Mike Harris' Blog - The old Porkchop Express!
No replies to this topic
#1 RSS Bot OFFLINE
RSS Bot
  • 9,531 posts
Posted Thu May 16, 2019 10:42 PM
The title of course has nothing to do with my entry.
New update coming soon.
As far as I can tell all mapping bugs have been fixed.
When I upload the new rom then you tell me what you find.
No more going through or getting caught in walls.
Kids...This was a huge pain in the %%%.
The interesting thing is is when I finished and optimized the check routines it seems so simple.
Just like replacing Spock's brain...A child could do it.
The great part is that I can use these routines in all my new games coming.
Still have to incorporate Diagonal movement and then the new rom will be released.
Next will be optimize pick up routine which I plan to have directional pickup.
As in pick up from the left then item will be on the right and so forth.
Here is a sample of my movement code.
 NORTH:
    LD A, 01
    LD (DIRECTION_RAM), A
    LD A,(SPRTBL)
    SUB A, 02                   ; Y Offset
    LD (SPRTBL),A
    CALL MAP_TO_SPRITE          ; Get Pattern, Wall?
    AND A
    JP NZ, WALL_NORTH           ; Hit North Wall
    LD A,(SPRTBL+1)
    ADD A, 09                   ; X Offset
    LD (SPRTBL+1),A
    AND A
    JP NZ, WALL_NORTH_2         ; Hit North Wall Offset
    LD A,(SPRTBL+1)
    SUB A, 09                   ; Return X Value
    LD (SPRTBL+1),A
    LD A,(SPRTBL)
    DEC A                       ; Return Y Value + Move North
    CP 02                       ; Check Screen Edge
    JP C, GOING_NORTH           ; Going North
RET
WALL_NORTH:
    LD A,(SPRTBL)
    ADD A, 03                   ; Bounce Player, Return Y Value
    LD (SPRTBL),A
RET
WALL_NORTH_2:
    LD A,(SPRTBL+1)
    LD (SPRTBL+1),A
    LD A,(SPRTBL)
    LD (SPRTBL),A
RET
GOING_NORTH:
    LD A, 182
    LD (SPRTBL),A               ; Player to the Bottom
    LD C, 01
    CALL PRINT_ROOM
RET
http://atariage.com/...rkchop-express/
