Timing....
7 replies to this topic
#1 potatohead OFFLINE
potatohead
  • 4,404 posts
Posted Thu Jul 28, 2005 12:13 AM
Anyone have a rough guess at commands / cycles?
Just ran into a timing constraint on the ooze game. To avoid some of the little timing bugs in the last version, I wanted to clear the playfield and draw a fresh set of ooze each frame.
This takes too long. Storing ooze lengths two per variable does not help this any.
Ahhh... the challenge of the 2600 is beginning to show.
FYI, more than a few pfgraphics commands will consume all the time you have. So will a lot of variable shuffling to squeeze more value out of each bit.
So, going back to the old approach to see if that can be done with the additional overhead of packing the data into each nibble of the variables.
#2 batari OFFLINE
batari
    )66]U('=I;B$*
  • 6,680 posts
  • begin 644 contest
Posted Thu Jul 28, 2005 1:28 AM
View Post
The pf commands will use up your cycle budget really quick - they are currently the most "expensive" commands by far. The other commands are all relatively inexpensive.
When considering the cycle counts below, recall that you have about 2700 usable cycles per frame in bB.
Here's a tally which may be useful for estimating your time (values are approximate)
pfpixel: 80 cycles
pfscroll left/right: 500 cycles
pfscroll up/down: 650 cycles every 8th time it's called, 30 cycles otherwise
pfvline: 230-600 cycles depending on length (Approx 200+34*length)
pfhline: 250-1500 cycles depending on length (Approx 210+42*length)
If you're not using pf commands, chances are you won't exceed the time allotted, at least in Alpha 0.2. In the next version, we're hoping for full multiply/divide and fixed point math, which may also be a little taxing on cycles, but probably it will be comparable to pfpixel and not anywhere near the playfield scrolling or lines.
#3 Thomas Jentzsch OFFLINE
Thomas Jentzsch
    Thrust, Jammed, SWOOPS!, Boulder Dash, THREE·S, Star Castle
  • 23,941 posts
  • Always left from right here!
Posted Thu Jul 28, 2005 1:32 AM
A simple, unoptimized loop which only clears the playfield data will require at best ~9 cycles/iteration (sta zp,x; dex; bpl loop), which is 6*9=54 cycles for one line of data. (if the loop is counting up, it will require 11 cycles)
During overscan, you have ~2100 cycles for calculations.
#4 Thomas Jentzsch OFFLINE
Thomas Jentzsch
  • 23,941 posts
Posted Thu Jul 28, 2005 1:34 AM
pfpixel: 80 cycles
Ouch, maybe you should implement some instructions which allow filling a larger area (like memset).
#5 batari OFFLINE
batari
    )66]U('=I;B$*
  • 6,680 posts
  • begin 644 contest
Posted Thu Jul 28, 2005 1:37 AM
View Post
Yes, i'd highly recommend using an inline asm routine for pf clearing.
Normally, you do have 2100 cycles in overscan. However, the stock bB kernel doesn't use all 192 scanlines right now - it uses around 184 or so, giving an extra 600 cycles or so.
#6 batari OFFLINE
batari
    )66]U('=I;B$*
  • 6,680 posts
  • begin 644 contest
Posted Thu Jul 28, 2005 1:48 AM
pfpixel: 80 cycles
View Post
It's heavy, yes, largely because it does some calculations to convert the x and y arguments to an actual memory location, then, of course, it only sets a bit at a time, requiring read-mask-write, and it must also index a lookup table because some of the bit orders are reversed.
memset (as it is used in C) would be faster but wouldn't be quite as useful since it doesn't deal with bits.
#7 potatohead OFFLINE
potatohead
  • 4,404 posts
Posted Thu Jul 28, 2005 2:07 AM
Ok that tells me what I want to know.
I'm doing another redesign because I didn't have much luck storing ooze positions as nibbles in the vars.
Either I'm just not groking the bit operations (likely)
, or
they have some problems. (Somewhat likely)
Had some luck with using bits as flags, that will save me enough for now.
An inline asm for clearing the playfield works great and that's the route I chose. I no longer need the pfline command and pfpixel can be managed to avoid running out of time.
Thanks for the info guys, that tells me enough about the scale of things that I can make good decisions going forward.
#8 kisrael OFFLINE
kisrael
    HMBL 2600 coder
  • 4,071 posts
Posted Thu Jul 28, 2005 6:24 AM
I think a "CLS" like command would be useful.
Maybe with a "FLS" fill screen command that does the opposite...or even better, a "negscreen" function that does a logical NOT on every byte of the playfield, so a CLS + NEG would do the same thing as a FLS.
