A/V Mod for Bally Astrocade
56 replies to this topic
#51 the_crayon_king OFFLINE
the_crayon_king
    Chopper Commander
  • 155 posts
Posted Tue Oct 18, 2016 9:32 AM
There is a doc here for conversion to RGB:
http://www.ballyalle...rgb_convert.pdf
Step one I will redraw that schematic.
Also I am going to see if I can get component video out of this using a THS7314 tonight.
#52 the_crayon_king OFFLINE
the_crayon_king
    Chopper Commander
  • 155 posts
Posted Tue Oct 18, 2016 11:14 AM
Uh can't edit my old post here is the schematic; I think I have all the important bits:
http://i.imgur.com/2jW9Ylm.png
MOAR INFO: http://www.bucek.name/pdf/tba530.pdf
Any clue what kind of inductor that is ? 270N something I can't read alot of this stuff clearly.
Someone should probably check for accuracy.
Edited by the_crayon_king, Tue Oct 18, 2016 11:54 AM.
#53 the_crayon_king OFFLINE
the_crayon_king
    Chopper Commander
  • 155 posts
Posted Thu Dec 29, 2016 10:02 PM
Here is what I am looking at: http://i.imgur.com/WLxZ12g.gif
Just a note for anyone looking into this (and for myself in the future). Video out should 100% be possible with a THS73XX.
I have THS7360 kits that would be good for putting out YPBBR, S-Video, or composite on this console.
You could use a 7805 to get +5 from that +10 and everything else can be done with the THS73XX.
The B-Y and R-Y look like they would need DC restore caps at the end of the THS73XX maybe pull downs on the input as well.
Y looks like its good to go but you would probably need to adjust a pull down resistor on the input for correct brightness. Or try straight in to the TV with 75 ohms for S-Video
I have no clue what the other Chroma is but it would probably also need DC restore at the output of the THS73XX.
I can draw up a schematic of what I would do if anyone is interested in trying to do one of the video outputs.
splitting the Luma/Sync so it can be put out to both B-y,R-y,Y and S-Video (Y|C) would be a pretty high priority. Composite too maybe.
Any measurements people have on the output values of those pins would also help greatly.
Gain of TBA530 (if I am reading this right is 40db (100x) vs 6db (4x)of the THS73XX
Ill design a board using the data out there on RGB using the TBA530 so people can print this and try it out if so inclined.
Edited by the_crayon_king, Thu Dec 29, 2016 10:27 PM.
#54 kenzre OFFLINE
kenzre
    Space Invader
  • 24 posts
Posted Sat Dec 31, 2016 8:31 PM
IF you can solder, I make a comp video / pseudo stereo (both sides actually have identical outputs) board that requires soldering. The cabling is larger than the standard RF cord, so it would either be a tight fit or you might need to file the Arcade a little. The other 2 ways id can be installed is either a 3 RCA jack unit ( yellow,red,white) made for mounting to the unit, but that would require drilling 5 holes, 3 for the jacks and 2 for mounting, OR I can send it with a 35mm jack and special cable that goes from the 35mm to the 3 RCA cable.
The PCB, fully assembled and tested with the 3 RCA in one is $50.00. comes with mounting instructions, wiring to go to the unit and jack.
The 35mm jack version is $75.00 because it has the extra cable.
A 6 foot 3 wire RCA AV cable (YRW connectors both sides) can be used by either... $15.00
Shipping, Processing and handling fee of $15.00 required if shipped in US.
Requires that the modulator box has to be placed back on it's jack to get a color output. Without it, you will get a B/W output.
#55 the_crayon_king OFFLINE
the_crayon_king
    Chopper Commander
  • 155 posts
Posted Sun Jan 1, 2017 8:19 AM
You should at least try using the FMS6400 that way you could get S-Video and composite.
I made this open source may help if you ever wanna go that route: https://easyeda.com/...7a9acbcaf2880c9
Edited by the_crayon_king, Sun Jan 1, 2017 8:21 AM.
#56 KylJoy OFFLINE
KylJoy
    Dragonstomper
  • 777 posts
  • Intellibeardist
Posted Mon Dec 4, 2017 7:54 PM
I'm still interested in a good RGB mod kit or schematic that is proven to work well.
Anyone?
#57 the_crayon_king OFFLINE
the_crayon_king
    Chopper Commander
  • 155 posts
Posted Sun Dec 10, 2017 10:17 PM
Anyone?
I dont own a bally or Id try something. Or maybe I do own one ? Everything is in storage regardless.
I could build a board and put in all the parts but I'd have no way to test.
If someone has oscope measurements of the on board R-y B-y Y (or a datasheet); that would be a good place to start.
You could also probably just use those signals for video assuming your TV will accept it.
I redrew this:
(unknown source [maybe console5?)
Note about this scan It isn't the highest quality... but the original source isn't available.
Ken Lill notes on Feb. 26, 2010 It could be used to give you RGB out of an arcade, but you have to wire into the 3 different supplies and the ground. If you DID use this, you shouldn't need the modulator.
Brett Bilbrey notes on Feb. 26, 2010 That is the schematic for the Midway RGB board. It was a simple board that converted R-Y, B-Y, Video (where in this case, Video is Luma) to the RGB format. I don't know if you can get your hands on one of the boards anymore, but any R-Y, B-Y, Y to RGB converter should work. The nice part of that would be getting rid of the chroma crawl on the NTSC video and you could use the RGB input on newer TV sets.
Specifically, the connector that the internal RF modulator (sealed box) mounts to here on the schematic
So I think we just need a few op amps/resistors/caps and a lm1881
Edited by the_crayon_king, Sun Dec 10, 2017 10:22 PM.
