted May 7, 2019 Share Posted May 7, 2019 I'm debugging and at a break. The command is: .writemem "H:\Workbench\charmap.chr" $e000 L$400 Trying to dump the character set for a little tutorial-driven editing. Quote Link to comment Share on other sites More sharing options...
pixelmischief Posted May 7, 2019 Author Share Posted May 7, 2019 Figured it out. Don't use paths with spaces. No quotes fails on first space-separated word. Both single- and double-quotes are useless. Then, for a path that DOESN'T have spaces, don't forget to take off the quotes you previously tried to use on that other path WITH the spaces. .writemem H:\Workbench\charmap.chr $e000 L$400 This worked. 2 Quote Link to comment Share on other sites More sharing options...
phaeron Posted May 7, 2019 Share Posted May 7, 2019 This is a bug, I'll fix it for next version. The .readmem and .writemem commands are using the wrong argument type in the debugger command line parser. BTW, the parser doesn't use single quotes. It's always double quotes for quoting. 2 Quote Link to comment Share on other sites More sharing options...
pixelmischief Posted May 7, 2019 Author Share Posted May 7, 2019 This is a bug, I'll fix it for next version. The .readmem and .writemem commands are using the wrong argument type in the debugger command line parser. BTW, the parser doesn't use single quotes. It's always double quotes for quoting. Thanks, again, for this incredible software! 1 Quote Link to comment Share on other sites More sharing options...
