All-Terrain Combat
16 replies to this topic
#1 Zach OFFLINE
Zach
  • 1,620 posts
Posted Wed May 18, 2005 11:32 PM
Remember when the playfields in Combat were limited to symmetrical 40x24 mazes? Thanks to Thomas' Skipdraw, you will soon be able to make an asymmetrical playfield with maximum resolution!
Have you ever seen a 2600 game with two sprites, two missiles, and an asymmetrical playfield in the same scanline? I didn't think it was possible until I learned about Skipdraw. This new version of Combat has a completely redesigned kernel.
The attached binary is still preliminary work. There are issues to work out, most importantly why it won't run on hardware. But I think you'll agree, it looks great in an emulator.
EDIT: May 24 binary attached, where a simple syntax error was fixed.
Edited by Zach, Sun Jul 10, 2005 5:32 PM.
#2 kisrael OFFLINE
kisrael
    HMBL 2600 coder
  • 4,071 posts
Posted Thu May 19, 2005 6:06 AM
Nice work!
Though doesn't Armor Ambush have Assymetrical Playfield, and can get all that stuff on one line? Or am I missing something?
#3 vdub_bobby OFFLINE
vdub_bobby
  • 5,832 posts
  • Boom bam.
Posted Thu May 19, 2005 10:48 AM
View Post
Combat uses a two-line kernel, right? Well, if you really want to push things to the limit, use SwitchDraw instead of SkipDraw - save you a couple more cycles, and it is perfectly suited to a 2LK.
Oh, and: it looks fantastic!
What problems are you having with real hardware?
#4 StanJr OFFLINE
StanJr
    Web-slinger
  • 15,433 posts
  • fun or bust
Posted Thu May 19, 2005 1:36 PM
very, very cool. Looks like this year's Stan Awards will be cooler than ever (for those of you in a cave, Zach did the awesome award BINs for last year's awards!). ;) ;) ;) ;)
Looks awesome.
Is this an offical hack for the database, or are you just showing off?
#5 Zach OFFLINE
Zach
  • 1,620 posts
Posted Thu May 19, 2005 4:53 PM
Nice work!
View Post
Thanks Kirk, it's always nice to hear from established homebrewers (gods or not). I took a quick look at Armor Ambush, and it's an impressive kernel. It appears the terrain is drawn with a clever combination of reflected and transposed playfields instead of complete asymmetry. Yes, there might be some changes to the PF on the fly, but I don't think the Armor Ambush kernel could draw something like this:
#6 Zach OFFLINE
Zach
  • 1,620 posts
Posted Thu May 19, 2005 5:09 PM
@Bob, yeah Combat uses a two line kernel, if you are referring to the fact the the graphics for each tank are updated on alternate scanlines. When I try to run the binary on a K Cart, I just get a black screen. Sometimes I see the playfield for a split second before the screen goes black. I'll post the code soon to see if anyone has an idea of what's going on. If not, I'll just do a brute force commenting out of code.
@Stan, once it is finished, I think it will fit into the database just fine. We all appreciate the work you put into maintaining the list.
#7 vdub_bobby OFFLINE
vdub_bobby
  • 5,832 posts
  • Boom bam.
Posted Thu May 19, 2005 5:19 PM
View Post
I'll take a look at it, unless some else gets to it first :D
#8 Zach OFFLINE
Zach
  • 1,620 posts
Posted Thu May 19, 2005 7:30 PM
View Post
View Post
Cool.
Edited by Zach, Tue May 24, 2005 5:49 PM.
#9 batari OFFLINE
batari
    )66]U('=I;B$*
  • 6,680 posts
  • begin 644 contest
Posted Thu May 19, 2005 8:31 PM
Great hack!
I have no idea why it won't work on real hardware, but I did find a graphical glitch with an easy fix. The left tank, when traveling near the right edge of the screen, will look distorted at a particular spot. This is due to the write to GRPx occuring during the visible portion of the scanline. Looking at your original code:
ReturnFromSkipDraw       ;3
      sta GRP1        ;3
      cpy NewMissileY1;2   ; Assumes Y is your kernal line counter
      php             ;3
      cpy NewMissileY0;2
      php             ;3
     ;( ------------ second line ------------------)
      dey             ;2
All you need to do is move the STA GRP1 down a bit, maybe after the stack pushes or the "dey" and the glitch should go away. I have not tested this, but I see no reason why this wouldn't work.
#10 Zach OFFLINE
Zach
  • 1,620 posts
Posted Tue May 24, 2005 5:43 PM
I made an interesting discovery today. When I load the binary as part of a multicart, it runs just fine on my KC. If I load it as a single file, I get the blank screen described earlier.
At this point, I think it's safe to say we don't need to examine the source code anymore. I'd like to ask the members of the community to test on their own hardware. I'm curious what the results are with other Krokodile Carts, Superchargers, Cuttle Carts, and maybe even EPROMS. Thanks.
Edited by Zach, Thu May 26, 2005 5:02 PM.
#11 batari OFFLINE
batari
    )66]U('=I;B$*
  • 6,680 posts
  • begin 644 contest
Posted Tue May 24, 2005 6:31 PM
At this point, I think it's safe to say we don't need to examine the source code anymore. I'd like to ask the memebrs of the community to test on their own hardware. I'm curious what the results are with other Krokodile Carts, Superchargers, Cuttle Carts, and maybe even EPROMS. Thanks.
View Post
It could be specific to the KC, but if it is, the original Combat probably should also not work on a KC. Have you tried the original game?
#12 Zach OFFLINE
Zach
  • 1,620 posts
Posted Tue May 24, 2005 6:50 PM
Just tried original Combat. It works.
#13 Zach OFFLINE
Zach
  • 1,620 posts
Posted Tue May 24, 2005 10:55 PM
I just successfully loaded the new Combat on a Supercharger. It is becoming evident that the hardware issue has something to do with the Krokodile Cart. (It's still a great piece of equipment, though.)
#14 Atari_Jaguar OFFLINE
Atari_Jaguar
    Chopper Commander
  • 195 posts
Posted Tue May 24, 2005 11:29 PM
View Post
I concur wholeheartedly wth mister zach.
#15 SpiceWare ONLINE
SpiceWare
    Draconian
  • 12,631 posts
  • Medieval Mayhem
Posted Wed May 25, 2005 5:13 PM
View Post
Just tried it on my Krok Cart and it worked fine as a stand-alone 4K game. I'm loading it with KrokCom, my Mac OS X program. Mine doesn't set the bankswitch type automatically yet, so I have to explicity tell it "4K", perhaps the Windows program is setting the wrong bankswitch type?
Edited by SpiceWare, Wed May 25, 2005 5:14 PM.
#16 bjk7382 OFFLINE
bjk7382
  • 4,580 posts
Posted Thu May 26, 2005 11:30 PM
Works fine on the cc2. It's still just combat though :P
I like how the planes are tanks.
#17 Zach OFFLINE
Zach
  • 1,620 posts
Posted Sat Jul 9, 2005 11:22 PM
Thanks to everyone who tested on hardware. Today I finished up the Tank version. Assuming no problems are found, the plane version will be posted soon. When that is done, I will release a tool for making your own playfields.
Updates to this version include:
  • Removed airplane levels.
  • Made game reset from attract mode possible with left joystick button.
  • Made game variations selectable with left joystick.
  • Reduced picture size from Combat's original 263 scanlines to the standard 262.
  • Sprite data stored more efficiently.
  • Fixed a subtle bug that was only apparent when rotating a tank in slow motion.
