Movement
How are you trying to move it?
If you are trying to move it by setting the HMPx registery, then it won't move until you do a "STA HMOVE". (Note this should be done after an "STA WSYNC")
If you are using a full horizontal positioning scheme like described here, then it's simply a matter of changing the horizontal position variable between frames.
Hope this helps.
Well, thanks anyway, but I discovered some other way to make it happen.
The problem was that at every frame I was saying to put the sprite in the same place by setting the RESP0, so it seemed that the moving routine was the problem.
I created a variable to make sure that I would locate the sprite in the place I want it to start just one time. I set it with 1 before the MainLoop (frame loop).
And then this is what I made, after the scanline loop:
; Check if I need to locate the Sprite at the center of the screen
ldy #82 ;this is the number of cycles I had to "waste"
lda rhpos ;load the variable responsable for the checking
beq hpos ;if it's 0 skip the code below and go to hpos
lda #0 ;A=0
sta rhpos ;rhpos=0, so it will never happen again
timeforhpos ;delay for right positioning
dey
bne timeforhpos
sta RESP0 ;and call the sprite right here
hpos ;label that the code goes when rhpos is 0
Thanks again.
