a 688*576 picture on Jaguar !
31 replies to this topic
#1 GT Turbo OFFLINE
GT Turbo
    Dragonstomper
  • 581 posts
Posted Sun Apr 30, 2006 4:39 PM
Yes it's possible, when Zerosquare do nothing, he do some nice code, enjoy this one :
http://www.jagware.o...p?showtopic=230
GT ;)
#2 gusbucket13 OFFLINE
gusbucket13
    Star Raider
  • 83 posts
Posted Mon May 1, 2006 3:47 AM
Thats cool, I personally havent seen anything like this before. Very Nice.
GB13
#3 The_Laird OFFLINE
The_Laird
    Bratticus Maximus
  • 3,571 posts
  • Atari Sega Nerd
Posted Mon May 1, 2006 3:52 AM
Lookin' gooood! :lust:
#4 Matthias OFFLINE
Matthias
  • 1,171 posts
Posted Mon May 1, 2006 5:43 AM
Congratulations,
that's a great achievement!
Best regards
Matthias
#5 GT Turbo OFFLINE
GT Turbo
    Dragonstomper
  • 581 posts
Posted Mon May 1, 2006 12:06 PM
Zerosquare strike back with a 1376*576 picture on a Jag !!
GT Turbo (JagWare)
#6 Zerosquare OFFLINE
Zerosquare
  • 2,740 posts
Posted Mon May 1, 2006 12:37 PM
Thanks for the comments, everyone :)
Don't forget to try out the 1376x576 version also (different picture) ;)
Edited by Zerosquare, Mon May 1, 2006 12:40 PM.
#7 JagChris OFFLINE
JagChris
  • 3,601 posts
Posted Mon May 1, 2006 9:24 PM
My screen wont stop rolling.
#8 GT Turbo OFFLINE
GT Turbo
    Dragonstomper
  • 581 posts
Posted Tue May 2, 2006 12:59 AM
Yes, because it's 50 Hz only. In 60 Hz mode, you have to do a lot of modifications, i have asked Zerosquare for that, but i think he can explain the why ;) by itself
GT Turbo (JagWare) ;)
#9 walter_J64bit OFFLINE
walter_J64bit
  • 5,180 posts
Posted Tue May 2, 2006 10:29 AM
I've got the deom to run, but it needs to be in NTSC ;)
Edited by walter_J64bit, Tue May 2, 2006 12:24 PM.
#10 Matthias OFFLINE
Matthias
  • 1,171 posts
Posted Tue May 2, 2006 10:32 AM
Hello!
Unfortunately a normal CathodeRayTube can only display about 768 pixels per scanline(*),
but great to hear that you are exploring this topic further ;-)
Regards
Matthias
(*) = I know that there are no real "pixels" on a scanline of a CRT, it's the calculated value for the used video-signal.
#11 walter_J64bit OFFLINE
walter_J64bit
  • 5,180 posts
Posted Tue May 2, 2006 12:32 PM
Hello!
Regards
Matthias
I use my MADCATZ LDC (it's NTSC) I found it can handle PAL resoution but the games or progroms needs to be in "In a 60 Hz mode"
Edited by walter_J64bit, Tue May 2, 2006 12:33 PM.
#12 justclaws OFFLINE
justclaws
    Dragonstomper
  • 939 posts
  • Underground but not dead.
Posted Tue May 2, 2006 3:48 PM
Hi GT,
Great to see you chaps still experimenting.
First published interlace code is in Tempest 2000, but this looks nicer!
Cheers, keep up the good work!
Regards,
JustClaws.
#13 Zerosquare OFFLINE
Zerosquare
  • 2,740 posts
Posted Tue May 2, 2006 4:43 PM
Again, thanks for the positive feedback. I'm still polishing the code, and planning to add a 60 Hz version ; details on how to setup the modes will be released publicly.
#14 Zerosquare OFFLINE
Zerosquare
  • 2,740 posts
Posted Wed May 3, 2006 9:06 AM
I've posted new versions which should work for both 50 Hz (green power LED) and 60 Hz (red power LED) Jaguars ; you can find them here.
#15 Paolo OFFLINE
Paolo
    Dragonstomper
  • 910 posts
Posted Thu May 4, 2006 12:17 PM
My question is: (sorry, I didn't read ALL the discussion -both there and at JS2-)
May this image be used as a backgroung in a true game?
Or the Jag is too much busy in keeping it onscreen?
#16 Zerosquare OFFLINE
Zerosquare
  • 2,740 posts
Posted Thu May 4, 2006 2:20 PM
There are several points to consider :
1) Processors usage is not a problem since the Object Processor is the one doing the hard work.
2) Interlacing does not require additional resources per se (although there are twice as many lines to display, they are refreshed half as often).
3) Higher horizontal resolutions use more bandwidth on the internal bus ; it can slow other things down.
4) Large pictures need a lot of ROM to store them, and a lot of RAM to display then (it's less of a problem with SCPCD's JagCF card).
I've not done any benchmarking yet, but my feeling is that 1376x576 would be only interesting for still pictures (there are limitations on sprites in this mode anyways), and that 688x576 would still be interesting for general use (but don't quote me on that :) )
Edited by Zerosquare, Thu May 4, 2006 2:22 PM.
#17 Symmetry of TNG OFFLINE
Symmetry of TNG
    Moonsweeper
  • 252 posts
Posted Sun May 7, 2006 5:37 AM
You know.. I honestly dont know if that is truly interlace...Or if it is something even related to interlace... I have no idea what it does except "shake" the text.... (interlace "flickers" in Y direction.. but tempest "shakes" the text... in X..and probably Y aswell..)
So as far as i knew I was the first one that did true interlace in december 04... (but thought to have it as a "ess" up my sleve for a bigger demo release... but Zerosquare beat me to it ;) ... which is ok... Im just glad some hackers are emerging in the scene...
This is offcourse if not someone else did like I did and kept it a secret ..perhapps it was done eons ago but never got to see the light of day... (perhapps it was tested by atari but banned & forbidden to be use by licensed games... we never know).
But it opens the path for the first, retro, SlideShow demo on the jaguar =) ...jeyyy =)
regards
/Sym
#18 Andrew Davie OFFLINE
Andrew Davie
  • 1,829 posts
  • Dr.Boo
Posted Sun May 7, 2006 6:01 AM
Doesn't count unless you release it! Keeping it secret means you didn't do it.
Cheers
A
#19 Zerosquare OFFLINE
Zerosquare
  • 2,740 posts
Posted Sun May 7, 2006 7:12 AM
That's likely, considering the fact that you need to modify the VP register for interlacing to work, and this quote from the Jag's Release Notes (see the attached picture).
#20 Symmetry of TNG OFFLINE
Symmetry of TNG
    Moonsweeper
  • 252 posts
Posted Sat May 13, 2006 12:52 AM
What doesnt count? ...the fact that Tempest isnt true interlace, or the fact that I did true interlace in Dec-04, or the fact that ZeroSquare released the first true interlace for the jaguar? ...
Lets stick to facts not fiction please, just because someone didnt experience WW2 doesnt mean it didnt happen..
Zerosquare:
Yes that is what i meant... atari never wanted their coders to poke around with these registers.. and you need to poke alot to get interlace.. Hence my oppinion that its possible that this is a "first time experience" for the jaguar..
Or perhapps its unstable in a way we havent experienced yet... ?
I would urge ALL with a BJL to test this demo on all jaguar series.. so we get a verification that the method works stable on all jaguars.
regards
/Sym
#21 Fredifredo OFFLINE
Fredifredo
    Dragonstomper
  • 501 posts
Posted Sat May 13, 2006 4:04 AM
Work fine on my K french pal jaguar :)
#22 supercat OFFLINE
supercat
  • 6,401 posts
Posted Sat May 13, 2006 2:04 PM
If one were writing a Doom-style game that was capable of updating the screen at 60fps, it should be able to handle interlacing at full-speed. If the game was only capable of running at a lower frame rate, using an interlaced display would make things worse.
One thing I've wondered about with NTSC is whether it would be possible to jinx the vertical timing to get a 3:1 interlacing pattern. The serration pulses would be non-standard, but I would think that if the signal was generated properly it should work on most television sets.
Actually, one thing I would have liked to have seen emerge as a standard for use with DVDs would have been a video format with 72 fields/second 24 frames/second using NTSC-standard horizontal scanning. That would have allowed enhanced vertical resolution (compared with NTSC), proper movie frame rate, and minimal additional electronic complexity. Never happened, of course.
#23 Zerosquare OFFLINE
Zerosquare
  • 2,740 posts
Posted Sun Jun 4, 2006 10:54 AM
For the curious, I've released some info about video on the Jag (not everything yet... see the link for the explanation :P) here. We've also discovered that Tempest 2000 "interlace"... doesn't.
Edited by Zerosquare, Sun Jun 4, 2006 10:56 AM.
#24 Math You OFFLINE
Math You
    Dragonstomper
  • 882 posts
Posted Sun Sep 30, 2007 6:54 AM
Could the Jaguar do 720x480 pixels in widescreen like an NTSC dvd player would?
#25 Zerosquare OFFLINE
Zerosquare
  • 2,740 posts
Posted Sun Sep 30, 2007 7:31 AM
Yes. In fact, the Jaguar can output up to approx. 1400 pixels per horizontal line in 60 Hz mode -- better than a DVD player.
