sly Posted June 14, 2001 Share Posted June 14, 2001 I have an Atari and an Intellivision that are doing similar things. On the Atari 2600 the graphics are coming through scrambled on a portion of sprites and scores. For example the Atari Space Invader Aliens are inorganized and partially on top of each other. Does anyone know what could be wrong and a way to fix it? With the Intellivision system Donkey Kong's Mario is a scrambled square and the Barrels look like dead birds. I want to know if anything can be done. I've tried cleaning the cartridge area inside and it has no effect. Quote Link to comment Share on other sites More sharing options...
Joel D. Park Posted June 15, 2001 Share Posted June 15, 2001 Intellivision donkey kong was such a poor port, that's probably what the graphics are supposed to look like :-). Actually, if both systems are having the same problem, perhaps you have a power issue with the recepticle you are using. I can't imagine that the power would make much difference on Atari's 9VDC ouput but you never know, you might try a different recepticle. It's not the whole screen right?? Just certain sprites on the screen? I don't know. Quote Link to comment Share on other sites More sharing options...
JagDiesel Posted June 15, 2001 Share Posted June 15, 2001 Could be a switchbox problem if you're using an older switchbox. The same problem with both systems usually denotes a non-system related problem, and those usually are the easiest to take care of. Quote Link to comment Share on other sites More sharing options...
