Hex Editors
8 replies to this topic
#1 Shawn OFFLINE
Shawn
    As Above
  • 18,851 posts
  • So Below
Posted Tue Dec 13, 2005 12:09 AM
Hey All,
Can anyone recomend a Hex Editor that is easy to cut BIN's in half with? I have tried a few but I want one that is "point and shoot" easy. I need mainly for distella to make 8k games into 4k chunks.
Thanks,
Shawn Sr.
#2 Tom OFFLINE
Tom
    Moonsweeper
  • 455 posts
Posted Tue Dec 13, 2005 12:35 AM
Why a hex editor ? All you need is dd.
dd if=8krom.bin of=bank0.bin count=4096 bs=1
dd if=8krom.bin of=bank1.bin count=4096 bs=1 skip=4096
Simple and powerful.
#3 Shawn OFFLINE
Shawn
    As Above
  • 18,851 posts
  • So Below
Posted Wed Dec 14, 2005 12:08 AM
View Post
dd? :?
#4 Tom OFFLINE
Tom
    Moonsweeper
  • 455 posts
Posted Wed Dec 14, 2005 3:36 AM
A standard Unix utility. Everybody running Windows should have a Cygwin or GnuWin32 installation.
#5 Shawn OFFLINE
Shawn
    As Above
  • 18,851 posts
  • So Below
Posted Wed Dec 14, 2005 11:27 AM
View Post
downloaded it and used cygwin and I keep getiing this error message and I don't know why:
dd: opening '8kfile.bin' : No such file or directory
Any idea's? Do I need to use a specfic directory? I tried copying my 8kfile.bin into the cygwin working directory but no go.
Edited by silver_surfer, Wed Dec 14, 2005 2:57 PM.
#6 Tom OFFLINE
Tom
    Moonsweeper
  • 455 posts
Posted Wed Dec 14, 2005 5:50 PM
View Post
View Post
You did use the correct filenames, right ? "8krom.bin", "bank0.bin" and "bank1.bin" in my first post were of course only placeholders. You have to substitute them with the real filenames you want to use. If that isn't the problem, post the whole command line you're using.
#7 Shawn OFFLINE
Shawn
    As Above
  • 18,851 posts
  • So Below
Posted Thu Dec 15, 2005 10:35 AM
View Post
View Post
View Post
yes I know you where using dumy names 8kfile.bin means nameofmygame.bin
The exact string I'm unsing is exactly what you have posted to use. I'm runnig WIN XP PRO Build 2600 with Service pack 2 if that makes a difference.
#8 Tom OFFLINE
Tom
    Moonsweeper
  • 455 posts
Posted Thu Dec 15, 2005 12:56 PM
Sorry, you're doing obviously something wrong, but I really don't know what it could be (the command I posted above is correct)
You don't need to put files in specific directories, but you must either pass the full path to the input file to dd, or you change to the directory the input file is in and only pass the file's name, without path information.
Iirc Cygwin also doesn't treat filenames case sensitive (Unix systems do so), so it shouldn't matter wether you pass "X.FOO" or "x.FOo" for a filename.
#9 Nukey Shay OFFLINE
Nukey Shay
    Sheik Yerbouti
  • 21,885 posts
Posted Thu Dec 15, 2005 1:33 PM
All this worry about filenames and such? :P
I just use a freeware program called HJ Split. Cuts files into any size fragments.
