XL Translator Source...
7 replies to this topic
#1 Curt Vendel ONLINE
Curt Vendel
  • 4,685 posts
Posted Fri Oct 28, 2005 11:16 PM
TITLE 'The ATARI Translator ---------------------'
SUBTTL 'Program Identification and Revision History'
; ATARI Translator
; Version 1
; September 20, 1983
; This auto-booting diskette installs an ATARI 800 Operating
; System (Revision B) in RAM "under" the ROM-based O.S. in
; an XL-line computer. It exists to allow consumers to run
; most 3rd party software which would otherwise fail to exe-
; cute on the XL computers due to "violations" of the rules
; for proper Operating System usage. It is NOT meant to en-
; courage continued disregard for the stated O.S. guidelines
; by independent software vendors.
; Once this disk has been loaded, the user is prompted to
; remove it and insert the application diskette (or cassette)
; and press the [SELECT] key. When this occurs the system
; undertakes a COLD START in the new, RAM-based O.S. envir-
; onment. For all intents and purposes, the machine should
; then look exactly like an ATARI 800 (with the few caveats
; outlined below) and the program should boot and run fine.
; In order to properly service a [RESET]-triggered WARM START,
; the RAM-based O.S. has been modified to continually "watch"
; the contents of the DOSINI vector. When/if the application
; sets this vector the O.S. saves the contents and steals it
; back so that it always points to some code which re-enables
; the soft O.S. upon [RESET]. A normal WARM START is then
; processed by the soft O.S. This [RESET] key handling only
; works for applications which do not themselves jump through
; DOSINI. Side 'B' of the TRANSLATOR diskette has been config-
; ured to allow programs of this class (ie. any which boot the
; 850 Interface Module) to run properly. However, in this case
; the [RESET] key will not reselect the RAM-based O.S.
; The Translator assumes the following conditions for proper
; operation:
; + 64K RAM system (ie. 600XL w/expansion module)
; + The application does not write to PORTB ($D301)
; + IRQs and NMIs are not permanently disabled by the
; application (or [RESET] may not function correctly)
; + On a 1450XLD, application is booted from SIO-based disk
; + Application does not alter locations $0160 thru $0170
; + Application does not expect RAM in 4K block at $C000
; By configuring the system as an ATARI 800, the application
; will not be able to take advantage of certain XL-specific
; features, such as function keys F1-F4, the HELP key, PBI
; peripheral devices, etc.
; MODS: Joe Miller Add graphics and code for [RESET] 83-09-15
; Greg Riker Original version 83-03-20
SUBTTL 'Macro Definitions'
LIST I,-M
WATCH MACRO
%L LDA DOSINI+1 ;If DOSINI high byte has changed
CMP #high RAMLINK
BEQ ?X%K
STA SVDINI+1 ; Save new high byte
LDA #high RAMLINK
STA DOSINI+1 ; Replace w/WARM START trap address
;Endif
?X%K LDA DOSINI ;If DOSINI low byte has changed
CMP #low RAMLINK
BEQ ?Y%K
STA SVDINI ; Save application's low byte
LDA #low RAMLINK
STA DOSINI ; Restore WARM START trap address
?Y%K ;Endif
ENDM
PATCH MACRO DEST,SOURCE,COUNT
%L LDA #low %1 ;Copy 'COUNT' bytes from 'SOURCE' to 'DEST'
STA DEST
LDA #high %1
STA DEST+1
LDA #low %2
STA SOURCE
LDA #high %2
STA SOURCE+1
LDA #low %3
STA COUNT
LDY #0
?Z%K LDA (SOURCE),Y
STA (DEST),Y
INY
DEC COUNT
BNE ?Z%K
LDA #high %3
BEQ ?Q%K
INC SOURCE+1 ;NOTE: special case for O.S. copy
INC DEST+1
BNE ?Z%K
?Q%K
ENDM
ALIGN MACRO ;Page-aligned location counter
ORG [[high *]+1] shl 8
%L
ENDM
RESET SET *O ;Set conditional assembly parameter
INCLUDE D2:XLBOOT.ASM
INCLUDE D2:XLSCR1.ASM
INCLUDE D2:XLSCR2.ASM
INCLUDE D2:XLSCR3.ASM
INCLUDE D2:XLITES.ASM
SUBTTL 'Mainline'
; This is the TRANSLATOR mainline.
; It activates a textual prompt on the display and waits
; for the [SELECT] keypress. When [SELECT] is pressed,
; The XL O.S. is swapped out and the 400/800 Rev. B. O.S.
; is copied into RAM in its place. A few key patches are
; made to the RAM-based O.S. and WARM START recovery code
; is hidden in RAM at $CFxx. When this is done, a COLD
; START is invoked by the newly installed O.S.
ALIGN
SWAPOS LDA DLJMP ;Move display list 'JMP' address
STA DLJ ;Into zero page (for indirect STA)
LDA DLJMP+1
STA DLJ+1
LDA RAMSIZ
CMP #$C0
BCC TXTON ;If Cartridge (or BASIC) not present, then
LDX #low CRTLEN
LDA #0 ; Repeat
NOCART STA CARTIN,X ; Remove 'Cart. Present' message
DEX
BPL NOCART ; Until all characters removed
;Endif
TXTON LDA #1
STA TXTFLG ;Enable prompt message (via VBL)
SELECT LDA #8 ;Repeat
STA CONSOL ; Convention for reading CONSOL keys
LDA CONSOL ; Read CONSOL keys
AND #2
BNE SELECT ;Until [SELECT] pressed
LDA #0
STA SDMCTL ;Disable screen DMA
STA DMACTL
STA NMIEN ;Disable all interrupts
STA IRQEN
SEI
LDA PORTB ;Load current PORTB PIA status
AND #$FE ;Disable O.S. ROM (leave BASIC unchanged)
STA PORTB
PHA ;Hold that thought for a moment
EJECT
; Install REV B. O.S. Patches -------------------------
PATCH $D800,OSOBJ,$2800 ;Copy Rev B. O.S. into RAM
PATCH RAMSCAN,PC0CODE,PC0LEN ;Copy O.S. patches to page $Cx
PATCH $F26F,PATSIZ,3 ;SPECL ram sizing patch
IF RESET ;If [RESET] processing enabled, then
PATCH $E737,PATIRQ,3 ; Low-level IRQ watchdog patch
PATCH $E7AB,PATNMI,3 ; Immediate VBLANK watchdog patch
PATCH $F173,PATROJ,3 ; Post stack-clear 'trojan horse'
PATCH $F366,PATCLD,3 ; Single boot sector fix
; Repoint the JMP (DOSINI) to our vector --------------
LDA #low SVDINI ; New vector for disk-booted init
STA DINI+1
LDA #high SVDINI
STA DINI+2
ENDIF ;Endif
; Save a few XL-O.S. WARM START descriminator bytes ----
PLA ;Reload current PORTB PIA status
STA SVPORTB ;Save it for WARM START restoration
LDA GINTLK ;Save Cartridge interlock flags
STA SVINTLK
LDA CARTCK ;Save Cartridge checksum (if needed)
STA SVCRTCK
LDX #2 ;Save XL O.S. power-up test bytes
RECON LDA PUPBT1,X
STA SVPUCHK,X ;for WARM START power-up check in XL
DEX ;(these are restored in TROJAN)
BPL RECON
; Finally, startup the RAM-based O.S. -----------------
JMP COLDSV ;Invoke Rev. B O.S. COLD START
SUBTTL 'Patches and WARM START Linkage'
; These 5 lines are PATCHed into the O.S. -----------+
PATIRQ JMP DSCAN1 ;IRQ 'DOSINI' monitor |
PATNMI JMP DSCAN2 ;NMI 'DOSINI' monitor |
PATROJ JMP TROJAN ;Hides routine in stack |
PATSIZ JMP SIZRAM ;Limits RAMSIZ to $C0 |
PATCLD JSR COLDIN ;Special-case 'DOSINI' chk |
; They are the only run-time changes to the O.S. ----+
; The following code is 'safed' in RAM at $Cxxx ----------------+
; v
PC0CODE
LOC RAMSCAN
; -------------- This code, in turn, is moved into the stack,
; where (hopefully) it will remain untouched by
; normal execution of the application. It is
; needed to reselect the RAM O.S. on [RESET] --+
STKCODE ; |
SEI ;Disallow interrupts for switchback |
LDA #$FE ;Reestablish access to data at $Cxxx |
STA PORTB ;By momentarily deselecting ROM O.S. |
LDA SVPORTB ;Load previously saved PORTB status |
STA PORTB ;Reconfigure memory/disable ROM O.S. |
JMP WARMSV ;Re-invoke WARM START --> |
STKLEN EQU * - STKCODE ; |
; -------------- End of Stack Usage -------------------------+
; The 'trojan' instructions are executed just after memory
; is cleared after both a COLD or WARM start in the 800 O.S.
; It deposits the above routine in the stack and restores
; some key values needed by the XL O.S. to descriminate be-
; tween a WARM and COLD start upon the user pressing [RESET].
TROJAN PATCH RAMLINK,STKCODE,STKLEN
LDA SVINTLK ;Restore XL-O.S. control bytes
STA GINTLK
LDA SVCRTCK
STA CARTCK
LDX #2 ;Restore 'magic' power-up bytes
REWARM LDA SVPUCHK,X
STA PUPBT1,X
DEX
BPL REWARM
LDA #2 ;Complete 'patched' code
STA LMARGN
JMP $F177 ;Return to O.S. initialization code
; Storage area for key TRANSLATOR variables --------------------+
SVDINI DS 2 ;Application's DOSINI saved here |
SVPORTB DS 1 ;COLD START PORTB status saved here |
SVINTLK DS 1 ;Cartridge interlock flag saved here |
SVCRTCK DS 1 ;Cartridge checksum saved here |
SVPUCHK DS 3 ;O.S. WARM START test bytes saved here |
; The above bytes should not be touched by the application -----+
; This ensures the O.S. stops sizing RAM at $C000 ---------------
SIZRAM CLC ;Patch to O.S. RAM sizing code
ADC #$10
STA TRAMSZ
CMP #$C0 ;Stop scan at $C000
BCS SIZRTS
JMP $F25F
SIZRTS RTS
; These routines 'WATCH' for the application stealing the
; DOSINI vector. If that happens, the new value is saved
; at SVDINI and DOSINI is re-stuffed with a vector to the
; [RESET] recovery code hidden in page 1.
COLDIN WATCH ;Special case for 1 boot sector disks
JMP (SVDINI)
DSCAN1 STA IRQEN ;Low-level IRQ patch
WATCH
JMP $E73A
DSCAN2 WATCH ;VBLANK NMI patch
JMP (VVBLKI)
CPYRT DB 'Copyright 1983 ATARI, Inc.'
DB $02,$BB,$5A,$30,$5F,$EE,$3D,$A8,$20
DB $47,$50,$52,$26,$4A,$42,$4D,$33,$20
ORG *O
PC0LEN EQU * - PC0CODE
; This ends the code stored in $Cxxx ---------------------------+
ALIGN
INCLUDE D2:OSB800.ASM
SUBTTL 'End --------------------------------------'
RAMEND
END RAMLOAD
#2 kheller2 OFFLINE
kheller2
  • 1,278 posts
Posted Tue Mar 6, 2007 9:50 PM
After reading this...
Does anyone know why Atari decided to go with 64K on the XLs? Was this a design decision to allow for the running of OSB or marketing or? Is the Translator just in response to the issues seen with the 1200XL and software incompatabilities?
How is this different from the "Fix-XL" that was a 3rd party patch?
I always wondered what the B side of the Translator was for... =)
Edited by kheller2, Tue Mar 6, 2007 9:50 PM.
#3 Urchlay OFFLINE
Urchlay
  • 1,133 posts
Posted Tue Mar 6, 2007 11:08 PM
Any chance of this being posted as a zip file or such? The board software destroys the formatting, so it'd need some work to be able to actually assemble the source...
#4 Rybags ONLINE
Rybags
  • 15,897 posts
Posted Tue Mar 6, 2007 11:16 PM
It's only part of the code.
Should be a loader as well. I'd guess that it probably reads the OS image to low RAM, then moves it entirely to $D800-FFFF once loaded.
#5 atarifan49 OFFLINE
atarifan49
    Dragonstomper
  • 539 posts
Posted Wed Mar 7, 2007 12:38 AM
Hey Karl,
The B side was for loading a different version of Atari 800 OS when the A side didn't work. I believe it was OS version A. I've had to use side B sometimes. Don't remember which titles though.
Glenn
#6 atarifan49 OFFLINE
atarifan49
    Dragonstomper
  • 539 posts
Posted Wed Mar 7, 2007 12:40 AM
Thanks Curt. You continue to rock the Atari community with your wonderful finds.
#7 classics OFFLINE
classics
  • 2,106 posts
  • So many projects, so little time.
Posted Wed Mar 7, 2007 1:00 AM
I always thought the extra 16k RAM in the OS area was for backward compatibility, so OSB could be loaded for programs not compatible with the new XL OS.
#8 kheller2 OFFLINE
kheller2
  • 1,278 posts
Posted Wed Mar 7, 2007 1:09 AM
Hey Karl,
Glenn
I always thought that too, but the above comments make me wonder:
"This [RESET] key handling only
Edited by kheller2, Wed Mar 7, 2007 1:09 AM.
