Posted Tue Aug 7, 2001 7:46 AM
How exactly is this done?
Here is my guess. Even if I'm wrong, I'd like to talk about how best to do this since 4 players is quite limiting.
Anyway, I've read that if you know that 2 objects will be on different horizontal planes, that this is the best time to split the sprite. IS it done via a DLI? IN other words, put a DLI halfway down the screen, and the DLI routine changes the player bitmap to the 2nd object, and changes its location in memory? Then at line 1, the swapping occurs again?
Or perhaps it is done in conjunction with careful timing of the which scanline you are on? (note that I currently have no clue how to implement this kind of coding)? Or is there a whole other (and hopefully, Better) way?
Oh btw, my first game (which is no longer titled "Firefighter") probably won't need to implement this kind of sprite/player swapping, but I'd still like to get an idea of how to do it. Like in Joust, all those birds are just 4 players?! I notice that when they get on the same horizontal plane, swapped/split players start to blink. Perhaps this is why the Pac-Man 2600 ghosts flicker? Every ghost is draw every 4th frame?
Thoughts are welcome!
