Power base mini and clone consoles
5 replies to this topic
#1 envytomdead2 OFFLINE
envytomdead2
    Space Invader
  • 37 posts
Posted Thu May 16, 2019 7:17 PM
I have a retron 3 and noticed minor graphical glitches on pretty much all master system games. I am using a power base mini. I gave also seen the same thing in videos for the retro trio plus and mini gen HD. Is this a power base mini bug or do all of these clones have the same bug? Has anyone tried another converter with these clones? Same results? Different?
#2 godslabrat OFFLINE
godslabrat
  • 5,620 posts
  • I took the midnight train going a-ny-where...
Posted Thu May 16, 2019 8:52 PM
The power base converter is just a pinswap, it does no processing on its own, nor does any variant of it. If you're having issues, it's due to the clone console itself. SOAC clones are known for minor glitches, it's just a matter of your tolerance for them.
#3 envytomdead2 OFFLINE
envytomdead2
    Space Invader
  • 37 posts
Posted Fri May 17, 2019 5:55 AM
I know it's just a pass through but Genesis tends to run very smooth so I found it weird that sms games so consistently had those minor glitches. That being said I threw a lot of sms games and it did play everything except afterburner and cloud master.
Edited by envytomdead2, Fri May 17, 2019 6:03 AM.
#4 derFunkenstein OFFLINE
derFunkenstein
  • 1,533 posts
Posted Mon May 20, 2019 7:40 AM
All those clones most likely use the same faulty GoaC that's doing something to the Master System games.
#5 envytomdead2 OFFLINE
envytomdead2
    Space Invader
  • 37 posts
Posted Tue May 21, 2019 5:28 AM
I think I am beginning to realize all of these clone systems are relatively the same. If I want flawless master system a modern tv, I am going to have to go with the mega sg or an emulation based solution like the retron 5. That being said the glitches are pretty minor.
#6 godslabrat OFFLINE
godslabrat
  • 5,620 posts
Posted Tue May 21, 2019 8:01 AM
Agreed on all counts.
