6502 ASM pretty formatter
EricBall
Does anyone know of a tool (DOS, Windows, or C++ source) which will reformat 6502 ASM for consistency?
For Leprechaun, I've got chunks of code which I've done at different times & I haven't been consistent with my use of upper & lower case. I'd like to be able to run my source through a filter which will reformat everything.
I'm thinking stuff like opcodes as lower case, equate labels as upper case, address labels as lower etc.
  • 3 weeks later...
Did you find something? I saw that Beautifer supports some asm types.
964063[/snapback]
Nope, didn't find anything, and haven't had the time to create something myself. I also found that I had some semi-contradictory desires on how to handle different labels. (Important, because labels are case sensitive in DASM.)
  • 2 months later...
964063[/snapback]
964844[/snapback]
Did you decide on a method or find an utility?
Be kind to wizards or you shall be replaced with a very small Perl script.
  • 1 month later...
Here is a little tool that let you format your source.
Not very sophisticated but it's a first try.
I tested it with some DASM source code and it worked quite well but I am don't use macros or special pseudo op's.
You can add instructions or pseudo op's in the corresponding txt files.
Just give it a try and let me know what you think.
One more note, you need the .NET framework 1.1 to let it run.
6502Formatter.zip
  • 11 years later...
I've wrote a pretty printer for 6502 assembler code, Aardvark was a mess of tabs and spaces, so I needed something to make it uniform.
I hope it's also useful for someone else.
REMEMBER: DON'T APPLY IT OVER YOUR ORIGINAL SOURCE CODE, MAKE A BACKUP FIRST!!! (it could have hidden bugs)
https://github.com/nanochess/pretty6502
