Any compressor between rle and lz4 ?
67 replies to this topic
#1 rensoup OFFLINE
rensoup
    Space Invader
  • 32 posts
Posted Mon May 13, 2019 1:06 PM
 Hi,
I'm just wondering if there's anything between these 2 as RLE just doesn't compress too well and LZ4 compresses well enough but is a little to slow when decrunching ?
Perhaps some modified form of RLE ?
Thanks
#2 dmsc OFFLINE
dmsc
    Dragonstomper
  • 533 posts
Posted Mon May 13, 2019 1:17 PM
Hi!
Hi,
Thanks
LZ4 should be as fast (or even faster) than RLE. Sure you are using an optimized implementation?
#3 rensoup OFFLINE
rensoup
    Space Invader
  • 32 posts
Posted Mon May 13, 2019 1:28 PM
Hi!
Really ? well I tried Fox and XXL's version, it's optimized for size so probably not for speed. It looks like it can decrunch about 200-300 bytes max per frame at 50fps.
The other problem with LZ4 for what I have in mind, is that it can't decrunch chunks as it uses previously decrunched data (while RLE can)
I would still be interested to get a faster version if you have one.
Thanks!
#4 Heaven/TQA OFFLINE
Heaven/TQA
  • 11,255 posts
Posted Mon May 13, 2019 2:00 PM
download the MADS assembler and have a look at the various crunchers.
me used exomizer, deflate, lz4 in the past but sticked now to c64 depacker called "B2" & pucrunch.
#5 CharlieChaplin OFFLINE
CharlieChaplin
  • 3,134 posts
Posted Mon May 13, 2019 2:06 PM
Do you want to depack movies with 50fps in realtime on A8 ?!? Could be a difficult task on the little Atari...
#6 Irgendwer OFFLINE
Irgendwer
  • 1,484 posts
Posted Mon May 13, 2019 2:45 PM
Three years ago I've created "autogamy" and used it to compress the level data for "dye". (Also used in "E-Type".)
Features:
* fast and compact depacker (using self modifying code)
* nearly as good as LZ4 - for small files often even better
* in-place decompression if the source data ends at least 4 bytes behind the end of the target buffer
* compression uses also self-referencing - so no streaming (windowing currently unsupported)
Archive contains packer for Windows (exe) and source-code for de-packer cc65 header / ca65 source.
You may like give it a try.
#7 rensoup OFFLINE
rensoup
    Space Invader
  • 32 posts
Posted Mon May 13, 2019 3:29 PM
I've started using MADS and indeed there's plenty of crunchers. I will take a closer look but perhaps some folks here have experience with them and can tell me if one of them fits the requirements?
Can't find any ref to "B2" but pucrunch/exomizer aren't quite what I'm after... way too slow to decrunch.
#8 rensoup OFFLINE
rensoup
    Space Invader
  • 32 posts
Posted Mon May 13, 2019 3:34 PM
Well there's various things I want to do... and decoding gfx data is one of them. A single 32x32 1 color sprite would take about half a frame to decode... That hurts.
#9 rensoup OFFLINE
rensoup
    Space Invader
  • 32 posts
Posted Mon May 13, 2019 3:43 PM
Features:
Thanks! :thumbsup:
I will give it a try for sure. Sounds like it would be a good fit for one of my use cases.
I've got another use case which requires -no- self-ref so I will look into what's in MADS and possibly have to try my own RLE variant (not even sure it will compress much better than RLE though)
#10 pirx OFFLINE
pirx
    Moonsweeper
  • 457 posts
Posted Mon May 13, 2019 4:15 PM
Do you know of any streaming compression of a decent quality - would be perfect for SAP Type-R sounds.
#11 dmsc OFFLINE
dmsc
    Dragonstomper
  • 533 posts
Posted Mon May 13, 2019 8:34 PM
Hi!
I don't understand this. LZ4 can be decompressed "almost" in place (with about 8 bytes of gap between compressed/decompressed data).
Thanks!
With a "small" (124 bytes) implementation, I get a little less than 49 cycles per byte, this is 500 bytes/PAL frame on GR.0 (the slowest possible), about 650 bytes/PAL frame without DMA. This is my main "copy" loop, in ZP:
        org     $80
docopy
	jsr	getsrc
dst = * + 1
	sta 	output_addr
	inc	dst
        bne     skip4
        inc	dst+1
skip4:
	dex
	bne	docopy
        dey
	bne	docopy
	rts
getsrc
src = * + 1
	lda     packed_data
	inc	src
        beq     skip5
        rts
skip5:	inc	src+1
	rts
Note that the "docopy" loop uses JSR to the read routine, and the pointer is incremented on each byte read/write, this is to minimize size.
You can implement it faster if you use indexed addressing, the main copy loop should be like:
docopy
	lda     source_addr, X
	sta 	output_addr, X
	inx
        bne     docopy
        dey
	bne	docopy
	rts
This would make 14 cycles/byte in the best case, so this is max about 1700 bytes/PAL frame. Certainly three times faster than my original code should be possible.
Attached is a sample source code, and a program that compressed a XEX file using LZ4 (windows/linux versions).
#12 xxl OFFLINE
xxl
  • 1,132 posts
Posted Tue May 14, 2019 12:14 AM
LZ4 is very fast
gpl3.txt - 35147 bytes
exomizer - 12382 bytes + depacker 1 page =~ 12.3 KB, decompress 128 frames (2.6 sec)
deflate - 11559 bytes + depacker 2 pages =~ 11.8 KB, decompress 179 frames (3.6 sec)
LZ4 - 15622 bytes + depacker <150  bytes =~ 15.3 KB, decompress 55 frames (1,1 sec)
there is also a bootloader with lz4 streaming decompression
#13 Irgendwer OFFLINE
Irgendwer
  • 1,484 posts
Posted Tue May 14, 2019 12:32 AM
Yes, but if the source data is bigger than the available target buffer memory (->streaming) you've lost. So you need something like windowing the data for the compression or no self-referencing at all.
#14 Heaven/TQA OFFLINE
Heaven/TQA
  • 11,255 posts
Posted Tue May 14, 2019 2:41 AM
are we talking about packing 32x4 bytes= 128 total? is there any chance to win here? as sprite data might be very pixelized. not sure if using compression helps here a lot? how many of those frames do you want to pack as stream? what is total size? I mean that's something we must know to find the "best" packer in your use case scenario.
#15 dmsc OFFLINE
dmsc
    Dragonstomper
  • 533 posts
Posted Tue May 14, 2019 8:30 AM
Hi!
Well, the LZ4 format codes two types of runs: literal runs and copy-over runs, so you can simply limit the window size to allow for streaming with any buffer size. Of course, the compression will be a lot worse with smaller windows.
In my code above I made an optimization: I replace the "copy distance" field with a "copy address" field (= position - distance), so the copy can be done directly. This also allows (by modifying the compressor) to use *any* place in the target memory as a source, so you could stream frames using the read buffer and the target screen, so you can send only changed bytes.
#16 rensoup OFFLINE
rensoup
    Space Invader
  • 32 posts
Posted Tue May 14, 2019 1:03 PM
Hi!
        org     $80
docopy
	jsr	getsrc
dst = * + 1
	sta 	output_addr
	inc	dst
        bne     skip4
        inc	dst+1
skip4:
	dex
	bne	docopy
        dey
	bne	docopy
	rts
getsrc
src = * + 1
	lda     packed_data
	inc	src
        beq     skip5
        rts
skip5:	inc	src+1
	rts
docopy
	lda     source_addr, X
	sta 	output_addr, X
	inx
        bne     docopy
        dey
	bne	docopy
	rts
Sounds interesting as well, 1700 bytes best case is a lot better for lz4. :thumbsup:
#17 rensoup OFFLINE
rensoup
    Space Invader
  • 32 posts
Posted Tue May 14, 2019 1:17 PM
LZ4 is very fast
well 15.3KB/ 55 =280 bytes per frame which is what I was seeing as well...
Sure it's faster than exomizer/deflate but they're at the far end of the spectrum when it comes to speed.
I was looking for something between lz4 & rle in terms of speed and compression ratio. Looks like I've got 2 possibilities with dmsc & irgendwer at least when it's ok for self referencing.
btw I tried compressing data with your rle implementation that I found in MADS, it seems to perform a litte worse than this one sometimes (files can be 1-10% bigger):
https://csdb.dk/release/?id=34685
#18 rensoup OFFLINE
rensoup
    Space Invader
  • 32 posts
Posted Tue May 14, 2019 1:33 PM
Ok, so I guess that was a little confusing. I mixed 2 use cases into one question.
My first use case was simple:
Like pirx said a decent streaming compression scheme would be perfect for SAP-R which exactly what I was trying to do!
lz4 deinterleaved Pokey data compresses pretty well... so I modified XXL's lz4 decompression code to only output 9 bytes per frame only to realize that it didn't work because it was trying to copy data that I'd already discarded (yeah I know very little about compression :) )
I also realized that it was taking about 10 scanlines to output 9 bytes!
I had another use case in mind (compressing sprites) but at 300 bytes/frame, it just wouldn't cut it either. With the code posted before, I have hope for this one.
#19 rensoup OFFLINE
rensoup
    Space Invader
  • 32 posts
Posted Tue May 14, 2019 1:47 PM
Indeed, not what I want to do at all though... sorry for the confusion :arrow:
Yes unfortunately for SAP-R, the window has to be 128-256 bytes for any decent compression, 128 *9 *2 =~2.3KB just for buffers, you're starting to lose the benefit of the compression. I get the feeling that the code would be clunky too. A cheaper compressor might do just as well.
#20 elmer OFFLINE
elmer
    Chopper Commander
  • 207 posts
Posted Tue May 14, 2019 2:48 PM
You might want to take a look at the wikipedia article for LZSS to understand the basic idea behind all of the compressors that you've been looking at (beyond RLE).
It's a really simple concept, but, as you've found, you need to keep the decompressed data around in order to be referenced.
This usually isn't a problem, but you do need to know that you've got to do that.
Pure LZSS might be what you're looking for. The compression ratio is worse than LZ4, but the coding for the decompressor is absolutely trivial.
It is what a lot of games in the late 1980s and early 1990s used before programmers tweaked the details of the algorithm to get even better compression, but at some cost in speed.
LZ4 was optimized for speed of compression/decompression for use in realtime on 32-bit CPUs ... I've yet to find a case where it actually makes sense to use it on 8-bit or 16-bit computers/consoles.
Something like Jorgen Ibsen's aPlib offers better compression, with only a little extra cost in speed ... and if you really need the speed, then pure LZSS is hard to beat.
As you've pointed out, to get good decompression speed with any of the LZSS variants, you've got to make good use of the X and Y index registers and self-modifying code. You'd also be advised to avoid subroutine calls and inline, if possible.
You can find the C source for an LZSS compressor (from Mark Nelson's book) here...
https://github.com/v...src/Game/LZSS.C
#21 ChildOfCv OFFLINE
ChildOfCv
    Moonsweeper
  • 404 posts
Posted Tue May 14, 2019 2:53 PM
Did you benchmark LZO?  It's supposed to be designed around decompression speed.
Also, if the idea is just to blast this to the screen as you decompress, you could even add a special flag to the decompressor which says "Move to this address before continuing to decompress".  Then you can just let the decompression loose on an entire run of data to do a frame update without having to write "same" data to parts of the screen.
#22 dmsc OFFLINE
dmsc
    Dragonstomper
  • 533 posts
Posted Tue May 14, 2019 3:22 PM
Hi!
Look at the attached program, it is a (really simple) animation with 128 frames of 7680 bytes each. The compressor uses the current frame and the last one as reference, so streaming output is possible. Attached is the C program that compresses the video and the and decompressor ASM source.
#23 dmsc OFFLINE
dmsc
    Dragonstomper
  • 533 posts
Posted Tue May 14, 2019 6:42 PM
Hi!
Here is a somewhat optimized version, it decompresses at 126 228 cycles / frame, this is 16.4 cycles/byte (so, about 9.5 fps in PAL, 9.0 fps in NTSC)
It could be optimized a little more, but I doubt more than about 15%.
#24 xxl OFFLINE
xxl
  • 1,132 posts
Posted Wed May 15, 2019 12:15 AM
no.
compressed data: 15kb
decompresed: 35147 bytes
so: 35147 / 55 = 639 bytes
#25 Heaven/TQA OFFLINE
Heaven/TQA
  • 11,255 posts
Posted Wed May 15, 2019 10:26 AM
now that's nice.
Hi!
1 user(s) are browsing this forum
0 members, 1 guests, 0 anonymous users
