Z80 MATH?
8 replies to this topic
#1 Mike Harris OFFLINE
Mike Harris
    Chopper Commander
  • 246 posts
Posted Thu May 16, 2019 6:47 PM
Can someone post some code that would check if greater than in Z80 Assembly?
I know CP  if I want to check if say A = ? but how do you find out if a number is > or <.
I looked it up on google and I get no examples.
BOB: EQU 100
LD A, BOB
CP A, 100
JP Z, YAKITY
If BOB was greater than 100 without CP 101, 102, 103 and so on.
And equally if BOB Was less than 100
UPDATE...
Figured a solution but I welcome alternatives.  Maybe there is a better way.
Edited by Mike Harris, Thu May 16, 2019 7:38 PM.
#2 nanochess ONLINE
nanochess
    Processorus Polyglotus
  • 5,898 posts
  • Coding something good
Posted Thu May 16, 2019 9:10 PM
CP 100
JP NC,GREATEROREQUAL
; HERE IF LESS THAN
CP 100
JP C,LESSTHAN
; HERE IF GREATER OR EQUAL
#3 Mike Harris OFFLINE
Mike Harris
    Chopper Commander
  • 246 posts
Posted Thu May 16, 2019 9:40 PM
CP 100
; HERE IF LESS THAN
CP 100
JP C,LESSTHAN
too insane it is that easy
Edited by Mike Harris, Thu May 16, 2019 9:48 PM.
#4 artrag ONLINE
artrag
  • 1,286 posts
Posted Fri May 17, 2019 12:45 AM
If A and the value to be compared, say B, have sign (i.e. can be negative and are restricted to -128,127) the conditions to test is m (A<B) or p (A>=B).
Note that they are supported by JP and not by JR.
May be an example may help
LD A,-1
CP 1
JP m,isless ; true as A<1
Last condition is true, but note that here C is reset, and the test is interpreted as:
LD A,255 ; same as - 1 in binary
CP 1
JP NC,isbiggerorequal ; true as 255>1
Edited by artrag, Fri May 17, 2019 1:29 AM.
#5 carlsson ONLINE
carlsson
    Metagalactic Mule
  • 8,997 posts
Posted Fri May 17, 2019 1:34 AM
For that matter, checking the carry flag is how you usually determine if something is smaller/larger in any contemporary architecture, let it be Z80, 6502 or anything else. The amount of flags might differ but generally Z for zero and C for carry use to exist.
#6 artrag ONLINE
artrag
  • 1,286 posts
Posted Fri May 17, 2019 1:42 AM
True but if you do not deal with signs you will incurr in errors.
The Z80 has the S flag that is a copy of the highest bit of the result and can be tested by m and p conditions.
#7 nanochess ONLINE
nanochess
  • 5,898 posts
Posted Fri May 17, 2019 9:25 AM
Let us just remind that in 6502 the comparison sense is reversed. C is set when greater than equal, and clear when less than.
Also in Z80 the usage of S for signed comparison only works with numbers between -64 and 63, otherwise it will fail miserably.
If you want to do proper signed comparison you should do this:
xor $80       ; value to be compared
cp $e4        ; $64 xor $80
jp c,lessthan
; here greater than or equal
#8 artrag ONLINE
artrag
  • 1,286 posts
Posted Fri May 17, 2019 11:28 AM
jp c,lessthan
True, I should have added that one should test both S and Overflow for full range comparisons
http://www.z80.info/zaks.html
#9 ChildOfCv OFFLINE
ChildOfCv
    Moonsweeper
  • 404 posts
Posted Fri May 17, 2019 12:22 PM
It typically depends on how the ALU works.  Intel and Z80 set the C flag for either carry or borrow.  The PIC and 6500 lines set carry on add if it overflows, but set carry on subtract when there is NO borrow.
