laito69 Posted May 14, 2001 Share Posted May 14, 2001 hi you all. my lynx 2 is not working very well. i think the A and B buttons are stuck, because they keep firing even when i am not pressing them. if anyone knows how to fix this, please let me know. Luis david meneses luisdavidmeneses@hotpop.com Quote Link to comment Share on other sites More sharing options...
dollopx Posted May 15, 2001 Share Posted May 15, 2001 I have a similar problem with my UP button, it sticks. My brother's Lynx's A button sticks. Sorry I can't help, but I was just expressing the fact that your not the only one with a dodgy Lynx II Quote Link to comment Share on other sites More sharing options...
Gunstar Posted May 23, 2001 Share Posted May 23, 2001 This is generally caused because under the plastic buttons and D-pad are "rubber bubbles" that keep the contacts seperated until you depress the button. Over time with a lot of use, these "bubbles" wear out and crack at the seem, so then the contacts are constantly touching. So either the bubbles need to be replaced(and many times you can use "bubbles" other than the original equipment),(got an old joypad from some other sytem you don't use? Try replacing it with a "bubble" out of one of them), or what I did when a joypad of mine had this problem, was to open up the unit, take the "bubble" out(removing any lose rubber peices or rings), and then use a drop of superglue to actually glue the contact to the bottom side of the plastic button or D-pad. It will not feel exactly the same as it used to, and you may need to put an old spring under the button or D-pad(like a spring from a key on an old computer keyboard). But your "sticking" problem will be cured and the unit will be usable again. Hope this helps. Gunstar Quote Link to comment Share on other sites More sharing options...
