Madhatter Posted June 9, 2001 Share Posted June 9, 2001 Visiten mi página WEB y vean cómo fabriqué mi propio Cartridge Atari 2600 160 en 1. How I built my Custom Atari 2600 Cartridge. http://es.geocities.com/gamemasterquilpue/...wnataricart.htm myownataricart Quote Link to comment Share on other sites More sharing options...
Alex Posted June 9, 2001 Share Posted June 9, 2001 That wiring looks insane! Nice job. Ese cableado parece insano! Trabajo de Niza. Quote Link to comment Share on other sites More sharing options...
khryssun Posted June 9, 2001 Share Posted June 9, 2001 Impressive work man I hope that will work with a 27C4001 (that should). Do you plan to design a completed circuit board lay-out ? that's would be really GREAT just a question : Why using 10 kohm resistors ? (Bob colbert's schematics use 1 Kohm resistors) Quote Link to comment Share on other sites More sharing options...
khryssun Posted June 9, 2001 Share Posted June 9, 2001 Trabajo impresionante hombre. Espero lo que trabajará con un 27C4001 (que debería). ¿Ud planifica diseñar una exposición de tarjeta de circuitos impresos completada? Esto ES serían realmente GRANDE Solamente(justo) una pregunta: ¿Por qué utilización 10 kohm resistencias? (Schematics del colbert's de Roberto usa 1 Kohm resistencias) Quote Link to comment Share on other sites More sharing options...
Madhatter Posted June 10, 2001 Author Share Posted June 10, 2001 quote: Originally posted by khryssun: Impressive work man I hope that will work with a 27C4001 (that should). Do you plan to design a completed circuit board lay-out ? that's would be really GREAT just a question : Why using 10 kohm resistors ? (Bob colbert's schematics use 1 Kohm resistors) Quote Link to comment Share on other sites More sharing options...
Madhatter Posted June 10, 2001 Author Share Posted June 10, 2001 OK, Mr. Colbert usa 1K resistors, para tres switches. Pero él utiliza una memoria 27256, con entradas TTL, y debe usar resistores de 1 K. En mi circuito, se trata de memorias con entradas CMOS, por lo que no tiene sentido usar resistores tan pequeños como 1 K. De hecho, en el board original, la memoria es manejada directamente por un CMOS 4024. Debo confesar que yo, al final, reemplacé el arreglo resistivo de 10 K por uno de 4,7 K, sin notar ninguna diferencia. Tal vez en un futuro cercano diseñe un circuito impreso especial para multi-carts. Por ahora, no. Saludos desde Chile. Quote Link to comment Share on other sites More sharing options...
khryssun Posted June 10, 2001 Share Posted June 10, 2001 Gracias por estas precisiones. Contemplo construyen un milticard entonces busco van consiguen tanto como informaciones que posibles. ¡Hola! de Francia Quote Link to comment Share on other sites More sharing options...
Eduardo Posted June 17, 2001 Share Posted June 17, 2001 Hola Madhatter: Muy buen trabajo el que realizaste con ese multicart, yo tengo una consola igual que la que utilizaste para extraer el chip rom con los juegos, solo que la mia tiene 64 juegos, en el exterior tiene exactamente las mismas etiquetas por lo que probablemente tus indicaciones coincidan con el chip de juegos que viene dentro de mi consola. Por estos rumbos tambien se consiguen consolas clones con chip rom multijuegos incluido. Voy a experimentar un poco. Saludos desde Mexico amigo Chileno. Quote Link to comment Share on other sites More sharing options...
Madhatter Posted June 20, 2001 Author Share Posted June 20, 2001 Hola Eduardo: Gracias por visitar mi página. Eres uno de los pocos que habla español y que me escribe, además. Espero que la información de mi página te sirva de algo en caso de que intentes "destripar" esa 64 en 1 que tienes. Saludos desde Chile. Quote Link to comment Share on other sites More sharing options...
