Help applying friction
Been messing around with 16 bit math and sub-pixel sprite movements and I ran into a problem when trying to apply friction to a given sprites speed.
I've attached the entire code below but the relevant section is this:
; Friction (broken )
ApplyFriction
.xfriction  lda xspeed+1
 bmi .doNegFrict
 lda xspeed
 bmi .doNegFrict
.checkPosFrict  lda xspeed+1 ;check if 0
 beq .checkLow
 jmp .doPosFrict
.checkLow	lda xspeed
 beq .yfriction
.doPosFrict;positive speed, subtract friction from speed
 sec
 lda xspeed
 sbc #FrictionLow
 sta xspeed
 lda xspeed+1
 sbc #0
 sta xspeed+1
 jmp .yfriction
;negative speed, add friction to speed
.doNegFrict	clc
 lda xspeed
 adc #FrictionLow
 sta xspeed
 lda xspeed+1
 adc #0
 sta xspeed+1
.yfriction
;Not done yet
It would seem it works as I expect when the xspeed is negative (sprite moving left) but when positive xspeed+1 > 0 friction no longer applies.
2 thoughts
1) this is probably a simple bug, but I cant seem to see it.
2) there is probably a much easier way of applying friction to a given speed than the method I am using above :)
Any suggestions?
friction.zip
:idea: BTW: Instead of two separate routines for adding and subtracting the friction values, you can use a more general routine and add negative values. E.g.
 lda #FrictionLow; #-FrictionLow
 ldy #0          ; #-1
 clc
 adc xspeed
 sta xspeed
 tya
 adc xspeed+1
 sta xspeed+1
And since you probably need more than one 16-bit addition in your code, you can define a subroutine:
 ldy #0          ; #-1
 ldx #<xspeed    ; or e.g. <xpos, <yspeed ...
 jsr Add16
Add16 SUBROUTINE
 clc
 adc $00,x
 sta $00,x
 tya
 adc $01,x
 sta $01,x
 rts
 ldy #0          ; #-1
 clc
 adc xspeed
 sta xspeed
 tya
 adc xspeed+1
 sta xspeed+1
 ldy #0          ; #-1
 jsr Add16
Add16 SUBROUTINE
 clc
 adc $00,x
 sta $00,x
 tya
 adc $01,x
 sta $01,x
 rts
Thanks thomas! I saw code similar to this in your cave 1k source, but didn't fully understand it at the time, I think because you were applying friction based on relative speed of the object(?). This makes much more sense now :)
I think because you were applying friction based on relative speed of the object(?)...
Yup, the faster the vertical speed, the more opposite friction (1/8th of the current yspeed). This makes flying the helicopter much easier.
The physics are still not very exact, since air-friction isn't linear but quadratic to speed. But it works quite well for the game. :)
