Apple IIGS (And others?) Best Battery Kit: No solder, off board, lithium.
2 replies to this topic
#1 @RealActorRob OFFLINE
@RealActorRob
    Space Invader
  • 14 posts
Posted Fri May 17, 2019 10:19 AM
I've sold at least 10, maybe 15 or so on Ebay with no complaints, only positive feedback:
https://www.ebay.com/itm/293012012749
The issue: the IIgs ROM 1 uses a soldered lead lithium battery. Why, Apple?!
This kit lets you clip the battery leads, press on two very tight fitting wires that won't slip off or short other things like alligator clips would, and the other end press fits onto a PRAM type 3.3V lithium battery holder you can mount where you like. Zip tie to power cable, tape, etc.
Lithium also probably won't leak ever, unlike those AA kits that are also much larger.
So:
No desoldering
No leaking
No potential shorts
No soldering
Mount where you like
I did this to solve all the things I didn't like, so, I'm not just the inventor, I'm a user. :)
#2 CGQuarterly OFFLINE
CGQuarterly
  • 4,911 posts
  • Editor - Classic Gaming Quarterly
Posted Fri May 17, 2019 1:51 PM
That's a pretty good solution!  I'd grab one, but I just changed the battery in my IIgs, so I'm good for a while.
#3 @RealActorRob OFFLINE
@RealActorRob
    Space Invader
  • 14 posts
Posted Mon May 20, 2019 8:44 PM
PM me I can knock a little off vs. paying the Ebay fees or if you just want the wires and socket you can get the battery when needed down the road. Sorry you had to unsolder/solder yours...I was too late! ;)
