Current program to open *.ARC files?
3 replies to this topic
#1 6BQ5 OFFLINE
6BQ5
    Moonsweeper
  • 302 posts
Posted Fri May 17, 2019 8:26 AM
I downloaded some compressed files in *.ARC format. None of them open with PeaZIP, which should support ARC. Can someone recommend a Win10 program that can decompress them?
Thanks! :)
#2 rdea6 OFFLINE
rdea6
  • 2,836 posts
Posted Fri May 17, 2019 8:32 AM
Altirra Emulator open as disk from D1:
If small enough to fit in an ATR copy paste to Atr file and open with SpartaDos X  ARC V FILENAME.ARC
#3 Nezgar OFFLINE
Nezgar
  • 1,974 posts
Posted Fri May 17, 2019 9:30 AM
Altirra can actually mount a .ARC directly if mounted into a drive slot.
For windows try: https://www.izarc.org
Also, check this thread: http://atariage.com/...aded-arc-files/
#4 6BQ5 OFFLINE
6BQ5
    Moonsweeper
  • 302 posts
Posted Sat May 18, 2019 4:13 PM
IZArc seemed to do the trick. Thanks, everyone! :)
There is a glitch when un-ARC'ing multiple files by selecting them and right clicking. Suppose you select 10. If file #6 is corrupted then IZArc aborts. Files #7 - #10 remain untouched.
