Removing epoxy blobs
5 replies to this topic
#1 pyl85 OFFLINE
pyl85
    Space Invader
  • 12 posts
Posted Fri Mar 3, 2006 1:32 AM
It's time to resume my FB2 cart mod and survey the damage done last time. I pulled up a few solder pads so I'm going to be needing to solder in some jump wires that go from the "big thing" to the "little thing." The only problem is that the "little thing" is completely covered in epoxy. Anyone know of a good way to remove a bit so I can get access to the pins? And sorry for the crude description.
Thanks,
Greg
#2 Curt Vendel OFFLINE
Curt Vendel
  • 4,899 posts
Posted Fri Mar 3, 2006 8:16 AM
Greg,
You are going to have a very difficult time trying to accomplish that task. The "globs" are an industrial epoxy silicate. Its a very hard type of material and it bonds itself to the electronics contained within, if the silicate cracks it will then crack and damage the components underneath.
An acid bath to attempt to remove it will also end up damaging the components as well.
There is one method which has a possible chance to working, you rapidly heat and freeze the epoxy, this will have the occassional result of "popping" the epoxy off of the pcb without damaging the components underneath, but this method will most likely destroy several dozen boards before you are successful.
Curt
Thanks,
Greg
View Post
#3 pyl85 OFFLINE
pyl85
    Space Invader
  • 12 posts
Posted Fri Mar 3, 2006 4:05 PM
Thanks, Curt. I figured that it would be near impossible to remove the epoxy, I just thought I'd ask. Looks like I better get started repairing traces...
-Greg
#4 pkblack OFFLINE
pkblack
    Star Raider
  • 80 posts
Posted Sun Apr 23, 2006 8:17 AM
I remember seeign this site where someone figured how to get into a large piece of expoxy. there is the address http://www.multigame.com/pacplus.html
#5 Bryan OFFLINE
Bryan
  • 10,927 posts
  • Cruise Elroy = 4DB7
Posted Sun Apr 23, 2006 9:18 AM
Wow... I totally destroyed a PacPlus module once trying to get into it.
-Bry
#6 lbaeza OFFLINE
lbaeza
    Dragonstomper
  • 503 posts
  • Former NRXA8-staff
Posted Thu Jun 15, 2006 8:28 PM
More epoxy madness here:
http://www.tripoint....xpss/unpot.html
Regards
