Jaguar link up with the Lynx?
52 replies to this topic
#1 AtariLynx OFFLINE
AtariLynx
    Combat Commando
  • 4 posts
Posted Wed Feb 23, 2005 2:59 PM
I've heard you can link the two together. If you can, waht cord is needed to buy and what games can you connect with? :? :?
Thanks! :D
#2 TheGrandPubaa OFFLINE
TheGrandPubaa
    Moonsweeper
  • 293 posts
Posted Wed Feb 23, 2005 3:02 PM
It serves no practical function from what i've heard. There is a comlynx signal on the bus, but you would have to do some soldering to get a comlynx cable hooked up, and even then, there is no software to run.
#3 justclaws OFFLINE
justclaws
    Dragonstomper
  • 939 posts
  • Underground but not dead.
Posted Sun Feb 27, 2005 8:59 AM
Hello,
Indeed, it was another great idea which Atari failed to capitalise on.
I guess the fact they'd effectively stopped marketing Lynx by the time
they launched the Jaguar was the problem, no funding for Lynx games.
Perhaps in a few years time, we'll be playing homebrew hookups!
Cheers,
JustClaws.
#4 Matthias OFFLINE
Matthias
  • 1,171 posts
Posted Sun Feb 27, 2005 9:15 AM
Hello,
you probably don't need soldering if you do have two or three things:
- BLL-Cable:
This is used to connect a Lynx with a PC, providing a DSUB9-female-plug
- JagLink:
Converts from TTL to RS232 like the BLL-cable does, but provides no DSUB9-plug
- "JUGS"-Adapter:
Adapts from JagLink to DSUB9 (female i thnk)
- either an MODEM or NULL-MODEM cable to connect BLL-cable and JUGS/JagLink.
So the hardware problem can be solved by some people...
On the software side we do have to look at the Jaguar-DSP-port-bug and to check if both machines can be configured to provide the same serial-connection-settings (baudrate, number of data-bits, etc.)
Matthias
#5 davidcalgary29 OFFLINE
davidcalgary29
  • 6,222 posts
Posted Sat Dec 2, 2017 9:43 PM
Any developments on this in the past decade?
#6 sirlynxalot OFFLINE
sirlynxalot
    Dragonstomper
  • 551 posts
Posted Sat Dec 2, 2017 9:57 PM
No developments per se, but I think there was a prototype catbox sold at one point prior to 2012 that had a comlynx jack.  Still no software for either the lynx or the jag to test or take advantage of that though.
#7 JagChris OFFLINE
JagChris
  • 3,645 posts
Posted Sat Dec 2, 2017 10:12 PM
Blastin from the past!!!
#8 davidcalgary29 OFFLINE
davidcalgary29
  • 6,222 posts
Posted Sun Dec 3, 2017 1:12 PM
Does AvP code make use of the comLynx signal? I’ve read that Atari planned to make use of the Lynx as an ‘enhanced’ controller for Jag AvP with the Lynx port running.
#9 Stephen Moss OFFLINE
Stephen Moss
  • 1,152 posts
Posted Mon Dec 4, 2017 4:30 AM
Never heard that before and you may be correct although logically it make little sense as you have less buttons that the Jag controller which makes weapon selection and strafing harder to access and it is more bulky than the Jag controller. If they were going to use the com port then a multiplayer network would make more sense.
#10 LinkoVitch OFFLINE
LinkoVitch
  • 2,645 posts
Posted Mon Dec 4, 2017 4:57 AM
Or they could just use it as an extra screen.. so you could put the output of tracker/player health on the Lynx screen freeing it up from the jag screen.  Which would be kind of cool (assuming you could get a lynx to be viewable whilst playing your Jag :D
#11 neo_rg OFFLINE
neo_rg
    Moonsweeper
  • 388 posts
Posted Mon Dec 4, 2017 7:54 AM
I heard it was going to be used as if it was a motion tracker when playing the marine.
#12 Lynxpro OFFLINE
Lynxpro
  • 3,736 posts
Posted Mon Dec 4, 2017 3:31 PM
Connect the Lynx up to the Jag and have the Jag feed the Lynx the motion-tracker data. I wonder if Atari would've went to the trouble of making a card for the Lynx or if they would've just enabled its native ability to run game code straight from ComLynx. Wonder if anyone from Rebellion knows if this ever made the planning stages...
#13 Zerosquare OFFLINE
Zerosquare
  • 2,766 posts
Posted Mon Dec 4, 2017 6:47 PM
As far as I know there's no such thing on the Lynx (unlike, say, the Game Boy Advance). You can't even power on the console without a cart inserted anyways.
#14 Lynxpro OFFLINE
Lynxpro
  • 3,736 posts
Posted Mon Dec 4, 2017 7:37 PM
Epyx planned for it but Atari Corp didn't enable it [or actively frowned against implementing it]. They crunched the numbers and decided it wouldn't be very profitable if you only had to buy a single Lynx cart and then everyone with Lynxes could download the game via ComLynx.
I seem to recall someone in the Lynx forum talking about enabling it...
#15 davidcalgary29 OFFLINE
davidcalgary29
  • 6,222 posts
Posted Mon Dec 4, 2017 7:40 PM
#16 AtariORdead OFFLINE
AtariORdead
    Chopper Commander
  • 238 posts
Posted Mon Jan 29, 2018 6:56 PM
In regards to the Lynx and Jag.
I wonder why Atari never thought about doing a similar adaptor the the super gameboy. ( maybe they did consider it, I don't know )
Hardware was already developed, software was already done, and manufacturing Lynx carts was already done.
All the elements were just about there, it would have been extra revenue for the adaptor, and with the slow releases of Jag software, they would have probably shifted a few extra lynx carts.
Whether its true Or not I remember reading about a possible issue with resolution, not sure though.
#17 madman OFFLINE
madman
  • 2,841 posts
Posted Mon Jan 29, 2018 7:29 PM
Probably because the Lynx was also a commercial flop? Why spend the money to develop and release an adapter for a failed handheld so that the games could be played on a failing console?
Err, I mean, Atari absolutely should've done this! It could've saved them! It would've made the Jaguar a success and Sony would've been dead in the water!
#18 walter_J64bit OFFLINE
walter_J64bit
  • 5,210 posts
Posted Mon Jan 29, 2018 8:24 PM
You kill me, Madman! :rolling:
#19 AtariORdead OFFLINE
AtariORdead
    Chopper Commander
  • 238 posts
Posted Tue Jan 30, 2018 2:20 AM
Who said it would have saved them, and who said it would have made the jaguar a success.
You are projecting.
I simply asked why not? everything was there and while not going to save anything it would have likely clawed back some money for Atari.
What a strange and bitter response.
#20 Austin OFFLINE
Austin
  • 12,979 posts
Posted Tue Jan 30, 2018 2:30 AM
To be fair, compared to the Jaguar the Lynx was a runaway success.
I think an adapter could have been neat. I'd have used it.
#21 LinkoVitch OFFLINE
LinkoVitch
  • 2,645 posts
Posted Tue Jan 30, 2018 4:39 AM
Did any of the adaptors for other systems come out in the 1st generation of releases for that system?  As I see it the Jag never really made it past it's 1st generation of games, so it never got to the point where there was enough interest and legs in the system to warrant any development of such a device.
I agree it would be a cool little addon for the Jag.  I imagine the crossover subset of people that bought a Lynx and then bought a Jag there wouldn't have been a big enough pool of interest if it were released at the jaguars (giggle) "Prime" (snort, sorry can't keep a straight face :) )
#22 Austin OFFLINE
Austin
  • 12,979 posts
Posted Tue Jan 30, 2018 4:44 AM
Eh, we're talking about Atari. You know, the company that shelled out cash for VR development, a gaming modem, and a CD add-on for a console that hadn't even sold 200,000 units yet. I highly doubt a Lynx Player of some type would have been any worse. :)
#23 LinkoVitch OFFLINE
LinkoVitch
  • 2,645 posts
Posted Tue Jan 30, 2018 6:16 AM
Exactly! a Lynx module would have been in some way sensible.. so Atari didn't do it.. now an out there wacky idea like VR.. hells yeah! pump all of the money into that!! make sure to shout "TEXTURED 3D" at the devs every time you speak to them too. :)
#24 Clint Thompson OFFLINE
Clint Thompson
  • 4,424 posts
  • Kiss Reality Goodbye.
Posted Tue Jan 30, 2018 9:59 AM
Still waiting for the first homebrew that will actually make this a reality, though I'm not betting on it to ever happen. If at very least a tech demo of sorts to show it working would be neat. Pointless perhaps in the grand scheme of things but still cool.
#25 LinkoVitch OFFLINE
LinkoVitch
  • 2,645 posts
Posted Tue Jan 30, 2018 10:50 AM
That would be nice, but what we REALLY need is to have a do-over of AvP with the Lynx acting as the motion scanner output ;)
