How do you flip between 1 and -1? (a=0-a, a=a^254)
14 replies to this topic
#1 Random Terrain OFFLINE
Random Terrain
    Visual batari Basic User
  • 28,880 posts
  • Controlled Randomness
    Replay Value
    Nonlinear
Posted Thu Sep 8, 2005 4:46 AM
Without using a bunch of if-then statements, how do you flip a number between 1 and -1 or -1 and 1 in either direction? It's not hard to do with other BASIC languages, but can we do that with batari Basic?
Thanks.
Edit:
Answered in posts below. You can use:
a=0-a
or
a = a^254
See this post for details on which one you should use:
http://www.atariage....ndpost&p=927991
Edited by Random Terrain, Thu Sep 8, 2005 11:30 PM.
#2 batari OFFLINE
batari
    )66]U('=I;B$*
  • 6,680 posts
  • begin 644 contest
Posted Thu Sep 8, 2005 4:54 AM
Thanks.
View Post
Yes, something like a=-a should work.
#3 Random Terrain OFFLINE
Random Terrain
  • 28,880 posts
    Replay Value
    Nonlinear
Posted Thu Sep 8, 2005 5:04 AM
Thanks.
View Post
I tried that with and without spaces and it won't compile, so I thought that wasn't allowed. Well, it won't compile in an if-then, but it will outside of it but it complains about an error and then the buggy program runs.
Edited by Random Terrain, Thu Sep 8, 2005 5:07 AM.
#4 Random Terrain OFFLINE
Random Terrain
  • 28,880 posts
    Replay Value
    Nonlinear
Posted Thu Sep 8, 2005 8:39 AM
In case anyone wants to know, I figured out a way to toggle without creating extra if-then statements:
  rem * Here's a crappy little program I (Random Terrain) made as an example of
  rem * sprite movement with the joystick. You control a sprite and there is also
  rem * a bouncing ball that you can bang into.
  rem * Don't worry, you are blocked from going past the edge of the screen.
gamestart
  rem * Create alias for each variable.
  dim spritex = a
  dim spritey = b
  dim directionx = c
  dim directiony = d
  dim directionx2 = e
  dim directiony2 = f
  rem * Setup.
  COLUPF = 204 : score = 0
  player0x = 93 : player0y = 54
  bally = 30 : ballheight = 1
  r = rand : if r > 30 && r < 155 then ballx = r else ballx = 30
  directionx = 1 : directiony = 1
  directionx2 = 255 : directiony2 = 255
  rem * Define player0 shape.
  player0:
  %11111111
  %10100101
  %10100101
  %10111101
  %10111101
  %10100101
  %10100101
  %11111111
end
  rem * Main game loop starts here.
gameloop
  scorecolor = 158
  COLUP0 = 28
  drawscreen
  rem * Move player0 if joystick is used and don't allow border crossing.
  if joy0up && player0y > 10 then player0y = player0y - 1
  if joy0down && player0y < 89 then player0y = player0y + 1
  if joy0left && player0x > 15 then player0x = player0x - 1
  if joy0right && player0x < 167 then player0x = player0x + 1
  rem * Move ball and don't allow border crossing and detect collision with player0.
  if bally < 3 then directiony =  1 : directiony2 = 255
  if bally > 87 then directiony = 255 : directiony2 = 1
  if ballx < 16 then directionx = 1 : directionx2 = 255
  if ballx > 174 then directionx = 255 : directionx2 = 1
  if collision(ball,player0) then directionx = directionx2 : directiony = directiony2 : score = score + 10
  ballx = ballx + directionx : bally = bally + directiony
  if switchreset then goto gamestart
  goto gameloop
As you can see, I just made an opposite within the if-then statements that already existed. Might be a better way than that, but I can't think of it.
EDIT:
Here is the same thing, but using Zach's tip (from a post below).
gamestart
  dim spritex = a
  dim spritey = b
  dim directionx = c
  dim directiony = d
  rem * Setup.
  player0:
  %11111111
  %10100101
  %10100101
  %10111101
  %10111101
  %10100101
  %10100101
  %11111111
end
gameloop
  scorecolor = 158
  COLUP0 = 28
  drawscreen
  rem * Move ball and don't allow border crossing and detect colision with player0.
  if collision(player0,ball) then directionx = directionx^254 : directiony = directiony^254 : score = score + 10
  goto gameloop
Edited by Random Terrain, Thu Sep 8, 2005 11:41 PM.
#5 danwinslow OFFLINE
danwinslow
  • 2,571 posts
Posted Thu Sep 8, 2005 3:40 PM
a=a*(-1)
? maybe.
#6 batari OFFLINE
batari
    )66]U('=I;B$*
  • 6,680 posts
  • begin 644 contest
Posted Thu Sep 8, 2005 3:45 PM
a=a*(-1)
? maybe.
View Post
Not yet - it will get confused by the parens.
I am a little surprised that a=-a does not work - I thought I programmed this in. I guess I did it wrong :? Either way, a=0-a will work.
#7 Zach OFFLINE
Zach
  • 1,620 posts
Posted Thu Sep 8, 2005 4:44 PM
For 1 and -1, a = a ^ 254 would work too. Plus, it should produce more efficient code. A lot of people here would be happy to explain why it works if you're interested.
Edited by Zach, Thu Sep 8, 2005 4:52 PM.
#8 Random Terrain OFFLINE
Random Terrain
  • 28,880 posts
    Replay Value
    Nonlinear
Posted Thu Sep 8, 2005 7:25 PM
View Post
Thanks. That works. I'm really bad at math, so there is no way I would have come up with that.
View Post
That also works. Is one better than the other without a doubt?
Which one should I go with?
a = a^254
or
a=0-a
Thanks.
#9 SeaGtGruff OFFLINE
SeaGtGruff
  • 5,566 posts
Posted Thu Sep 8, 2005 11:15 PM
View Post
View Post
a = a^254
or
a=0-a
Thanks.
View Post
That depends on what you need to do.
"a = 0 - a" compiles as "LDA #0:SEC:SBC a:STA a," which takes 7 bytes, and uses 10 machine cycles.
"a = a ^ 254" compiles as "LDA a:EOR #254:STA a," which takes 6 bytes, and uses 8 machine cycles.
Thus, "a = a ^ 254" is more space-efficient and time-efficient than "a = 0 - a."
*However*, "a = 0 - a" flips between a and -a for any value of a (e.g., 2 and -2, or 3 and -3, or 4 and -4, etc.), whereas "a = a ^ 254" flips between a and -a if and only if a happens to be equal to 1.
That's because if a is equal to 1, then it's flipping between %00000001 (1, which is +1 if the byte is considered to be a signed number) and %11111111 (255, which is -1 if the byte is considered to be a signed number).
If a is anything other than 1, then "a = a ^ 254" will produce some value other than -a. For example, if a is equal to 2 (%00000010), then "a = a ^ 254" will result in %11111100 (253, which is -3 if the byte is considered to be a signed number).
So it all depends on whether you're specifically wanting to flip between 1 and -1, or whether you're actually wanting to flip between a and -a for any a.
Michael Rideout
#10 Random Terrain OFFLINE
Random Terrain
  • 28,880 posts
    Replay Value
    Nonlinear
Posted Thu Sep 8, 2005 11:37 PM
View Post
Thanks. I was only using 1 in my last test program, so a = a^254 is the best choice for now. I'm sure I'll need a = 0-a one of these times though.
#11 chad5200 OFFLINE
chad5200
    Star Raider
  • 67 posts
Posted Fri Sep 9, 2005 6:14 AM
Weird...
The "sample.bas" included with bB 0.35 includes the command:
"shipvelocity=-shipvelocity"
and that compiles just fine.
Why?
#12 Random Terrain OFFLINE
Random Terrain
  • 28,880 posts
    Replay Value
    Nonlinear
Posted Fri Sep 9, 2005 6:31 AM
Weird...
Why?
View Post
I wonder if it has to do with this:
dim shipvelocity=b.b
I still don't understand that yet. Or maybe it has to do with this:
include fixed_point_math.asm
#13 SeaGtGruff OFFLINE
SeaGtGruff
  • 5,566 posts
Posted Fri Sep 9, 2005 6:38 AM
Weird...
Why?
View Post
Hmm, you're right! Three things come to mind, but I don't have time to check them out right now:
(1) Because shipvelocity is a "dim" instead of a "straight variable"?
(2) Because shipvelocity is a "floating-point" variable instead of an "integer byte"?
(3) Because batari said that "a = - a" should have worked, so it's apparently a bug related to at least that specific scenario (if not others as well), similar to the way that "||" followed by ">" produces a bug, yet "||" followed by "<" doesn't.
Michael Rideout
#14 Random Terrain OFFLINE
Random Terrain
  • 28,880 posts
    Replay Value
    Nonlinear
Posted Fri Sep 9, 2005 6:45 AM
Weird...
Why?
View Post
View Post
I know for sure it's not because of a regular dim, since I was using directionx=-directionx and it didn't work.
#15 batari OFFLINE
batari
    )66]U('=I;B$*
  • 6,680 posts
  • begin 644 contest
Posted Fri Sep 9, 2005 2:25 PM
Weird...
Why?
View Post
Michael Rideout
View Post
It's #3. There is a specific section of the compiler where it handles "assignment to a negative" and I thought I specifically coded this case in. It looks like 4.4 fixed point types were coded properly, but apparently integers were not.
