+johnnywc Posted August 31, 2005 Share Posted August 31, 2005 Hello all, I am currently working on a kernel that allows up to 8 independant objects on the screen at once using intelligent flicker (ie. shows any two sprites in one vertical band with no flicker, 3 sprites with 2 flickering at 30hz, one doesn't flicker, 4 sprites all flickering at 30hz, etc.). The pre-calculation needs the Y values of the objects I'm displaying to be sorted in descending order (so that last scan lines can be compared to for determining when to flicker, etc and that reposition lines can be computed). Anyway, I wrote this sort routine that works but is extremely slow (it takes 19 scan lines to finish!). Is there a tried-and-true method for sorting 8 numbers in the fastest time possible? My method uses a "bucket sort" that scans the numbers looking for the largest one, marks it as "processed" and repeats the loop (8 times): Here is the code: SortObjects ; logic: ; step through each object and find the largest y value ; store the index in the next position ; note: skip values that have already been processed ; mark all as not sorted ldy #MAX_OBJECTS-1 lda #0 .initSorted sta O_Sorted,Y dey bpl .initSorted ldx #MAX_OBJECTS-1; position to compute .sortObj ldy #MAX_OBJECTS-1 lda #0 sta temp .findMaxObj lda O_Sorted,Y bne .skipObj ; compare the object with the max value lda O_Y,Y cmp temp bmi .skipObj ; object is greater; save sty index sta temp .skipObj dey bpl .findMaxObj ; store the result ldy index sty O_Sort,X ; mark this object as processed lda #1 sta O_Sorted,Y dex bpl .sortObj RTS Note that I'm storing the indexes of the objects in a separate array called O_Sort (O_Sorted is a boolean array that stored whether the object has been processed). Of course, my assumption is that I need to process objects in a sorted order to implement intelligent flicker. Any ideas are welcomed. Thanks, Quote Link to comment Share on other sites More sharing options...
djmips Posted August 31, 2005 Share Posted August 31, 2005 Don't re-sort the list every frame. Since your list is mostly sorted, you only need to deal with an object that changes it's position in the list. Quote Link to comment Share on other sites More sharing options...
+johnnywc Posted August 31, 2005 Author Share Posted August 31, 2005 Thanks for the tip - that was going to be my first approach, but since all 8 objects can move each frame I was worried that would take too long. As it turns out, sorting the array each time takes even longer!! Of course with this approach, I only have to sort objects that move up or down, and I only have to traverse the list in one direction based on whether the object moved up or down, and I can stop comparing once I hit a value that is greater (or less than). I'll try this approach and see how much time it takes. Thanks again! Quote Link to comment Share on other sites More sharing options...
Cybergoth Posted August 31, 2005 Share Posted August 31, 2005 Hi there! You may want to research in the [stella] archives about my Flickersort method used for Star Fire. The BASIC idea is doing one iteration of a special Bubble Sort per frame. Doing so will have a "constantly improving" result. Amazing bonus: If done right, this'll automatically do the "intelligence" as well - overlapping sprites will just continue to swap positions and so they automatically get an even distribution of on-screen time! Greetings, Manuel Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted August 31, 2005 Share Posted August 31, 2005 For almost sorted lists, Bubblesort is probably the easiest and fastest solution. Just make sure that you stop, when the list is sorted (no swaps in the last round). Quote Link to comment Share on other sites More sharing options...
supercat Posted August 31, 2005 Share Posted August 31, 2005 Selection sort isn't bad, but there are a few things you should do to make it faster. First and foremost, having to check each element to see if it's the maximum and also check to see if it's already been selected is very wasteful. It's probably better to swap each selected item with the top element and shrink the size of the area being searched after each pass of the outer loop. Alternatively, the search can be performed on a temp copy of the original data to be sorted; every time an item is selected, the copy of the item in the temp array should be zeroed. I'd suggest doing something like this: lda #7 sta psize sort1: ldx psize sort2a: txa ldy items,x dex bmi sortdone1 sort2b: cpy items,x bcc sort2a dex bpl sort2b sortdone1: ; A holds the present location of the maximum item ; Do something useful with it, then... dec psize bpl sort1 Note that the inner loop time is MUCH smaller than what you had before, since the important information is all kept in registers. Quote Link to comment Share on other sites More sharing options...
+johnnywc Posted August 31, 2005 Author Share Posted August 31, 2005 Thank you all for your help. I'm going to implement the bubble sort and see what kind of results I get. While we're on the subject, my objects each have 3 bytes of info (X,Y and state) needed for drawing. My first thought was that it would be quicker to have a secondary table that stored the indexes to the objects so that when I sort I only have to swap indexes in this table (instead of swapping all 3 bytes in the object table). Are there any thoughts on this? Thanks again!! BTW - I'm working on a re-write of Wizard of Wor using intelligent flicker (that non-intelligent flicker is a killer!). I'm sure I could hack the original code, but I'm using this as a learning opportunity too. I hope to implement the intelligent flicker, add more mazes (including the special mazes like The Arena, Warlord and Pit levels), and the in-between "DOUBLE SCORE DUNGEON" transition scene. I'll probably have to use 8K but we'll see. Quote Link to comment Share on other sites More sharing options...
supercat Posted September 1, 2005 Share Posted September 1, 2005 While we're on the subject, my objects each have 3 bytes of info (X,Y and state) needed for drawing. My first thought was that it would be quicker to have a secondary table that stored the indexes to the objects so that when I sort I only have to swap indexes in this table (instead of swapping all 3 bytes in the object table). 922718[/snapback] If it's only three bytes per object, use a selection sort and do the swap. If you're crunched for time, it may be useful to unroll some of the loops. This will cause some significant code bloat (I don't know what your target size is) but allow for a major speedup since you can avoid redundant loads/stores. I'll see if I can code a macro-based version for you. Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted September 1, 2005 Share Posted September 1, 2005 i am using this method: www.student.oulu.fi/~loorni/covert/rants/sprite.htm http://www.atariage.com/forums/index.php?showtopic=66811 Quote Link to comment Share on other sites More sharing options...
djmips Posted September 1, 2005 Share Posted September 1, 2005 I had to resort to an archive to check out that article. http://web.archive.org/web/20041106215212/...ants/sprite.htm Interesting. I had written a 32 sprite mux for the C64 back in 1990. This certainly brings back memories. I wish I had kept some source code. Maybe some day I'd like to disassemble TMNT for the C64 and figure out what I did. I do remember being satisfied with the 'mapper' part of the code. Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted September 1, 2005 Share Posted September 1, 2005 thanks...interesting that my link does not work to the rant with the radix sort but yours instead... Quote Link to comment Share on other sites More sharing options...
supercat Posted September 1, 2005 Share Posted September 1, 2005 Interesting. I had written a 32 sprite mux for the C64 back in 1990. This certainly brings back memories. I wish I had kept some source code. 923138[/snapback] Doing a sprite multiplexer for the C64 is a bit different from doing one on the 2600, since the former has enough RAM to allow for radix-bucket sorting. Depending upon the application, the 2600 may as well, but it's hardly a given. The basic approach to radix-bucket sorting would be something like this (assuming eight zones of 16 scan lines each; two sprites per zone) ldx #30 ; (Number of zones*2-1)*2 lda #0 cllp: sta zoneptr+1,x dex dex bpl cllp ldy #7 ; Number of sprites lp: lda spritey,x ; abs,y mode lsr lsr and #$FC tax lda zoneptr+1,x beq storehere1 inx inx lda zoneptr+1,x bne nothere1 storehere1: ; Store sprite shape into zoneptr,x nothere1: lda spritey,x ; abs,y mode lsr adc #[sprite_height/2] lsr and #$FC tax lda zoneptr+1,x beq storehere2 inx inx lda zoneptr+1,x bne nothere2 storehere2: ; Store sprite shape into zoneptr,x nothere2: dey bpl lp Note that there is no need for sorting, though steps must be taken to ensure that in case of 'zone overload' objects will flicker instead of disappearing entirely. If that is addressed [and there are ways of dealing with it] the above general approach can be a good one. Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted September 2, 2005 Share Posted September 2, 2005 the interesting part starts with the "flicker engine"..... and what is happening when sprites cross the "zones"... Quote Link to comment Share on other sites More sharing options...
supercat Posted September 3, 2005 Share Posted September 3, 2005 the interesting part starts with the "flicker engine"..... One approach which works well if there are at most four objects/zone is to have alternate frames take the objects in ascending and descending order. If there are one or two objects in a zone, they'll appear solid. If three, two will flicker 30Hz and one not. If four, all will flicker 30Hz. If there are more than four, some will disappear (oops). I don't know what the best way is to construct a flicker engine for dividing more than four objects among two sprites. In a game like Star Fire where both sprites are used as a pair, the algorithm is comparatively simple. The general case, however, is harder. There are a number of approaches I can see, but all of them require either icky amounts of space or icky amounts of time. Constraining objects to move in discrete zones [as in Pooyan or Millipede ] simplifies things by making it more practical to search for objects in zone 1, then zone 2, etc. and what is happening when sprites cross the "zones"... 923672[/snapback] Well, the partial code I gave above handled part of the issue. You need to indicate whether a sprite is a 'new' sprite or a 'continuation', which can be handled using the X position. If zero, it's a continuation of a sprite; anything else, it's a new sprite. Quote Link to comment Share on other sites More sharing options...
Cybergoth Posted September 3, 2005 Share Posted September 3, 2005 Hi there! I don't know what the best way is to construct a flicker engine for dividing more than four objects among two sprites. In a game like Star Fire where both sprites are used as a pair, the algorithm is comparatively simple. The general case, however, is harder. Actually the Star Fire Flickersort algorithm will work 100% the same, totally regardless of how many hardware sprites are actually available, as it'll always cause an even distribution of screen time for any object. And the kernel would still try to draw as many sprites as it can - only at the advantage of having more hardware sprites available to draw them. Greetings, Manuel Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted September 3, 2005 Share Posted September 3, 2005 Manuel...just went through the flicker sorter... is is this part of the source? ;----------------------------------------------------------- ;FLICKER SORT SUB ;----------------------------------------------------------- FlickerSort: LDX #MAXOBJECTS-2 SortLoop: LDY sprtsizetype+1,X ; A-> 1st sprite type and size LDA ypos+1,X ; A-> 1st sprite ypos SBC shapeheight,Y ; A-> 1st sprite ypos - size SBC #$03 ; Fix skipping problem CMP ypos,X ; 2nd Sprite drawable? BPL DontSwap ; Y: All right! SwapThis LDA xpos,X ; N: Swap horizontal position LDY xpos+1,X STA xpos+1,X STY xpos,X LDA ypos,X ; Swap vertical position LDY ypos+1,X STA ypos+1,X STY ypos,X LDA xymov,X ; Swap horizontal movement LDY xymov+1,X STA xymov+1,X STY xymov,X LDA zmov,X ; Swap horizontal movement LDY zmov+1,X STA zmov+1,X STY zmov,X LDA sprtsizetype,X ; Swap size & type LDY sprtsizetype+1,X STA sprtsizetype+1,X STY sprtsizetype,X DontSwap: DEX BPL SortLoop Quote Link to comment Share on other sites More sharing options...
Cybergoth Posted September 3, 2005 Share Posted September 3, 2005 Hi there! Manuel...just went through the flicker sorter... is is this part of the source? Yup. Plain and simple. Just the inner loop of a slightly tweaked Bubble Sort. Only one iteration per frame. Greetings, Manuel Quote Link to comment Share on other sites More sharing options...
supercat Posted September 3, 2005 Share Posted September 3, 2005 Actually the Star Fire Flickersort algorithm will work 100% the same, totally regardless of how many hardware sprites are actually available, as it'll always cause an even distribution of screen time for any object. And the kernel would still try to draw as many sprites as it can - only at the advantage of having more hardware sprites available to draw them. 924334[/snapback] Right, but if there are an odd number of objects (especially if it's three) what may be the optimal flicker for equalizing objects' display time will not look the best. For example, if there are three objects, it will look better if one is displayed 100% of the time and the other two 50%, than if all three are displayed 66% of the time. For that matter, having all three at 50% would still be better than all three at 66%. Quote Link to comment Share on other sites More sharing options...
Cybergoth Posted September 3, 2005 Share Posted September 3, 2005 Hi there! Hm... why should 50% look better than 66%? Greetings, Manuel Quote Link to comment Share on other sites More sharing options...
djmips Posted September 3, 2005 Share Posted September 3, 2005 I think it's a matter of opinion but having a 50 percent duty cycle on the flicker keeps a more consistent intensity level which may be more pleasing to your eye. Quote Link to comment Share on other sites More sharing options...
supercat Posted September 4, 2005 Share Posted September 4, 2005 Hm... why should 50% look better than 66%? 924541[/snapback] The rate of flicker is much more noticeable than the duty cycle. This is why movie projectors use a 2-blade (for sound speed) or 3-blade (for silent speed) shutter. Using the 2- or 3-blade shutter reduces the duty cycle of the projection, but causes it to flicker at 48 or 54fps instead of 24 or 18. An object which is shown at 50% duty cycle can flicker at 30Hz. An object which is shown at 66% duty cycle can flicker at, at best, 20Hz. Likewise, an object which is shown at 33% duty cycle can flicker at 20Hz; an object which is shown at 40% duty cycle would have a flicker-pattern rate of at best 12Hz. Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted September 4, 2005 Share Posted September 4, 2005 interesting....what is "duty cycle"? never heard that phrase? Quote Link to comment Share on other sites More sharing options...
Cybergoth Posted September 4, 2005 Share Posted September 4, 2005 Hi there! An object which is shown at 50% duty cycle can flicker at 30Hz. An object which is shown at 66% duty cycle can flicker at, at best, 20Hz. Likewise, an object which is shown at 33% duty cycle can flicker at 20Hz; an object which is shown at 40% duty cycle would have a flicker-pattern rate of at best 12Hz. I see. But an object with 40% screen time would look better with a pattern like: 1-0-1-0-0 as with 1-1-0-0-0? And if you have four objects, 1-0-1-0 would be better than 1-1-0-0, or? Then... I think for 2 hardware sprites the Flickersort algorithm might improve the result when doing 2 iterations per frame. It'd do the 1-0-1-0 for four sprites. For three sprites it won't help any though. With three objects, even if the flicker rate is the same on 66% vs 33%, wouldn't 66% look at least slightly improved over 33% on a real TV? Or would it just change the brightness? Greetings, Manuel Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted September 4, 2005 Share Posted September 4, 2005 With three objects, even if the flicker rate is the same on 66% vs 33%, wouldn't 66% look at least slightly improved over 33% on a real TV? Or would it just change the brightness? Depends on the phosphorescence effect of the TV and how fast it changes the intensity level from 0 to 1 and 1 to 0 (which vary when switching e.g. from 0.5 to 1). Rather complicated IMO. Does anybody know the average values here? Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted September 4, 2005 Share Posted September 4, 2005 manuel, coming from atari 800 with 4 players instead of 2600 2... i am playing around with this kind of sprite engine for couple of years... is your approach suitable for 4 hardware sprites as well or is it optimised for 2600 only? Quote Link to comment Share on other sites More sharing options...
